POV-Ray : Newsgroups : povray.pov4.discussion.general : GPU usage Server Time
14 May 2024 21:05:23 EDT (-0400)
  GPU usage (Message 1 to 10 of 26)
Subject: GPU usage
Date: 31 Dec 2008 12:50:00
Message: <web.495bb04c6954e3ed37f671630@news.povray.org>
I was curious, with the OpenCL 1.0 spec, and also with ATI/AMD releasing
open-source code now for utilizing the GPU processing power, could it be
possible to utilize GPU acceleration within POV-Ray?  I know a lot of POV-Ray
is CPU intensive and utilizing the threads in the GPU would drastically speed
up render times.
anyones thoughts?
Subject: Re: GPU usage
Date: 31 Dec 2008 14:26:01
Message: <495bc749$1@news.povray.org>
> up render times.
> anyones thoughts?
This comes up about once a month. The practical answer is, "No, not
really, since GPUs are optimized for the type of math that is used by
scanline systems, not physics based raytracing, and their floating point
systems are almost always using lower bit depth than the CPU of the same
machine, so nearly everything POVRay does would fall in the category of,
"Nope, the GPU can't do that, or if it did, it would produce results
that are poorer than the FPU of the main processor."
Now, if you didn't mind getting "poorer" quality, and the *slight* speed
increase you might get from it was worth it... maybe. But, unless its
enough to give you real time, its not worth the effort, since the only
reason you might want to downgrade the results, to get better
performance, is as a game engine. And actually, I kind of wish you could
do that. I am getting seriously tired of things like the layers alpha BS
in Second Life, which a raytracer would never have in the first place. lol
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 31 Dec 2008 18:50:00
Message: <web.495c0405dc9638ab30acaf600@news.povray.org>
> up render times.
There has already been some mention in the FAQ.
The first question will be: Does OpenCL support double-precision floats? If not,
then forget it, because that's the precision POV needs. I wouldn't be surprised
if games could do fine with single-precision.
The next question would be: How to distribute the workload? Just running another
POV render thread in the GPU will hardly work.
I guess it wouldn't be worth the pain. With SSE2, the compiler will help you to
make some use of it. With OpenCL, the compiler probably cannot, so a lot of
manual changes to the code would be needed, and designing them for portability
(so that the program can still run on non-OpenCL systems) could be quite a
problem.
Date: 31 Dec 2008 20:40:01
Message: <web.495c1e4cdc9638ab37f671630@news.povray.org>
> > up render times.
> problem.
Thank you for the input.  All of it makes sense.  From my knowledge, most
current GPU's do support double precision floats, however, not nearly at the
speed as single precision, as there isn't the need in graphics today.
I know some cards to exist that are designed more for math / calcuations and not
graphics, but i do not know much about those workstation cards, and/or what all
they do support.
Thanks again for the quick input!  It answered my curiosity of the day.
-Mark
Date: 1 Jan 2009 19:21:43
Message: <495d5e16@news.povray.org>
Modern GPUs are very programmable; they aren't tied to scanline rendering
anymore. Ever heard of protein folding on GPUs?
Raytracing *can* be done in GPUs.
See http://www.clockworkcoders.com/oglsl/rt/
However it would be a HUGE amount of work to modify POV-Ray to run on CUDA /
OpenCL. Lots of algorithms would need to be rewritten from scratch, and a
few may be impossible.
Date: 1 Jan 2009 21:10:00
Message: <web.495d76d8dc9638ab180057960@news.povray.org>
This is a very interesting summary for one such "GPU raytracer" project:
http://www.ce.chalmers.se/edu/proj/raygpu/index.php?view=projects
In particular:
"So far we have not been able to acquire rendering times that compete with
established ray tracers like mental ray but then again this has never been the
objective of this thesis. Writing fast ray tracers with the help of graphics
hardware is something that we believe is definitely possible though. A good
idea is probably to use the graphics card only for some parts of the rendering
like for example intersection tests and shading and letting the CPU take care
of the traversal of data structures and such."
I thought running it through a GPU would automatically yield even a naive
raytracer an immense boost in performance.  But then, not even MentalRay nor
VRay seem much interested in running on GPU either.
Date: 7 Jan 2009 03:50:49
Message: <5412C33CFC874C64AD0AFF80C11C2654@HomePC>
(Sorry it took me so long to respond, our internet connection was down
for a while).
While the OpenCL spec is very exciting for the GPGPU effort, it will not
help renderers such as POV-Ray.  Ultimately, they still come down to a
SIMD design: specify one instruction (or one set of instructions), and
run it on multiple sets of data.
In practice, this means that anything with a high degree of branching
(ie POV-Ray) won't benefit nearly as much.
Of course, the new GPUs are more capable than ever, and they do offer
double precision floating point, so it may at one point be possible for
limited aspects of the renderer.  However, bear in mind that even
something as inherently SIMD as video encoding, using a high end GPU
from NVidia (the GeForce 260) was actually *slower* than a stock Core 2
Duo from Intel (1).  Something with as much branching as POV-Ray will
perform even worse.
So, there's new hope for the future, but it's still a *distant* future.
(1)
http://xtreview.com/addcomment-id-6872-view-CUDA-video-performance-using
-TMPGEnc-4.0-Xpress.html
...Ben Chambers
www.pacificwebguy.com
The plural of anecdote is not data  --Elbows
Date: 3 Mar 2009 02:29:04
Message: <49acdc40$1@news.povray.org>
For what I have read about it, GPUs are great for geometry and some
other graphic related calculations, because they have more sophisticated
  hardwired, say trigonometric, functions that the FPU simply doesn't
have, this leads me to ask the experienced programmers here if how huge
would be to make a rough "previewer", real-time if possibile, for
POV-Ray? Correct me if I'm wrong but at some point that effort has to be
easy because the GPU have this scene elements analog to POV-Ray's
(lightning, primitives, colors, phong, diffuse, etc.), why is so hard to
use resemblance in features to POV-Ray's favor? I know... is only 32-bit
precision, is not 100% compatible, POV-Rays is Hyper-complex and
wealthy-rich in features but, somehow can't the to GPU along with the
FPU & CPU can't get to cut a deal that can give u an estimate of what
you'll receive if the scene is rendered?
  I really whish I could answer this myself...maybe a como of GPU
features can give some of the most complex POV-Ray's features? maybe a
rough rough preview, something that can "guess"(fast calculations with
GPU+FPU+CPU) to get just an estimation of the final colors and effects
on the objects, and mainly this could be used to preview the modeled
geometry of solids and surfaces and the lighting on the scene, rather
than actually have a correct colored accurate scene, don't you think?
Another suggestion, what about this:
a small floating window (maybe 512*384 or 384*288) with the title "rough
preview" that makes the GPU+FPU+CPU preview of the scene as ral-time as
possible "while you type" or when you have finished a valid line, this
could be configurable, but I think would be great as a default.
This ideas is so incompatible with reality? I hope not, you tell me :)
Regards.
Date: 3 Mar 2009 02:44:19
Message: <49acdfd3@news.povray.org>
In the spirit of co-processing (GPU+FPU+CPU) I would like to suggest
that if isn't too much of a trouble, would be great if POV-Ray could
have a GPU+CPU(CPU included) Identifier (GPU-Z, CPU-Z,etc) to use
available processing hardware resources to render, *of course* GPU
helping whenever it can keep with POV-Ray's quality specs and/or "rough
preview". Makes sense?
Date: 3 Mar 2009 07:25:00
Message: <web.49ad2031dc9638abbdc576310@news.povray.org>
Saul Luizaga <sau### [at] netscapenet> wrote:
(<GPU preview>)
Interesting idea. Would be a lot of work to implement though, I guess.
Great idea, but what if your scene file takes 15 minutes to (re-)parse because
of heavy macro usage? And what if you are working on SDL code designed to write
to files (radiosity samples, photons, or just plain #write output)? I wouldn't
want POV to just start running *such* SDL code while it isn't "ready to rock"
yet.
(Or what if all the changes you want to do is just a few #defines that govern
whether your SDL file *does* #write or instead #read some stuff, in order to
switch from #write to #read mode... don't even want to think about it. Argh!)
No, I think the idea is intriguing, but prohibitive due to the power of POV's
SDL language.
