POV-Ray : Newsgroups : povray.off-topic : Land of Lisp Server Time
18 Mar 2026 21:15:03 EDT (-0400)
  Land of Lisp (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Land of Lisp
Date: 2 Nov 2010 06:24:41
Message: <4ccfe6e9$1@news.povray.org>
On 02/11/2010 02:00 AM, nemesis wrote:
> Invisible<voi### [at] devnull>  wrote:
>> Is it possible to create variables with local rather than global scope?
> you're kidding me, right?
Well, I've never seen anybody do it before, that's all.
>> When you get to Haskell, of course, automatic type inference blows #1
>> out of the water
> yeah, except when it can't decide on the types all by itself and requests type
> annotations anyway.
Which is fairly rare.
In truth, you're probably going to put annotations on all your top-level
stuff anyway, for documentation's sake. What automatic type inference
means is that you don't have to dot type annotations absolutely
everywhere you go (and change them all over the place when something
changes), just in the few places you need them.
> I would also say the Hindley-Milner kinda cheats in this regard.  You usually
> don't have to type annotate whenever the function operates on numbers, strings
> or Algebraic Data Types.  And Algebraic Datatypes are a dead on giveaway of the
> type of an expression, because it usually have a name of its own to describe
> values of its type.  So, a function like:
> withBuf run = run . Buf 0 ini =<<  mallocBytes ini
>    where ini = 1024
> needs no type annotation because it already has a friggin reference there to
> type:
> data Buf = Buf !Int !Int !(Ptr Word8)
> so, you exchange type annotations everywhere for type names for values of this
> type in the expressions.  Not that much of a fair trade:  instead of providing a
> single type declaration, you provide it everywhere you use it.
I wouldn't agree with that.
If you want a point, you say Point 3 7. Which, as you say, rather gives
away the fact that it's a Point value. But how about saying "True"?
That's of type Bool, but you didn't write that in your expression.
Similarly, when you write
   Branch (Leaf 3) (Leaf 7)
you didn't say anywhere that this is of type Tree Int, did you? The
compiler infers this automatically. And don't even get me started on
expressions which are polymorphic, and could have /several/ possible types.
> I'm talking ill of Hindley-Milner type system, but you should be aware that the
> same lameness can happen in Lisps too:  here and now you will see things like
> fl* fx+ or fl<... that is, functions to operate on specific numeric types.
> Again, they exchange a single type declaration for type-specific operators
> everywhere.  Makes me wonder if the Algol folks got it right...
Not so in Haskell. If you want to add two numbers, you use (+). It's
polymorphic like that. And functions that use it end up being
polymorphic too (unless you specifically don't want them to be, usually
for performance reasons).
I'm actually surprised that a dynamically-typed language would do
something like that. I thought the whole point of dynamic typing was
that you can completely ignore types.
(Haskell also has the nice trick of numeric literals being polymorphic.
Sadly, the same does not hold for lists or strings...)
>> Really, in the modern age, there is no reason for dynamically-typed
>> languages to exist at all. It just invites bugs.
> Dynamically typed languages are just perfect for quick prototyping of systems
> where invariants are still not well known.  The fact that some of them can not
> just quickly prototype working systems, but prototype them with good performance
> is only a plus.
All I know is that every time I've used a dynamically-typed language,
I've spent 90% of my time fixing type errors - errors which *could* have
and *should* have been caught automatically by the machine, but I have
ended up catching them myself, by hand. Yuck!
>> "Why is Lisp the best?"
>> "Because it has macros!"
> I almost never use macros and still find Lisp the best. :)
I just don't get what's to like about it. It seems messy and ad hoc to me.
> I suspect its homoiconic nature has lots to do with it.  Plus, if you've never
> edited Lisp code with hierarchical parenthetical editing you don't know what a
> bless it is compared to any other language in existence.
More like "without automatic bracket match, it's impossible to produce
code which is even syntactically correct". It wouldn't be so bad, but it
seems all Lisp programmers habitually indent their code incorrectly.
I can see how having a language where everything is a list is
technically quite a nice idea. It's simple and elegant. Unfortunately,
the language as a whole seems to be messy and inconsistent. Too much
backwards compatibility, too much muddled thinking. Still, I guess it
was the first attempt...
> you don't need to type brackets with a proper Lisp editor such as emacs or
> DrRacket.  You usually just type alt+shift+( and it opens a pair and puts you
> right in.  You can select a big code section spanning several lines by just
> alt+shift+(right or left).
In other words "Lisp is so hard to write that you need a special program
to help you do it". (The same accusation could be levelled at XML of
course...)
>> I still don't think Lisp is very functional. :-P
> It's because you still don't know it well.
Sure, functions are first-class. But it lacks purity. It also doesn't
appear to place any emphasis at all on coding in a vaguely functional
style - not in the language design nor the standard libraries.
>> Depends on what you consider to be "functional programming". There are
>> really two separate characteristics that most FP languages have:
>> 1. Pure functions.
>> 2. Functions as first-class objects.
>> Any programming language that supports functions can support writing
>> pure functions. But as far as I can tell, Lisp does not in any way
>> encourage or facilitate doing so. Heck, C++ has facilities for marking
>> things that won't be altered after being initialised, whereas Lisp does
>> not. That makes C++ slightly more FP than Lisp.
> That's purely an implementation detail, not a language feature. Pure math-like
> functions with no side-effects only depend on you writing side-effect-free code.
No, a design that enforces purity has profound consequences for any
implementation of that design. (Not to mention the entire way that the
language is used.)
> Would you really call C++ more FP than ML because nothing in the language spec
> say "hey, this section is pure, you can optimize it away for concurrency"?
Who said anything about ML? I just said C++ seems more functional than Lisp.
> BTW, Haskell is the only such (well-known) language enforcing purity even for
> IO.
And Clean doesn't count because...?
>> You complain about "operator obfuscation" and then tout "custom syntax"
>> as improving readability. Which is it? :-P
> new syntax doesn't mean&*%#$.  macros have as much self-describing names as
> functions.
To me, "new syntax" means that I can write something that doesn't look
like the host language. From what little I've seen, a Lisp DSL just
looks like Lisp.
>> Since Lisp explicitly permits self-modifying code, wouldn't that mean
>> that the compiler has to be present at run-time?
> You got that "self-modifying code" all messed up.  Lisp macros can operate on
> Lisp code to produce new custom code, but that happens at compile-time.
> If you really want it, you have eval at runtime, but it's as slow as everywhere
> else.
As I say, it's news to me that Lisp can be compiled. I thought the fact
that you have an eval function more or less prevents this. Every other
language I've ever seen that has an eval function has been interpreted.
>>>> And, unlike Lisp
>>>> macros (AFAIK), Template Haskell statically guarantees that the code
>>>> written by a template is *always* syntactically correct. (It does _not_
>>>> guarantee that it is well-typed, just that there are no syntax errors.)
>>> that's good for a language heavy on syntax.
>> I won't claim to be a Lisp expert, but I was under the impression that
>> not every possible list is a valid executable Lisp expression.
> I mean there not much syntax in Lisp besides brackets, an expression evaluating
> to a function (or macro) at the head and arguments for that function (or macro)
> in the rest of that list.
And a Haskell expression consists of some combination of exactly 6 (go
count them) structures. The rest is just sugar. That's peanuts compared
to (say) the number of possible statements in Java. (For-loops,
while-loops, if-then-else, return, switch/break...)
>>    From what I can tell, Lisp macros work by you passing some data to
>> them, which they then transform into some sort of executable code.
>> Template Haskell allows you to inspect parts of the current module not
>> passed in as arguments. So you can, e.g., look up the definition of a
>> user-defined data structure.
> that sounds as painfully side-effectful as when I first heard it.  Hence Ninja
> Patching.  google it up...
So, what, I can tell the compiler to import some extra modules that I'm
about to reference, and I can look at the definition of a user-defined
data type and generate some boilerplate code to work on it? Yes, sounds
terrible.
Or perhaps you meant that people could abuse it? Well, yes, obviously
any powerful feature can be abused. So what?
>>> BTW, you know quasi-quoting comes from Lisp, don't you?  `(let ((r ,(fact 5)))
>>> r) will turn into (let ((r 120)) r) at compile-time... it's so friggin' easy
>>> it's used a lot.
>> I must be missing something... those two expressions look almost
>> identical to me.
> yeah, you're missing that you write the first and the compiler turns it into the
> second, at compile time:  yes, it evaluates (fact 5) during compilation.  It
> would certainly not do any magic and evaluate (fact n) if n was not known at
> compile time, but since it's a literal...
Oh, right, I hadn't noticed that fact 5 had vanished.
Now a Haskell compiler /might/ evaluate that at compile-time without any
special hints. You know why? IT CAN'T HAVE SIDE EFFECTS. :-P
Anyway, with Template Haskell, I can merely write
   $(let x = factorial 5 in [| x |])
to achieve the same effect. Not exactly intractably complex, eh?
>>> you're taking a comic book too seriously...
>> Perhaps. Maybe I'm just tired of Lisp fanboys claiming that this one
>> single language is some kind of perfect Utopia.
> now, there are not that many Lisp fanboys out there, there are?  Most I know are
> more like Lisp fanoldmen...
> Scheme doesn't have many fanboys either, more like irate compsci freshmen...
Whatever. I try not to make wild claims like "Haskell is perfect". I
think it's a fantastic language, but I know for a fact that it's not
perfect.
>>> nah, inc is 1 char shorter. ;)
>> And (+1) is more descriptive.
> not in Lisp where it looks like a silly function application... :p
It does what it says on the tin.
>> Also, I can soon change that to "iterate (*2) 1" to generate a geometric
>> sequence instead. I bet Lisp doesn't have a predefined "multiply by 2"
>> function. :-P
> we could have something like:
> (define (pf op x) (lambda (n) (op n x)))
> (iterate (pf * 2) 0)
Yes, that's just as succinct as (*2). Oh, wait...
>> Actually, just the other day I was trying to pin down in my head exactly
>> which sorts of programs Haskell is good for and bad for.
> math problems and formal proof automation would be my guess for best suited.
> Real world is more complicated.  say a script to automate a task.  You don't
> really need all that type theory to get it done...
You don't really need "all that type theory" to understand or use
Haskell. :-P
Anyway, the basic answer seems to be programs where getting the right
answer is more important than getting it fast, or where figuring out how
to solve the problem at all is really complex and you need all the help
you can get...
Date: 2 Nov 2010 13:13:24
Message: <4cd046b4@news.povray.org>
You're not thinking clearly, then.  Type errors in a dynamically typed
language are not something that crop up a lot for people who use such
languages frequently. It takes a little getting used to to remember what
types variables are while you're writing a function, but how hard can that be?
Now, if you use a lot of crappy undocumented libraries, sure, that can be
problematic. But that's true in any language.
The only time I get type problems is I'll occasionally mix up something like
a list of list of X with a list of X, but that bombs out the first time you
run it if the type system isn't absurdly forgiving, so it's not really any
more of a problem than it getting caught the first time you compile it.
(Of course, if your IDE catches such things before you've even finished
typing the body of the function, it's nice.)
 > From what little I've seen, a Lisp DSL just looks like Lisp.
That's because the people writing and using the DSLs are comfortable with
LISP. LISP had read macros, so they can look like anything you want.
 > Every other language I've ever seen that has an eval function has been
interpreted.
The *eval* call has to be interpreted, sure. But if you don't use eval,
everything is compiled. If you do use eval, everything but the eval is compiled.
You're aware that C# has (or will have, depending how strict you want to be)
the equivalent of eval, right?  As does Java, in some sense?
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 2 Nov 2010 13:15:00
Message: <web.4cd046952bc10e38b282d9920@news.povray.org>
no, you've never seen before, period.  Even previous examples I posted.  If
you'd had any curiosity on the subject, I'm sure plenty of examples abound in
places like projecteuler or language shootout.
it infers from unique names relating to a type like those sprinkled everywhere
in the code.  Think about it... :)
expressions are polymorphic by default in dynamically-typed languages. :)
(define (foo bar) (boz (boz bar)))
(define (boz bar) (+ bar bar))
an implementation could infer foo ultimately works on numbers because boz calls
+.  But + could be redefined as
(define +
  (let ((o+ +))
    (lambda args
      (cond
        ((null? args) 0)
        ((number? (car args)) (apply o+ args))
        ((string? (car args)) (apply string-append args))))))
and thus foo works on numbers, strings and what more gets into the redefinition
of +.
or at least it could in scheme a few iterations ago.  Today implementations say
+ can't be redefined... :p
yes, + in Lisp is polymorphic over numbers, be it float or integer.  fl+ or fx+
are performance-geared optimizations.
I still think simple declaration of a variable as of a given type would be
better than sprinkling code with operators/names that force expressions into a
given type.
you can, except when you want performance.
only you could do that in a language "without types" :p
I don't have a trouble providing arguments of the right types to functions, but
I must confess I've been flamed already by typos in the code only detected at
runtime. :p
Thankfully, the real nice thing about development with a REPL is that you can do
fine-grained iterative development:  write little expressions, test them, put
them into a function, repeat.   You write and test at the same time.  shame that
haskell's REPL is very limited and doesn't allow for full type definitions and
such.
Lisp n00bs usually indent their code incorrectly, specially those who actually
care about the parentheses and treat them like brackets in C languages, even
going as far as matching open and close in the same indented column.  Lisp
experts have long developed a code style that makes brackets virtually invisible
by hiding them to the rightmost end.
BTW, the expressions above I typed here, but copied them to a scheme buffer to
test them.  You can do marvels by merely typing () in sequence and going in
between them next.
There is quite a lot of backwards compatibility in CL, that's for sure:  it was
designed by a comittee to comply with several older lisp dialects, so they
basically just made a big union of features.  Not so much with scheme.
I'm specially annoyed at the car/cdr family of operators so dear to old Lispers.
 Those were the names of two macro-assembler instructions in the first machine
Lisp was implemented in.  They are truly lame legacy misnomers for head/tail...
I discussed a bit about them here to some strong reactions from old farts:
http://groups.google.com.br/group/comp.lang.lisp/browse_thread/thread/16135e3a09d5f6f3#
like I said, aside from Haskell, no other language goes that far to ensure a
pure, side-effect-free mystical environment.  Including others from functional
programming land, like scheme or ML.
this is side-effect free:
(let fact ((n 25) (r 1)) (if (< n 2) r (fact (- n 1) (* n r))))
even though implementations so far don't go as far as detecting its purity to
allow for fine-grained paralellism.
(BTW, once again written in the browser)
> It also doesn't
if you're talking about Common Lisp you're right:  it's a very imperative
version of Lisp.  Scheme was in part developed in the 70's as a functional
rework of the original Lisp principles.
> language is used.)
true.  But whenever I want all pure and white design I know where I can find
haskell... ;)
because it is even more obscure than haskell itself?
> looks like Lisp.
true.  We actually consider that a benefit. ;)
nobody codes haskell without such sugar just as nobody codes scheme like
((lambda (fact) (fact fact 5))
 (lambda (fact n) (if (< n 2) 1 (* n (fact fact (- n 1))))))
(once again written here)
that's for sure is a gain of all functional programming languages:  creating
larger things from the composition of a few core functions.
it is as succint as you can get without having to alter the parser to allow for
special syntax and corner cases here and there.  Simpler design. :)
Date: 2 Nov 2010 14:39:45
Message: <4cd05af1@news.povray.org>
For monomorphic expressions, sure. You do tend to end up sprinkling
these things around. But that's really no different to (say) Java having
"new Foo()", "new Bar()" etc sprinkled everywhere. [Except that you
don't have to uselessly duplicate it in the variable declarations as well!]
The polymorphic code, the stuff that works for any type, is mostly
devoid of this kind of stuff.
Now, see, in Haskell you'd just write a type signature that fixes the
expression to one specific type, and the compiler does the rest.
Typically you only need to fix it in one place too.
> given type.
And I still think it requires a lot less "sprinkling" than you seem to
think.
Oh, it *has* types, it's just that it only checks them when it's about
to use them. Which means that a tiny number of programs are accepted
that might otherwise be rejected, and a vast number of programs are
accepted that crash as soon as you run them - or worse...
> runtime. :p
And this is significantly easier with pure code. :-P
> Shame that
> such.
Now that _is_ a shame. It seems such a pointless and arbitrary
limitation, IMHO.
> Lisp
...which is worrying, given that the brackets are fundamental to the
language syntax, and moving them around slightly radically transforms
the entire meaning of an expression.
I dislike backwards compatibility. Even Haskell has too much of that.
Yes, that's specifically the single most annoying part I came across. I
imagine entire flamewars have been fought over that one...
IMHO, this is why Haskell is superior to every other language.
>> It also doesn't
No wonder they hate each other! ;-)
Funny, people seem to have heard of Clean. And OCaml. And Erlang. And
Lisp. And even Prolog. And yet, nobody seems to have ever heard of
Haskell...
>> looks like Lisp.
What, that you can define a new syntax which is identical to the
existing one? Why bother?
> nobody codes haskell without such sugar.
And? I'm talking about the ease with which you can programmatically
construct expressions using Template Haskell. The fact that the entire
language is 6 constructs makes that real easy.
Amen.
...and if you language already supports it, you don't need to alter the
parser. ;-)
http://blog.orphi.me.uk/
Date: 2 Nov 2010 15:42:18
Message: <4cd0699a$1@news.povray.org>
Right. Sure.
> like a list of list of X with a list of X, but that bombs out the first
> time you run it if the type system isn't absurdly forgiving, so it's not
> really any more of a problem than it getting caught the first time you
> compile it.
Unless, of course, the problem is on a rarely-executed code path. Like,
you make the same mistake a few times, and all the commonly-used code
paths get fixed, but there's one slightly rare path that you
accidentally miss.
The other thing, of course, is that you can't *change* part of the code
and then just follow the type errors to find all the parts that need
updating. You have to manually do several million test runs and hope you
hit everything.
Don't get me wrong, I can do it. (See my crazy JavaScript stuff, for
example.) It's just drastically harder than it should be.
> be) the equivalent of eval, right? As does Java, in some sense?
You're aware that C# and Java are interpretted languages, right? ;-) (In
the case of C#, it's not even possible to install the runtime without
installing the compiler too...)
Date: 2 Nov 2010 18:46:26
Message: <4cd094c2$1@news.povray.org>
> accidentally miss.
So you're writing code that you never tested? That's not something a
compiler will help with.
> hit everything.
This is true. But not what you were talking about.
I'm not saying dynamic languages are superior. I'm simply saying that when
you're used to using dynamic languages, the "you got the wrong type" is
really a rare problem.
No they're not.  No more than the ability to load a DLL means that C is an
interpreted language.
Plus, look up "C# aot compiler" and rejoice in the glory of it. For example,
http://msdn.microsoft.com/en-us/library/6t9t5wcf%28VS.80%29.aspx
or http://tirania.org/blog/archive/2006/Aug-17.html
Nor is that true. What are you smoking over there?  Can I have some?
   Serving Suggestion:
Date: 2 Nov 2010 19:20:00
Message: <web.4cd09c1c2bc10e38b282d9920@news.povray.org>
> > accidentally miss.
> > hit everything.
thanks, I wouldn't say any better...
must be the lady.  They can turn bright men into imbeciles. :)
Date: 3 Nov 2010 05:18:39
Message: <4cd128ef$1@news.povray.org>
>> Like, you make the same mistake a few times, and all the commonly-used
>> code paths get fixed, but there's one slightly rare path that you
>> accidentally miss.
I take it you haven't heard the expression "if it compiles, it usually
works correctly" then?
Obviously no compiler is ever going to eliminate the need for testing
completely. But it can drastically reduce the amount of time you have to
spend hunting for silly typos.
>> code and then just follow the type errors to find all the parts that
>> need updating. You have to manually do several million test runs and
>> hope you hit everything.
Isn't it?
> when you're used to using dynamic languages, the "you got the wrong
> type" is really a rare problem.
I've always preferred statically-typed languages. They catch so much
more of the type of bugs I tend to write. With an inflexible type system
like Java, I can understand people being exasperated by it and wanting
to use a dynamically-typed language instead. But really, the benefits of
static typing vastly outweigh the drawbacks.
> an interpreted language.
Right. And the fact that it runs on top of a VM doesn't count because...?
Uhuh. And so when you install the .NET "runtime", and it spends 45
minutes running "ngen.exe", "native code generator", that doesn't count
as "running the compiler" because...?
Date: 3 Nov 2010 09:49:18
Message: <4cd1685e$1@news.povray.org>
Not a VM at all. CLR IL is compiled on-the-fly as its encountered. This
creates a few initial delays, but once everything has been jitted, it's
every bit as native as C. Actually, if you step through a CLR app in a
debugger and switch over to the disassembly, everything is in x86
machine code by that point.
I believe you can turn that off, but it slows application start-up for
.NET apps.
~Mike
Date: 3 Nov 2010 11:17:25
Message: <4cd17d05$1@news.povray.org>
That happens with me,b ut that's because I have 30 years experience.
As I say, I almost never have that sort of typo.
I'm not disagreeing.
Because the VM compiles them to machine code before it runs, and the VM it
runs on top of is statically typed, strongly checked, and not unlike a CPU
in architecture.
It's translating CIL into machine code for your specific machine. It's
basically pre-JITting your libraries.
I'm not sure how you can decide that NGEN is a compiler, then tell me that
C# isn't compiled because it runs on top of a VM.
   Serving Suggestion:
