POV-Ray : Newsgroups : povray.pov4.discussion.general : A dream about POV4 Server Time
10 Jun 2026 13:46:50 EDT (-0400)
  A dream about POV4 (Message 11 to 15 of 15)
Subject: Re: A dream about POV4
Date: 14 Apr 2009 12:54:08
Message: <49e4bfaf@news.povray.org>
Zeger Knaepen <zeg### [at] povplacecom> wrote:
> intuitively I would expect something like "rotate <1,1,0>*45" to rotate 45
> degrees around the <1,1,0> vector
  What if you want to do is to multiply <1,1,0> by 45 and then use the
resulting vector to rotate the object?
Date: 14 Apr 2009 13:10:01
Message: <web.49e4c280840aad1af06ce2830@news.povray.org>
Then you'd be back to the 3.x syntax, which is just plain incompatible with what
I'd prefer. It's all that easy.
(and no, I wouldn't use "rotate <1,1,0>*45" - rather some "rotate <1,1,0>,45",
which IMO would make it clear what's happening; I think I'd also use "rotate
<1,1,0>,45 deg".)
Date: 14 Apr 2009 13:30:01
Message: <web.49e4c757840aad1a69f956610@news.povray.org>
Maybe, but I think multiplying the vector by the scalar is by far the most
intuitive meaning to that example. The language would be very inconsistent
otherwise (unless the intention was to ditch the asterisk as a multiplication
token...!).
> <1,1,0>,45 deg".)
....while permitting, e.g., "rotate 30*<1,1,0>,45" or similar? I would hope that
the new SDL would retain the way literals are handled (or close to it), however
the object structure ends up.
Date: 14 Apr 2009 20:25:00
Message: <web.49e52846840aad1af06ce2830@news.povray.org>
> > <1,1,0>,45 deg".)
Sure, "rotate 30*<1,1,0>,45" or even "rotate <1,1,0>*30,45" would be fair values
(though it doesn't actually make sense to scale a vector when you just want to
rotate around it...)
Date: 16 Apr 2009 05:56:52
Message: <49e700e4@news.povray.org>
> values
> want to
The rotate keyword is just wrong anyway, it is not obvious what the result
will be (does it do x first or z first?).  You also can get the "gimbal
lock" problem with specifying rotations this way.
A new rotate keyword could either take a single vector (for 3.x
compatibility), or take a vector and a scalar (to rotate a certain amount
around that axis).  Then all of the following would be valid:
rotate y*45
rotate <0,45,0>
rotate <1,1,0> * 45
rotate <1,1,0> , 45  // new syntax, rotate 45 degrees about the axis
rotate y,45          // new syntax, rotate 45 degrees about the axis
Anyway, I assume in POV4 "rotate" will just be a macro that generates a 4x4
transformation matrix, it should be easy to update/modify later without
recompiling the source.  You could even add a rotate macro that takes a
quaternion as a 4-element vector.
