POV-Ray : Newsgroups : povray.off-topic : you & me right now, warp Server Time
31 Mar 2026 08:31:17 EDT (-0400)
  you & me right now, warp (Message 66 to 75 of 175)
Subject: Re: you & me right now, warp
Date: 17 Feb 2009 08:25:42
Message: <499abad6@news.povray.org>
Darren New wrote:
> nemesis wrote:
>> Nothing is faster than C, some wise men said. ;)
> Assembler is.
Back in the days before modern processors I'd say absolutely. But
nowadays that's debatable. Due to multiple pipelines, the criticality of
cache hits and advances in compiler design, it's very difficult to beat
C with assembler.
I'd say a mix of C and inline assembly is probably your fastest
performance bet. You can leverage the optimizations the compiler will
perform, and use SIMD instructions in ways the compiler won't find.
~Mike
Date: 17 Feb 2009 08:26:13
Message: <499abaf5$1@news.povray.org>
Stephen wrote:
> I raise you "Machine code" :)
More pain != faster :-P
~Mike
Date: 17 Feb 2009 08:30:17
Message: <499abbe9$1@news.povray.org>
Invisible wrote:
> That still doesn't explain why I'm the only one having this problem.
You are not the only one by far. Do you know how many times I've been
"gently corrected" just on here?
You'll see I'm wrong a lot. I draw the ire of the same people you do.
The difference is I don't dwell on it. I just go on.
OK, so that may be stupid of me, but I do listen from time to time. :)
~Mike
Date: 17 Feb 2009 08:33:27
Message: <499abca7$1@news.povray.org>
Jim Henderson wrote:
> That's a good question, Slime.  I've been wondering that myself.
I agree.
But, I find it ironic that one of his admonishments was not to derail
the thread, only to see there is a large part of this thread that has
absolutely nothing to do with the original topic. Delightfully hijacked.
~Mike
Date: 17 Feb 2009 10:42:43
Message: <499adaf3$1@news.povray.org>
>> Assembler is.
> Back in the days before modern processors I'd say absolutely. But nowadays
> that's debatable. Due to multiple pipelines, the criticality of cache hits
> and advances in compiler design, it's very difficult to beat C with
> assembler.
Well it really depends on how *difficult* it is to match or beat any
language with assembler.  It's always theoretically possible, but as you say
with modern CPU and compiler design it is becoming increasingly harder.
If you really know the CPU and system architecture well I would imagine that
a skilled programmer could write a small section of assembler to run faster
than a compiler, just because humans are better at that sort of optimisation
(they can consider a lot more things intelligently that a compiler can't,
for example changing the algorithm slightly to better match the hardware).
But humans tend to be very slow at this, a compiler can perform simpler
optimisations over much larger programs far quicker.
Date: 17 Feb 2009 12:02:51
Message: <499aedbb@news.povray.org>
  Someone claimed to me once that fortran has some tricks in its sleeve with
certain types of mathematical programming that allows it to generate much
faster code than C can. In order to get the same speed with C you have to
resort to (obviously non-portable) inline asm.
Date: 17 Feb 2009 13:03:23
Message: <499afbeb$1@news.povray.org>
> say with modern CPU and compiler design it is becoming increasingly harder.
That was exactly my point. You can always disassemble the output of the C
compiler to get assembler code, so C cannot by definition beat assembler.
Nor can anything else.
It's merely a question of how much you're willing to pay to scrape out those
last few cycles, and whether you really need those last few cycles. But the
same applies to anything else. Could you take Bellcore's database systems
with hundreds of millions of lines of SQL stored procedures and rewrite it
entirely in C? Certainly. Is it worthwhile doing it that way to speed it up?
Of course not.
So saying that one language is faster than a completely different language
is one of those FUD overgeneralizations. It's true in some cases, and not in
others. How fast is C at building and analyzing parse trees that are too big
to fit in memory? You're probably better off abstracting the problem, either
with a library or a programming language, and the programming language will
be able to make better global choices than any straightforward library.
I suspect most people using C and C++ and such don't really ever profile
parts of their applications they didn't write. They don't look for speedups
in the runtime libraries, or Boost, or pthreads, or whatever else they're
using. Just like there are few people who actually compare the speed of
garbage collection against the speed of manual memory management in real
programs, and just assume that if the programmer's managing it, it must be
faster. But it isn't always, exactly because the GC engine can do the kind
of global analysis that the C compiler does for things like register
allocation.
Of course the holy grail is a programming language that *is* high level and
easy to use while also being capable of being turned into extremely
efficient machine code.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 17 Feb 2009 13:03:49
Message: <499afc05@news.povray.org>
I can't comment on whether that's true, but I know there is a fairly
large codebase of existing numerical-processing stuff in Fortran...
http://blog.orphi.me.uk/
Date: 17 Feb 2009 13:09:23
Message: <499afd53$1@news.povray.org>
> language is one of those FUD overgeneralizations.
Oh, and as another example, COBOL. It's much faster to do stuff like decimal
math and print formatting in COBOL (where it's built in) than C, especially
if your processor has instructions for it.
Plus, many processors these days are built for C and are hard to change.
Back when people were loading microcode themselves, machines running LISP or
Smalltalk were quite fast compared to those machines running C with the same
instruction set. It's more like "modern instruction sets favor C-like
languages" than anything else.
Stuff like dynamic dispatch in objects could be individual CISC instructions
and greatly speed things up, for example.
I'm also not sure if some of the Java hardware dosn't run Java faster than
it would run C.
   "Ouch ouch ouch!"
Date: 17 Feb 2009 13:09:24
Message: <499afd54$1@news.povray.org>
There's two tricks Fortran has...
1) It's OK to do single-precision math on two single-precision values.
2) It's not OK (simplified) to alias two values together and use them in the
same expression, so the compiler can assume less aliasing and keep more
stuff in registers over assignments. That makes it much easier to have a
loop doing B[I] = C[I] + A[I] and vectorize it, knowing B != A != C.
I think the later C standards improved (or tried to) on both these fields.
   "Ouch ouch ouch!"
