POV-Ray : Newsgroups : povray.off-topic : New LuxRender web site (http://www.luxrender.net) Server Time
31 Mar 2026 04:11:19 EDT (-0400)
  New LuxRender web site (http://www.luxrender.net) (Message 171 to 175 of 175)
Subject: Re: New LuxRender web site (http://www.luxrender.net)
Date: 24 Feb 2008 00:28:51
Message: <47c10093$1@news.povray.org>
Invisible wrote:
> POV-Ray, of course, gets round this problem by using more sophisticated
> mathematical techniques than simply projecting flat polygons onto a 2D
> framebuffer. I've yet to see any GPU attempt this.
Well, I wrote a vertex shader a while ago that would correctly position
a point along a Bezier patch*.  Then, rendering the patch became a
matter of passing a "net" of points in, and let the GPU handle the
actual calculation of the points.
It wouldn't be too much of a stretch to extend this to other functions,
and not just a Bezier calculator.
...Ben Chambers
www.pacificwebguy.com
*It even varied the granularity of the net in real time based on the
current FPS, so it would maintain a constant frame rate.  It ended up
quite nice, and I was able to have about a dozen patches on screen, with
no visible polygon edges, on my GeForce 5200.
Of course, on my 7600GT, I can render several dozen patches on screen at
once, with no visible polygon edges.  Still a far cry from modern games
(where an individual model might have 8-15 *thousand* polygons, and
there are usually several characters on screen at once), but a neat
effect anyway :)
Date: 24 Feb 2008 06:35:02
Message: <47c15666$1@news.povray.org>
Invisible wrote:
> Also, how does it figure out which polygons to draw? It can't possibly
> draw all 10 million polygons every frame - and yet, figuring out which
> ones are visible would seem to take more effort than actually drawing
> them all...
Something similar to bounding volumes (though they're really visibility
volumes), to limit the areas that are drawn.
For instance, when you're inside a room, the engine knows that it
doesn't need to draw the rest of the map - it only draws that room.
Furthermore, it also knows precisely which areas are visible outside the
window, and which ones aren't.
These volumes are usually computed ahead of time, as a large map can
take up to several minutes to compute the volumes (depending on the
game, the level, and the machine being used to build it).
...Ben Chambers
Date: 24 Feb 2008 06:38:39
Message: <47c1573f@news.povray.org>
Invisible wrote:
> I often look at a game like HL and wonder how it's even possible. I
> mean, you walk through the map for, like, 20 minutes before you get to
> the other end. The total polygon count must be spine-tinglingly huge.
It doesn't draw 10 billion separate vertices - it only draws about 150M
vertices, 60 times each.  Of course, most of those are instances of the
same meshes, so it's really only about 1-3M unique vertices in a given
scene.
...Ben Chambers
Date: 24 Feb 2008 06:41:34
Message: <47c157ee$1@news.povray.org>
nemesis wrote:
> BTW, is it just me or anyone else feel like it's easier to add new code and
> lighting models into povray rather than writing a povray SDL parser to other
> renderers? :P
Wasn't that one of the original design goals? ;)
...Ben Chambers
Date: 26 Feb 2008 07:40:15
Message: <47c408af$1@news.povray.org>
Chambers wrote:
> Until it can parse SDL, I will consider it inferior to POV.
> Long live hand written code! ;)
I think I just found the user requirements spec for my new raytracer...
No, but seriously, there are some things about SDL that I'd change. Like
making it possible to inspect existing objects and edit their textures
and stuff...
http://blog.orphi.me.uk/
