POV-Ray : Newsgroups : povray.pov4.discussion.general : Feature Re-requests - Normal Map and Displacement Map Support Server Time
16 May 2026 09:25:39 EDT (-0400)
  Feature Re-requests - Normal Map and Displacement Map Support (Message 1 to 10 of 11)
Subject: Feature Re-requests - Normal Map and Displacement Map Support
Date: 1 Feb 2008 23:23:36
Message: <8rr7q3h9cj7v2p91bodbk0he8958jbma97@4ax.com>
Please refer to the following thread...
http://news.povray.org/povray.general/thread/%3Cv4pqj217fg814vqilvmdgf2v3ri3i8qj77%404ax.com%3E/
Subject: Re: Feature Re-requests - Normal Map and Displacement Map Support
Date: 2 Feb 2008 04:13:48
Message: <47a4344b@news.povray.org>
  I repeat my answer here:
  You are free to propose a solution to that. Preferably in C++.
  Displacement mapping is used in scanline renderers because it's
feasible there. They use triangle meshes (or easily tesselable surfaces
such as NURBS) which can be easily subdivided and displaced even on
the fly.
  You want it to be done with *any* object in POV-Ray. Well, feel
free to suggest how it could be done.
Date: 2 Feb 2008 06:55:00
Message: <web.47a4595486739be92120b4440@news.povray.org>
I like this Patrick Elliott quote:
"Its not always possible to argue successfully for solution that make things
easier to do in 'specific' cases, when there is a perception of a more
physically 'correct' model already in the engine, and it just happens to
be complicated, frustrating and confusing to get the same result with it
(like subsurface scattering effects, for example)."
I wonder, when povray goes open-source it could probably benefit from using
libraries or code from projects such as Blender to handle displacements,
tesselation or decimate.  I'm not sure it'd be of any help for a raytracer, but
OTOH, Blender uses an internal renderer which seems to mix a scanline with a
raytracer...
BTW, speaking of requests, perhaps it should be useful to allow for the simple
geometric shapes to be treated as isosurfaces in syntax.  So, the parser would
interpret these two in different ways:
sphere { 0, 1 } <-- basic optimized quadratic shape
sphere { 0, 1 displacement { crackle .2 turbulence .06 } }  <-- isosurface
sphere shape displaced by pattern
or even:
union {
  sphere { x/2, 1 }
  box { -1,1 translate -x/2 }
  glue_level .2
  displacement { granite .04 }
} <-- the whole union is an isosurface of the shapes above glued together by 20%
and displaced by pattern
you know, kinda like supporting Chris Hormann' excellent IsoCSG macro lib
directly in syntax.  It's much easier for non-math folks to work on shapes and
transforms rather than functions and function composition.  I always though of
povray's isosurfaces as povray's NURBS... :)
Date: 2 Feb 2008 08:40:18
Message: <47a472c2@news.povray.org>
I'd like to have some way to get an isosurface function from primitives
(including complex CSG). That way we could easily make a complex object
using the normal syntax (instead of something like isoCSG), and then use
it inside a isosurface function.
In the C++ code, each object would have 'trace ray', 'is point inside
shape', etc. and a new 'get isosurface function'. Of course it would be
impossible or very hard to implement for some objects (like text or
julia_fractal).
#declare SomeShape = difference {
     sphere { <0,0,0>, 1 }
     cylinder { -x*2, x*2, 0.5 }
isosurface {
     function { object_function(SomeShape, x-0.5, z, y)*(1-clock) +
object_function(SomeShape, x+0.5, y, z)*clock }
Of course you could also use:
#declare Fn = object_function(SomeShape, x, y, z);
isosurface {
     function { Fn(x-0.5, z, y)*(1-clock) + Fn(x+0.5, y, z)*clock }
Which is shorter code.
Producing:
http://stuff.povaddict.com.ar/pov/iso.avi (XviD)
Date: 2 Feb 2008 09:25:00
Message: <web.47a47caa86739be92120b4440@news.povray.org>
that would be nice too!
> isosurface {
the funny thing is:  the object pattern doesn't work as an isosurface function.
Bummer...
Date: 2 Feb 2008 10:03:22
Message: <47a4863a@news.povray.org>
>> isosurface {
> Bummer...
The object pattern only calculates if some point is inside the object or
not. You need more than that for isosurfaces to work; which is what I'm
suggesting :)
Date: 2 Feb 2008 11:34:21
Message: <47a49b8d@news.povray.org>
> julia_fractal).
  The C++ core code should go towards a simpler, not a more complicated
design.
  What's wrong in having all those functions for every primitive as a
simple library of functions?
Date: 2 Feb 2008 13:42:36
Message: <47a4b99c$1@news.povray.org>
>> julia_fractal).
> design.
I want the *same* syntax on the SDL to be used as a normal object or as
an isosurface function. Have you seen the IsoCSG library? You need to
rewrite all your objects to use it.
I want to grab a complex CSG object, and use it in an isosurface without
having to rewrite it in another format. Can you do that with "a simple
library of functions"?
Date: 2 Feb 2008 18:59:28
Message: <47a503e0@news.povray.org>
  With pov4's new scripting language, maybe.
Date: 4 Feb 2008 11:12:43
Message: <oqdeq3hpvr3hamagac2e2r2nvs5ftpadlf@4ax.com>
I would be happy to do so, if I were more knowledgeable in such matters.  I imagine
someone that is more familiar with raytracing technologies than I may be able to
present a solution.  All I can do
at this time is request the feature.
Perhaps when the 3.7 source code is released, an eager programmer may wish to tackle
such an endeavor.
