Stephen wrote:
> On 17/05/2010 8:21 PM, andrel wrote:
>> A defibrillator gives a short 'DC'-pulse that stimulates all cells in
>> the heart at once, and resets them. Hopefully the heart will then reboot
>> gracefully
> As a side note I was taught that it was important to remove any metallic
> body jewellery from around the chest area before using a defibrillator.
> Ouch!
> Another point about electrocution is that mains voltage is not always
> and one 800V dc that really woke me up. Insulating footwear is a
> lifesaver. :-D
I was told it was all metal jewelery, but that could also be caused by
the use of electric scalpels and the possibility of ground issues.
That is really not what you want to hear from a surgical nurse or
anesthesiologist, that the hospital might have grounding issues.
Mythbusters tested this one - their result (by no means definitive,
though) was that a burn could happen only if the defibrillator was used
incorrectly.
http://mythbustersresults.com/episode88
Jim
Warp wrote:
> Darren New <dne### [at] san rr com> wrote:
>> Warp wrote:
>>> clipka <ano### [at] anonymous org> wrote:
>>>> Note that the probability that you're making contact with the cattle
>>>> wire at the very moment that a pulse has just started is /very/ low.
>>> You make it sound like touching the fence is about the same as touching
>>> a 1.5-volt battery poles. Wouldn't that kind of defeat the whole purpose?
>> The farmer doesn't want to kill the cow. He wants to tingle the cow enough
>> that the cow learns not to lean against the fence.
> Hence 1.5 volts isn't going to do it.
Yes, but a very brief high spike, which is what you were responding to,
*will* do it if the cow is pressing against the fence for several seconds.
He didn't say 1.5 volts. *You* said 1. volts. He said very short pulses.
Ada - the programming language trying to avoid
you literally shooting yourself in the foot.
On 05/17/10 06:13, Warp wrote:
> Invisible <voi### [at] dev null> wrote:
>> It's current that kills you, not potential difference or anything else.
> No, it's not the current that kills you. It's the power transfer.
> You yourself said it: Even if the current is tens of kilovolts, it may
> still not kill you.
Yes, but a voltage supply in the kiloamps range just may...
A man attempting to walk around the world DROWNED today...
be removed on admission. A burn from a necklace while painful and
unsightly is a talking point in at the bar. But a burn on the delicate
tissue people are piercing nowadays could be a little more painful.
Best Regards,
> incorrectly.
It is not unknown, you know. Especially in the field.
> Jim
Best Regards,
And lo On Mon, 17 May 2010 13:46:29 +0100, Warp <war### [at] tag povray org> did
spake thusly:
> Aydan <hes### [at] hendrik-sachse net> wrote:
>> When you put the glass over the candle, the air inside the glass will
>> be warmer
>> than the environment. When the candle has used up all the oxygen, the
>> air will
>> cool down and the inside pressure sinks, sucking in the water from the
>> outside.
> Yeah. You wouldn't believe how convoluted explanations I have seen.
Just to act on the dumb side. If you use a graduated beaker with a candle
in it, add the water, and the second beaker, and then measure the water
height. Shouldn't the increase in temperature in the up-turned beaker
create a high-pressure that forces the water out from under it and thus an
increase in the water height as measured in the graduated beaker? So why
is the level of water forced out by the high-pressure less than the amount
'sucked' in by the low-pressure?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
I didn't say he said 1.5 volts. I said that "you make it sound like it was
like 1.5 volts or something" (instead of a huge shock).
I didn't understand the question.
When things get crazy, it's not surprising that mistakes can happen. A
very high pressure job, to be sure.
Jim
