POV-Ray : Newsgroups : povray.pov4.discussion.general : Bruteforcerendering with povray Server Time
19 May 2024 22:58:51 EDT (-0400)
  Bruteforcerendering with povray (Message 21 to 29 of 29)
Subject: Re: Bruteforcerendering with povray
Date: 23 Jan 2008 20:14:26
Message: <4797e672@news.povray.org>
On a second thought... *sighs* yeah Indigo renders pretty realistic
scenes maybe as good or even better tha POV-Ray...... O.O! Just what did
I said?! just shoot me!! :)
Date: 24 Jan 2008 09:08:17
Message: <47989bd1$1@news.povray.org>
"Saul Luizaga" <sau### [at] netscapenet> wrote in message
news:4797e672@news.povray.org...
> On a second thought... *sighs* yeah Indigo renders pretty realistic scenes
> maybe as good or even better tha POV-Ray...... O.O! Just what did I said?!
> just shoot me!! :)
take a look at the rendertimes on those images before you let someone shoot
you :)
Date: 24 Jan 2008 09:25:01
Message: <web.47989f8ce181953e811410630@news.povray.org>
Once again: All classic features should be availible in PovRay 4.
The decision of choosing the algorithm is up to the user.
Every discussion about the time of rendering is mean less: A look of the Indigo
side shows everyone, that there ARE people who like to wait the time its needed
for the image.
Now one has to wait longer then he like to. Just turn back to classic algorithm
if you like to.
-holger-
Date: 24 Jan 2008 11:03:52
Message: <4798b6e8$1@news.povray.org>
> Indigo
> needed
> for the image.
I'm sure several years, or even decades, ago, people were waiting the same
times for POV to render.
Date: 24 Jan 2008 12:25:01
Message: <web.4798c8d6e181953ef48316a30@news.povray.org>
yes, but the difference is that at the time there was no other option to obtain
very detailed and realistic results.  Both photon mapping and radiosity
generate are capable of delivering very realistic and accurate results without
the huge performance penalties associated with the bruteforce methods...
Date: 24 Jan 2008 13:00:01
Message: <web.4798d175e181953e63108fea0@news.povray.org>
nemesis skribis:
But let us not forget that the _are_ things that povray is unable to render.
Imagine a room with a window. The window will act as a light source, making the
objects in the room cast shadows and generate caustics. Even if no direct
sunlight passes through the window. Radiosity can make the window illuminate
the room, but cannot generate (decent) shadows.
One could also imagine two walls that appear to have the same colour under a
broad-spectrum white light (such as an incandescent bulb), but have different
colours when observed under an emmissive-spectrum light (such as an LED). Such
effects would require a renderer to maintain hundreds of wavelengths instead of
just the three colours, and AFAIK no renderer can do this. (Still, it would be
cool if povray were the first.)
Long story short: realism is subjective. When the film Tron came out it had
amazing CGI. Nowadays we think it has very bad CGI. Today we think povray 3.6
generates amazing CGI. In ten years, http://xkcd.com/338/
Hymyly.
And there was light.
Date: 24 Jan 2008 13:55:01
Message: <web.4798de56e181953e773c9a3e0@news.povray.org>
funny you say that.  I recently was testing radiosity and meshes and the image
bellow is radiosity-only:  2 very bright ambient objects above providing the
"light".  The ground shadow is very much smoother than one generated by
area_lights in another test.  The shading in the body, though, seems to suffers
a bit.  I don't know if radiosity has some trouble with meshes...
Download 'bunny-wip2.jpg' (19 KB)
Preview of image 'bunny-wip2.jpg'
Date: 25 Jan 2008 07:15:00
Message: <web.4799d1bfe181953ef1cc7120@news.povray.org>
nemesisskribis:
Wow. I have tried the same, but even with crazy high settings (count 1600,
error_bound 0.001, etc) the best I have managed to render was a slightly
grayish patch behind my obstacles. (And long rendering times, of course.) Could
you perhaps show me the code, please? I have tried for quite long to achieve
these effects.
Still, my previous statement remains valid: there are things that povray cannot
render. And there are things that no rendering software can render (yet).
Hymyly.
Date: 25 Jan 2008 15:06:48
Message: <479a4158@news.povray.org>
there you go.  You can find the bunny model in my scene
radiosity_and_bunnies.  I posted the source in
povray.binaries.scene-files...
You know, ridiculously low error_bound values don't really help much.
Fiddling with lower pretrace steps gives far better results IMO...
#local HQ = 0;
#local GI = 1;
#local GIgather = 0;
#local CAD = 0;
#local CAMS = 1;
#if (GI)
#local LF = .5;
#else
#local LF = 1.1;
global_settings {
    #if (GI)
    radiosity {
        brightness 1.2
        always_sample no
        #if (!GIgather)
            load_file "bunny.rca"
        #else
            save_file "bunny.rca"
            #if (HQ)
            count 200*4 //1400
            error_bound .2
            low_error_factor .2
            adc_bailout .01/.4
            nearest_count 14
            recursion_limit 3
            #else
            count 80*10
            error_bound .2
            adc_bailout .01/.7
            low_error_factor .2
            nearest_count 18
            recursion_limit 3
        pretrace_start .04
        pretrace_end .006
        gray_threshold .7
    #else
    ambient_light 1.4
background { rgb 0 }
union {
    plane { y, 0 pigment { rgb 1 } finish {ambient 0} }
    #if (0)
    sphere {y*.7,.7
            //pigment {rgb 1}
                pigment{ marble turbulence 1.2 octaves 5 lambda 4 scale
1.4 color_map {[0 rgb 1][.7 rgb 1][.77 rgb .8][1 rgb .6]} }
            finish {ambient 0 diffuse .62}
    #else
    object {#include "meshstandford_bunny.inc" scale 10 rotate -y*120
translate -y*.08 }
    #if (!GI)
    light_source { 20*(4-z*8) .8
        #if (HQ)
        area_light x*50,z*50,18,18 jitter adaptive 0 circular orient
    light_source { 20*(4-z*4) .8
        #if (HQ)
        area_light x*60,y*60,18,18 jitter adaptive 0 circular orient
    #else
    box { -30, 30 translate 20*(4-z*8) pigment {rgb 1} finish { ambient 9
diffuse .8 } }
    box { -30, 30 translate 20*(4-z*4) pigment {rgb 1} finish { ambient 9
diffuse .8 } }
    rotate -y*50
    rotate -x*20
    translate z*3-y/2
#if (!GI)
light_source { -z*2+y/3+x .56 shadowless }
camera { aperture .2 blur_samples 40 focal_point y*.15+z*2.2 }
Download 'us-ascii' (7 KB)
