POV-Ray : Newsgroups : povray.off-topic : Land of Lisp Server Time
12 Mar 2026 08:34:35 EDT (-0400)
  Land of Lisp (Message 13 to 22 of 22)
Subject: Re: Land of Lisp
Date: 2 Nov 2010 13:15:00
Message: <web.4cd046952bc10e38b282d9920@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> On 02/11/2010 02:00 AM, nemesis wrote:
> > Invisible<voi### [at] devnull>  wrote:
> >> Is it possible to create variables with local rather than global scope?
> > you're kidding me, right?
> Well, I've never seen anybody do it before, that's all.
no, you've never seen before, period.  Even previous examples I posted.  If
you'd had any curiosity on the subject, I'm sure plenty of examples abound in
places like projecteuler or language shootout.
> If you want a point, you say Point 3 7. Which, as you say, rather gives
> away the fact that it's a Point value. But how about saying "True"?
> That's of type Bool, but you didn't write that in your expression.
> Similarly, when you write
>    Branch (Leaf 3) (Leaf 7)
> you didn't say anywhere that this is of type Tree Int, did you? The
> compiler infers this automatically.
it infers from unique names relating to a type like those sprinkled everywhere
in the code.  Think about it... :)
> And don't even get me started on
> expressions which are polymorphic, and could have /several/ possible types.
expressions are polymorphic by default in dynamically-typed languages. :)
(define (foo bar) (boz (boz bar)))
(define (boz bar) (+ bar bar))
an implementation could infer foo ultimately works on numbers because boz calls
+.  But + could be redefined as
(define +
  (let ((o+ +))
    (lambda args
      (cond
        ((null? args) 0)
        ((number? (car args)) (apply o+ args))
        ((string? (car args)) (apply string-append args))))))
and thus foo works on numbers, strings and what more gets into the redefinition
of +.
or at least it could in scheme a few iterations ago.  Today implementations say
+ can't be redefined... :p
> > I'm talking ill of Hindley-Milner type system, but you should be aware that the
> > same lameness can happen in Lisps too:  here and now you will see things like
> > fl* fx+ or fl<... that is, functions to operate on specific numeric types.
> > Again, they exchange a single type declaration for type-specific operators
> > everywhere.  Makes me wonder if the Algol folks got it right...
> Not so in Haskell. If you want to add two numbers, you use (+). It's
> polymorphic like that.
yes, + in Lisp is polymorphic over numbers, be it float or integer.  fl+ or fx+
are performance-geared optimizations.
I still think simple declaration of a variable as of a given type would be
better than sprinkling code with operators/names that force expressions into a
given type.
> I'm actually surprised that a dynamically-typed language would do
> something like that. I thought the whole point of dynamic typing was
> that you can completely ignore types.
you can, except when you want performance.
> All I know is that every time I've used a dynamically-typed language,
> I've spent 90% of my time fixing type errors - errors which *could* have
> and *should* have been caught automatically by the machine, but I have
> ended up catching them myself, by hand. Yuck!
only you could do that in a language "without types" :p
I don't have a trouble providing arguments of the right types to functions, but
I must confess I've been flamed already by typos in the code only detected at
runtime. :p
Thankfully, the real nice thing about development with a REPL is that you can do
fine-grained iterative development:  write little expressions, test them, put
them into a function, repeat.   You write and test at the same time.  shame that
haskell's REPL is very limited and doesn't allow for full type definitions and
such.
> > I suspect its homoiconic nature has lots to do with it.  Plus, if you've never
> > edited Lisp code with hierarchical parenthetical editing you don't know what a
> > bless it is compared to any other language in existence.
> More like "without automatic bracket match, it's impossible to produce
> code which is even syntactically correct". It wouldn't be so bad, but it
> seems all Lisp programmers habitually indent their code incorrectly.
Lisp n00bs usually indent their code incorrectly, specially those who actually
care about the parentheses and treat them like brackets in C languages, even
going as far as matching open and close in the same indented column.  Lisp
experts have long developed a code style that makes brackets virtually invisible
by hiding them to the rightmost end.
BTW, the expressions above I typed here, but copied them to a scheme buffer to
test them.  You can do marvels by merely typing () in sequence and going in
between them next.
> I can see how having a language where everything is a list is
> technically quite a nice idea. It's simple and elegant. Unfortunately,
> the language as a whole seems to be messy and inconsistent. Too much
> backwards compatibility, too much muddled thinking. Still, I guess it
> was the first attempt...
There is quite a lot of backwards compatibility in CL, that's for sure:  it was
designed by a comittee to comply with several older lisp dialects, so they
basically just made a big union of features.  Not so much with scheme.
I'm specially annoyed at the car/cdr family of operators so dear to old Lispers.
 Those were the names of two macro-assembler instructions in the first machine
Lisp was implemented in.  They are truly lame legacy misnomers for head/tail...
I discussed a bit about them here to some strong reactions from old farts:
http://groups.google.com.br/group/comp.lang.lisp/browse_thread/thread/16135e3a09d5f6f3#
> > It's because you still don't know it well.
> Sure, functions are first-class. But it lacks purity.
like I said, aside from Haskell, no other language goes that far to ensure a
pure, side-effect-free mystical environment.  Including others from functional
programming land, like scheme or ML.
this is side-effect free:
(let fact ((n 25) (r 1)) (if (< n 2) r (fact (- n 1) (* n r))))
even though implementations so far don't go as far as detecting its purity to
allow for fine-grained paralellism.
(BTW, once again written in the browser)
> It also doesn't
> appear to place any emphasis at all on coding in a vaguely functional
> style - not in the language design nor the standard libraries.
if you're talking about Common Lisp you're right:  it's a very imperative
version of Lisp.  Scheme was in part developed in the 70's as a functional
rework of the original Lisp principles.
> No, a design that enforces purity has profound consequences for any
> implementation of that design. (Not to mention the entire way that the
> language is used.)
true.  But whenever I want all pure and white design I know where I can find
haskell... ;)
> And Clean doesn't count because...?
because it is even more obscure than haskell itself?
> To me, "new syntax" means that I can write something that doesn't look
> like the host language. From what little I've seen, a Lisp DSL just
> looks like Lisp.
true.  We actually consider that a benefit. ;)
> And a Haskell expression consists of some combination of exactly 6 (go
> count them) structures.
nobody codes haskell without such sugar just as nobody codes scheme like
((lambda (fact) (fact fact 5))
 (lambda (fact n) (if (< n 2) 1 (* n (fact fact (- n 1))))))
(once again written here)
> The rest is just sugar. That's peanuts compared
> to (say) the number of possible statements in Java. (For-loops,
> while-loops, if-then-else, return, switch/break...)
that's for sure is a gain of all functional programming languages:  creating
larger things from the composition of a few core functions.
> > (iterate (pf * 2) 0)
> Yes, that's just as succinct as (*2). Oh, wait...
it is as succint as you can get without having to alter the parser to allow for
special syntax and corner cases here and there.  Simpler design. :)
Date: 2 Nov 2010 14:39:45
Message: <4cd05af1@news.povray.org>
For monomorphic expressions, sure. You do tend to end up sprinkling
these things around. But that's really no different to (say) Java having
"new Foo()", "new Bar()" etc sprinkled everywhere. [Except that you
don't have to uselessly duplicate it in the variable declarations as well!]
The polymorphic code, the stuff that works for any type, is mostly
devoid of this kind of stuff.
Now, see, in Haskell you'd just write a type signature that fixes the
expression to one specific type, and the compiler does the rest.
Typically you only need to fix it in one place too.
> given type.
And I still think it requires a lot less "sprinkling" than you seem to
think.
Oh, it *has* types, it's just that it only checks them when it's about
to use them. Which means that a tiny number of programs are accepted
that might otherwise be rejected, and a vast number of programs are
accepted that crash as soon as you run them - or worse...
> runtime. :p
And this is significantly easier with pure code. :-P
> Shame that
> such.
Now that _is_ a shame. It seems such a pointless and arbitrary
limitation, IMHO.
> Lisp
...which is worrying, given that the brackets are fundamental to the
language syntax, and moving them around slightly radically transforms
the entire meaning of an expression.
I dislike backwards compatibility. Even Haskell has too much of that.
Yes, that's specifically the single most annoying part I came across. I
imagine entire flamewars have been fought over that one...
IMHO, this is why Haskell is superior to every other language.
>> It also doesn't
No wonder they hate each other! ;-)
Funny, people seem to have heard of Clean. And OCaml. And Erlang. And
Lisp. And even Prolog. And yet, nobody seems to have ever heard of
Haskell...
>> looks like Lisp.
What, that you can define a new syntax which is identical to the
existing one? Why bother?
> nobody codes haskell without such sugar.
And? I'm talking about the ease with which you can programmatically
construct expressions using Template Haskell. The fact that the entire
language is 6 constructs makes that real easy.
Amen.
...and if you language already supports it, you don't need to alter the
parser. ;-)
http://blog.orphi.me.uk/
Date: 2 Nov 2010 15:42:18
Message: <4cd0699a$1@news.povray.org>
> You're not thinking clearly, then.
Right. Sure.
> The only time I get type problems is I'll occasionally mix up something
> like a list of list of X with a list of X, but that bombs out the first
> time you run it if the type system isn't absurdly forgiving, so it's not
> really any more of a problem than it getting caught the first time you
> compile it.
Unless, of course, the problem is on a rarely-executed code path. Like,
you make the same mistake a few times, and all the commonly-used code
paths get fixed, but there's one slightly rare path that you
accidentally miss.
The other thing, of course, is that you can't *change* part of the code
and then just follow the type errors to find all the parts that need
updating. You have to manually do several million test runs and hope you
hit everything.
Don't get me wrong, I can do it. (See my crazy JavaScript stuff, for
example.) It's just drastically harder than it should be.
> You're aware that C# has (or will have, depending how strict you want to
> be) the equivalent of eval, right? As does Java, in some sense?
You're aware that C# and Java are interpretted languages, right? ;-) (In
the case of C#, it's not even possible to install the runtime without
installing the compiler too...)
Date: 2 Nov 2010 18:46:26
Message: <4cd094c2$1@news.povray.org>
> accidentally miss.
So you're writing code that you never tested? That's not something a
compiler will help with.
> hit everything.
This is true. But not what you were talking about.
I'm not saying dynamic languages are superior. I'm simply saying that when
you're used to using dynamic languages, the "you got the wrong type" is
really a rare problem.
No they're not.  No more than the ability to load a DLL means that C is an
interpreted language.
Plus, look up "C# aot compiler" and rejoice in the glory of it. For example,
http://msdn.microsoft.com/en-us/library/6t9t5wcf%28VS.80%29.aspx
or http://tirania.org/blog/archive/2006/Aug-17.html
Nor is that true. What are you smoking over there?  Can I have some?
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 2 Nov 2010 19:20:00
Message: <web.4cd09c1c2bc10e38b282d9920@news.povray.org>
> > accidentally miss.
> > hit everything.
thanks, I wouldn't say any better...
must be the lady.  They can turn bright men into imbeciles. :)
Date: 3 Nov 2010 05:18:39
Message: <4cd128ef$1@news.povray.org>
>> Like, you make the same mistake a few times, and all the commonly-used
>> code paths get fixed, but there's one slightly rare path that you
>> accidentally miss.
I take it you haven't heard the expression "if it compiles, it usually
works correctly" then?
Obviously no compiler is ever going to eliminate the need for testing
completely. But it can drastically reduce the amount of time you have to
spend hunting for silly typos.
>> code and then just follow the type errors to find all the parts that
>> need updating. You have to manually do several million test runs and
>> hope you hit everything.
Isn't it?
> when you're used to using dynamic languages, the "you got the wrong
> type" is really a rare problem.
I've always preferred statically-typed languages. They catch so much
more of the type of bugs I tend to write. With an inflexible type system
like Java, I can understand people being exasperated by it and wanting
to use a dynamically-typed language instead. But really, the benefits of
static typing vastly outweigh the drawbacks.
> an interpreted language.
Right. And the fact that it runs on top of a VM doesn't count because...?
Uhuh. And so when you install the .NET "runtime", and it spends 45
minutes running "ngen.exe", "native code generator", that doesn't count
as "running the compiler" because...?
Date: 3 Nov 2010 09:49:18
Message: <4cd1685e$1@news.povray.org>
Not a VM at all. CLR IL is compiled on-the-fly as its encountered. This
creates a few initial delays, but once everything has been jitted, it's
every bit as native as C. Actually, if you step through a CLR app in a
debugger and switch over to the disassembly, everything is in x86
machine code by that point.
I believe you can turn that off, but it slows application start-up for
.NET apps.
~Mike
Date: 3 Nov 2010 11:17:25
Message: <4cd17d05$1@news.povray.org>
That happens with me,b ut that's because I have 30 years experience.
As I say, I almost never have that sort of typo.
I'm not disagreeing.
Because the VM compiles them to machine code before it runs, and the VM it
runs on top of is statically typed, strongly checked, and not unlike a CPU
in architecture.
It's translating CIL into machine code for your specific machine. It's
basically pre-JITting your libraries.
I'm not sure how you can decide that NGEN is a compiler, then tell me that
C# isn't compiled because it runs on top of a VM.
   Serving Suggestion:
Date: 29 Nov 2010 10:12:06
Message: <4cf3c2c6@news.povray.org>
The entire Whirl language consists of 2 instructions. That doesn't make it
simple or easy.
Date: 29 Nov 2010 10:44:33
Message: <4cf3ca61$1@news.povray.org>
> simple or easy.
It does if you're interested in how easily a machine can write it, not
how easily a human can write it.
