POV-Ray : Newsgroups : povray.off-topic : New LuxRender web site (http://www.luxrender.net) Server Time
8 Apr 2026 19:19:49 EDT (-0400)
  New LuxRender web site (http://www.luxrender.net) (Message 141 to 150 of 175)
Subject: Re: New LuxRender web site (http://www.luxrender.net)
Date: 21 Feb 2008 16:11:40
Message: <47bde90c@news.povray.org>
Orchid XP v7 wrote:
> As best I can tell, the algorithm described just sounds like POV-Ray's
> radiosity with an infinitely low error_bound. (I.e., always resample.)
don't forget higher than 1600 count limit...
Date: 21 Feb 2008 16:13:59
Message: <47bde996@news.povray.org>
> But applied to *all* terms, not just diffuse illumination...
  Except that POV-Ray doesn't have the concept of BRDFs.
  Also, brute-force renderers take a slightly different approach at
rendering than POV-Ray's radiosity. What the latter does is that when
a ray intersects a surface, it sends tons of rays to all directions
(unless it can interpolate from nearby values calculated earlier).
AFAIK brute-force renderers only send one ray to a random direction.
This means that a ray hitting a surface doesn't spawn a thousand new
rays, but only one.
  There are advantages and disadvantages with this. The advantage is that
the renderer never gets stuck on things like highly reflective/refractive
objects because it's only following one path, not thousands (each one of
which in turn would spawn thousands of new paths, etc). Another advantage
is that you don't have to fix a number of rays to send per intersection
point, but you can simply let it run for as long as you want.
  The disadvantage is the graininess, of course. Overall, however, the
correct result is approached faster in this way than with the method
POV-Ray uses. (This is assuming we are looking for the perfect solution.)
Date: 21 Feb 2008 16:22:47
Message: <47bdeba7@news.povray.org>
I think another advantage is it works well with deadlines. Instead of
worrying if you'll finish the render by the IRTC deadline, you just let
it run till the last minute. It may be more or less grainy, but at least
you have the whole image. With a normal raytracer, you'd have the top
half of the image...
Date: 21 Feb 2008 16:26:10
Message: <47bdec72$1@news.povray.org>
Orchid XP v7 wrote:
> Vincent Le Chevalier wrote:
>> That's the key. I'm not too sure POVRay's radiosity gives an unbiased
>> result even with all settings turned up to the best quality. If there
>> is just one reflective surface in the mix I'm downright sure it does
>> not...
> I do recall somebody rendered a radiosity scene with no photon maps at
> all, and yet a large curved mirror still produced correct caustics. (It
> was a damn long time ago now though, so I'd never be able to find the
> image...)
Well, strange...
In the docs it is written:
The brightness of radiosity in POV-Ray is based on two things:
    1. the amount of light "gathered"
    2. the 'diffuse' property of the surface finish
<http://www.povray.org/documentation/view/3.6.1/270/>
So it seems pretty clear that radiosity does not take the specular path,
ever, because the "reflection" property is not considered. Which means
that rays doing:
Light->specular->diffuse->diffuse->camera (the situation I described)
or Light->diffuse->specular->diffuse->camera (as in the image Nicolas
posted)
are never created.
But if there is a scene proving me wrong I'd be glad to see it.
Vincent
Subject: Re: Brute force renderers
Date: 21 Feb 2008 16:28:26
Message: <47bdecfa$1@news.povray.org>
On Thu, 21 Feb 2008 17:12:04 -0300, nemesis wrote:
> Jim Henderson wrote:
>> Ah, so you've decided Darren and I were right after all, then? ;-)
> yes, now I'm a satanist. :P </sarcasm>
Ah, then you didn't understand our point. ;-)
Jim
Date: 21 Feb 2008 19:33:36
Message: <47be1860@news.povray.org>
> On Thu, 21 Feb 2008 14:40:25 -0300, nemesis wrote:
>>>> As an aside is a black and white photograph, photorealistic, or a
>>>> sepia one? Are the Pre-Raphaelites or chocolate box paintings?
>>> You read my mind, Stephen. :-)
>> yes, they are all actual light (photo) captures, just lacking enough
>> resolution or colors.
> But a binary diff would be different against those.
> So it is subjective after all....
no, just render with the same resolution and color range and diff them. ;)
Date: 21 Feb 2008 21:04:39
Message: <47be2db7@news.povray.org>
Well, general consensus with the folks I've talked to about it says that
it is a matter of opinion - you seem to be in the minority here. ;-)
Jim
Date: 21 Feb 2008 22:56:21
Message: <47be47e5$1@news.povray.org>
so, your guys opinion is that it is a matter of opinion? ;)
Date: 21 Feb 2008 23:45:08
Message: <47be5354$1@news.povray.org>
>> that it is a matter of opinion - you seem to be in the minority here.
Precisely.  But because it's a majority, it must be a fact. ;-)
Jim
Date: 22 Feb 2008 01:14:56
Message: <47be6860@news.povray.org>
Until it can parse SDL, I will consider it inferior to POV.
Long live hand written code! ;)
...Ben Chambers
www.pacificwebguy.com
