zeroin23 wrote:
> "nemesis" <nam### [at] gmail com> wrote:
>> Fa3ien <fab### [at] yourshoes skynet be> wrote:
>>> Will the new Open Source status automagically attract people ?
>> I don't think so. Blender's standard raytracer is yafray, who is maintained
>> mostly by one guy alone...
>> face it, guys: it's not like the average Joe VB will make wonders in
>> implementing hardcore math algorithms... projects like this or optimizing
>> compilers will always only get a handful of souls knowledgeable enough to
>> contribute any significant bits...
> in terms of human resource management, the best programmer typically can output
> more usable lines of code with less bugs then the good programmer (the
> differences are exponential)
I partly disagree, the best programmers solve the same problem in
*fewer* lines of code with less bugs per line.
Maybe. You can't work on what you can't see :)
Tom
> Tom
Well, the source code is already available, so there's nothing stopping them
from seeing it except for snobbishness on their part (for refusing to touch
free software that isn't GPL).
....Chambers
> them from seeing it except for snobbishness on their part
It isn't always necessarilly snobbishness - it's wanting to protect
themselves from being accused of introducing non-GPL'ed code into GPL'ed
products.
For example, I know a few Linux kernel developers (not well, mind you,
but I've talked about a few things with them) and they won't even look at
the VMware networking drivers (for vmnet and vmmon) because the code is
not GPL. If they created something that behaved somewhat similar in some
way to either of these modules, they could be accused of injecting code
not released under the GPL into the kernel.
Which is kinda what SCO was going on about, BTW - so it's not like it's a
theoretical threat; false accusations cost time and money to refute as
well, after all.
Jim
>> Tom
Actually, there is a reason that's stopping them. 3.6.1 source code is
available. 3.7 changed lots of structure. It may be a waste of time to
edit 3.6.1 code if you'll have to re-adapt to 3.7, which may not be easy.
> >> Tom
exactly. 3.6 code is still largely C with classes and from a few hints from the
developers, it seems the 3.7 codebase is now largely full C++ with proper use of
classes and namespaces. A very good thing, indeed. Unfortunately, no source
for 3.7 yet available for now, AFAIK.
Not "full" (as it still has quite a lot of C-style code, including
tons of preprocessor macros etc), but closer.
As long as there are no goto's :D
There seems to be 16 of those.
> >> Tom
Yes, that's what I was getting at, but too indirectly. I've added things to
3.6.1 (well, MegaPOV) but there's no point going on with that when 3.7 will
change things. Plus it's a bit depressing now to add a feature and see only one
core out of the four doing the rendering, vs. 3.7 (the beta).
Tom
