POV-Ray : Newsgroups : povray.off-topic : GIMP hotkeys/ scripts/ user-defined functions? Server Time
9 Mar 2026 14:17:25 EDT (-0400)
  GIMP hotkeys/ scripts/ user-defined functions? (Message 41 to 50 of 80)
Subject: Re: Undirected rambling
Date: 10 Dec 2008 15:55:20
Message: <49402cb8$1@news.povray.org>
>>> Why would my o operator not be a one-liner?
>> Because it's defined as four (very wide) lines? :-P
> By how many lines is $ defined by?
One. (See my earlier reply.)
>> In Lisp, you cannot avoid endless brackets, because notionally the
>> *entire source code* as a single expression. :-P
> Yes, code is data in Lisp.  Ain't that sweet? :)
>> Heh, right. One question: is it statically-typed?
> No.  Like I said, perfect. :)
If it's not statically-typed, how do you know that all your types match
up correctly?
Oh yeah, that's right - you run it and hope you tested every possible
code path. Until you release the code, and 3 years later discover that
hidden away in some corner is a type mismatch.
...or you could have the compiler tell you on the day when you tried to
compile the code.
Guess which way I prefer? ;-)
>> Haskell is *loaded* with functions that do the same or similar things.
>> It's about how you want to think about your problem.
> I prefer to design my own DSLs and have a minimalist general-purpose
> language with few constructs that don't get in the way nor confuse me
> with conflicting semantics.
Each to their own...
http://blog.orphi.me.uk/
Date: 10 Dec 2008 16:41:11
Message: <49403777@news.povray.org>
Orchid XP v8 escreveu:
No.  I suggest you go through the GHC code and discover by yourself.
> up correctly?
Oh, *I* know.  Question is:  does the compiler/interpreter knows where I
want to go to?  Is it assuming right my decisions?
In C++/Java I have to carefully feed such decisions to the dumb
compiler, in Haskell I have to be sure its correctly following and
inform it when it isn't -- by running into runtime type mismatches, when
the compiler incorrectly assumed something.
In Scheme/Python/Ruby, the interpreter just don't care and it's all up
to you.
Not different at all from any logic mismatch between what you want to
say and what you actually say.  You may type your whole program
correctly and still have logical inconsistencies.  Sure, type
inconsistencies are catched early, but they sound to me like trivial
errors.  They were certainly non-trivial in C/C++ and their multitude of
pointer arithmetic, they are non-trivial in Java and its multitudes of
deep OO nestings and inter-module dependencies, and they are also
non-trivial in Haskell because of the way how its advanced and complex
type system allows for much of the behaviour of a program to be directly
embedded in the type declarations themselves.
They are trivial though in Scheme, where types are just basic data types
and simple groupings and most of the program behaviour is still
algorithmic in the traditional sense.  Type mismatches are the very
minor of headaches here.  So, I guess the importance of type systems is
relative.
Anyway, I don't know exactly how this discussion would fit an embedded
scripting language running in a host app.  Would Haskell do any better
as an embedded scripting language?  All its type safeties don't quite do
much in a non-compiled interactive environment:  if you ever did
anything at a Hugs or GHCi console, you'll see you may constantly run
into runtime type errors just as in a dynamically typed language.
Date: 10 Dec 2008 16:55:28
Message: <49403ad0@news.povray.org>
Why? It's not defined in GHC, it's defined in the libraries. :-P
[Checking the language standard document, it's actually defined as two
lines, because it gives a type signature as well.]
>> match up correctly?
> Oh, *I* know.
Right. Sure. Because you're super-human. :-P
In Haskell, you can't *have* runtime type mismatches. :-P
> to you.
Exactly. If you make a mistake, it's your fault, and the interpreter
gives you no help at all to fix it.
Does the type system catch every possible problem? No.
Will any automated system ever catch every possible problem? No.
Does that mean that automated systems for catching problems are a waste
of time? Again, no.
For writing small, simple things on the fly, something vague and
unstructured is probably the best way to go. (This is why scripting
languages exist.)
Personally, I don't tend to write that kind of code.
Date: 10 Dec 2008 20:06:30
Message: <49406796$1@news.povray.org>
So is mine.  The others had nothing to do with compose.
>> Oh, *I* know.
No, I just know what I'm doing and consider type errors too primary and
trivial next to logic errors.
True.  Sorry.  It's a type system error message from verifying a type
mismatch is happening.  It is helpful.
Of course, it's also a pain in the butt when it gets in the way:
Prelude> let statusLine fruits = if fruits>1 then fruits else "No more
fruits"
<interactive>:1:34:
     No instance for (Num [Char])
       arising from the literal `1' at <interactive>:1:34
     Possible fix: add an instance declaration for (Num [Char])
     In the second argument of `(>)', namely `1'
     In the predicate expression: fruits > 1
     In the expression: if fruits > 1 then fruits else "No more fruits"
I used a quick hack to try to get around it:
Prelude> let self x = x
Prelude> let statusLine fruits = if fruits>1 then self statusLine fruits
So far, so good.  The compiler didn't do its job. ;)
But, then:
Prelude> print statusLine 3
<interactive>:1:0:
     Couldn't match expected type `t1 -> t'
            against inferred type `IO ()'
     In the expression: print statusLine 3
     In the definition of `it': it = print statusLine 3
I tried to group it with parenthesis then:
Prelude> print (statusLine 3)
Weird!  It output that single double quote and froze.  I had to
interrupt it.
Lesson here:  sometimes the compiler not only gets in your way but also
doesn't do its job as supposed.
Oh, and BTW:
Prelude> filter odd [1,2,3,4,5]
[1,3,5]
weird, huh? :P
>> to you.
It gives you a nice call stack trace. :)
Seriously though, Common Lisp is king in this respect.  Some of its most
well-known implementations' runtime systems allow for a quick debug of
what's going on in an app, correcting, compiling and even patching it
while the system is still running.  Yes, no need for reboots.
> of time? Again, no.
Not at all.
> languages exist.)
Exactly.  Dynamic languages fit the bill whenever specifications are
vague and prone to much change.  Like, every real world system I've
worked with, except they were in horribly asinine straightjacket
languages that penalized changes.
But it was the kind of which the OP was asking about.
Subject: Re: GIMP hotkeys/ scripts/ user-defined functions?
Date: 10 Dec 2008 21:20:01
Message: <web.494078724d4e8c9434d207310@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> Hmm, I wonder if this gregjohn fellow is taking any advantage from my
> replies.  He posts a question and vanishes! O_o
My goodness, how long has it been?!
But I did look at the Script-Fu (had to be sure I typed that right) for resize
and don't think it exactly worked.
I was hoping to do something like set up my own hotkey where like Shft Ctrl F11
just automatically resizes to 400x300 pixels.
Date: 10 Dec 2008 21:36:24
Message: <49407ca8@news.povray.org>
nemesis wrote:
> actually, it's just a bridge between CL and XML.  Hey, XML itself is an
> s-expression language, like Lisp. ;)
Some people have tried the opposite. Converting XML into something that
looks like lisp :)
<tag attr1="value1"
     attr2="value2">
  <nested>Text node</nested>
  <empty/>
</tag>
(tag (@ (attr1 "value1")
        (attr2 "value2"))
  (nested "Text node")
  (empty))
Date: 10 Dec 2008 22:00:00
Message: <web.494081c94d4e8c944e7cdf8a0@news.povray.org>
Oh, man!  Why didn't you say so?  We went all into a language flamewar that
could be avoided! :P
Anyway, it's in the Edit -> Preferences dialog.  Go to Interface -> Config
Keyboard Shortcuts, select Image -> Resize Image (way down), press your choice
of shortcut, done.
Date: 10 Dec 2008 22:05:00
Message: <web.494082514d4e8c944e7cdf8a0@news.povray.org>
> looks like lisp :)
> <tag attr1="value1"
>      attr2="value2">
>   <empty/>
> </tag>
>         (attr2 "value2"))
>   (empty))
Yes.  Many web frameworks for Scheme go that path.  And I like it much better.
Date: 11 Dec 2008 05:05:08
Message: <4940e5d4$1@news.povray.org>
In other words, "no automated system catches every possible error". :-P
That doesn't make automated error catching useless.
>>> up to you.
Isn't that precisely what Smalltalk also does? :-P
Of course, much as I like Smalltalk, the lack of static typing makes it
really hard to use. When you have multiple levels of indirection, it's
very easy to accidentally miss one out. Static typing would instantly
detect this mistake and tell you exactly where the problem is. But
Smalltalk doesn't have it. So you run your code, something of the wrong
type gets assigned somewhere, and many hundred method calls later, you
get an exception because some method isn't defined. Oh, sure, you get a
call stack, but *good luck* figuring out where the _problem_ is. The
call stack only shows you where the problem get _detected_.
>> waste of time? Again, no.
> Not at all.
You see why I like having automated error-catching systems then? :-P
>> languages exist.)
No, scripting languages fit the bill anywhere the thing to be built is
small, simple, and it's only going to be used in one specific way.
As soon as you start trying to do anything more sophisticated than that,
scripting languages become inadaquate.
Yeah, I get that. I'm just saying, for writing large complex programs,
more help = better.
Date: 11 Dec 2008 12:05:46
Message: <4941486a$1@news.povray.org>
Oddly enough, Ada can unload and reload new code while it's running too, and
that's about the most anal-retentive language I've ever used.
> really hard to use. [...] but *good luck* figuring out where the
 > _problem_ is. The
You know, I did my PhD work by patching into someone else's structured
editor/compiler/interpreter written Smalltalk, without really understanding
all the details. I had this kind of error maybe a handful of times, and it
was never confusing what happened. If you leave out a level of indirection,
then you wind up with an array of XYZ where you expected a XYZ, so you know
you missed the indirection where you wanted to go from array-of-XYZ to XYZ.
If do one too many, you get the error exactly when you ask for the Nth XYZ
from the array of XYZ that's really a single XYZ.
I disagree.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
