POV-Ray : Newsgroups : povray.off-topic : Any thoughts on this... Server Time
9 Feb 2026 20:54:33 EST (-0500)
  Any thoughts on this... (Message 1 to 10 of 16)
Subject: Any thoughts on this...
Date: 22 May 2008 01:43:18
Message: <MPG.229eb5e5ce6c245c98a159@news.povray.org>
Lets say, for the sake of argument, that you have a way to *detect* when
an avatar in a game world has "touched" and object. Fine so far, but
lets say the object can be any imaginable shape, but you "need" to be
able to tell *where* they touched it, without breaking the object down
into specific objects, each with their own detection. My thought is, use
something like a bounding box. You can determine which "side" you are
touching it from, and where, relative to the top-left of that "side" of
the bounding box it was touched, by sort of extrapolating where on that
"side" you contacted it. There are obvious limitations to this method,
but it may be good enough for most applications its likely to be used
for. So.. The question becomes, knowing what I need, how the bloody heck
do you implement it?
Basically, I am going to try to propose an extension to the "touch"
functions in a virtual environment, which works similar to the image
maps used in HTML pages (so you can make images/buttons on the texture
as target points), but I would like to have a clear description of what
I am proposing and how it would work, so that the odds of it being
adopted is a tad higher than just making the suggestions. Note - Due to
the way objects are handled, to maintain ownership of them, the script
and the functions that determine what has been touched, and thus also
where on the bounding box, run on the server end, not in the client. I
figured that since the math to detect a collision with a bounding box is
fast, as is the general means to derive one, the only real issue is to
figure out how to find out where something got touched. This may have to
be done client side (and getting that data to pass to the server isn't a
big deal if it has to be), but in essence, I figure you would be
generating three pieces of information:
1. I am facing side S of the bounding box.
2. I touched the bounding boxes side at X,Y.
3. I touched object O, which is bound by #2.
Its already generating 3, but I don't see it being practical to detect
where on an object it touches directly, since a) the objects are meshes,
and b) even if you detected a face, that face could be far bigger than
the part of the texture that you *want* to detect the touch on.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: Any thoughts on this...
Date: 22 May 2008 02:25:39
Message: <483511e3@news.povray.org>
http://en.wikipedia.org/wiki/Collision_detection
Date: 22 May 2008 21:48:17
Message: <MPG.229fd0135ebfee5698a15a@news.povray.org>
In article <483511e3@news.povray.org>, war### [at] tagpovrayorg says...
Hmm. There is no "collision" between the mouse pointer and the object,
save in the most basic sense that something like the POV-Ray camera can
be said to "collide" with an object via its vector. The issue here is
detecting one such collision, based on another. I.e., you can't "test"
the bounding box *unless* you already know that the pointer made
apparent contact with the object, and then you have to determine *which*
face of the bounding box that "had to be" for it to have struck it. Mind
you, I can see where its possible they are already using a bounding
system to limit how many tests they have to make, and therefor they may
be testing if something "entered" the boundary, then if it actually
struck the object. That would make things a whole heck of a lot simpler,
but since this is all done server end, for security reasons, I don't
have access to source to check...
I suppose the wiki is applicable only if they are doing something "like
that" already. If not, then I suppose a second test against the bounding
box created would work. Frankly, I am not real certain that they "are"
using something to limit how many tests they need. Their code often runs
slow, there asset services, which track who owns things, goes down way
to often, etc. Even *basic* stuff in the script system seems to be
missing, since it never occurred to them that it made sense to have it.
Example - Every person/group has a unique ID. The "test" function to
tell who touched an object only tests "one" ID at a time, and you can
only have one such script in each object, which means you have to use
multiple objects, each with a seperate test, to determine if one of of a
list of people/groups touched it. Some people get around this using HTTP
requests and external servers to handle the tests, but imho, its damn
stupid that they waste time and resources to run multiple scripts, in
multiple objects, which "still" have to be sent to the client, along
with textures and other data, to do what a simple "Is the ID if the
person that touched it in a *list* of IDs?" I mean, this is a complete
"duh!", but its missing.
So, I am not betting that they necessarily are using bounding, or other
tests effectively to determine what got touched, client side or server
side. :(
Still, I think I can probably post the idea anyway, since its possible
they do have something in place that could be adapted to allow it.
void main () {
  else
Date: 22 May 2008 22:10:40
Message: <483627a0$1@news.povray.org>
I would say you can separate the security from the calculations pretty
easily.
1) The client knows what it's drawing at each pixel, so when you click,
compute which bit of mesh was shown in the pixel the mouse was in when
the click occurred. Report that to the server.
2) All the *server* has to do is verify that the client is capable of
seeing the bit of mesh that you clicked on. In other words, the server
doesn't have to figure out where you clicked - it only has to confirm
that you could have clicked on what the client figured out. Given the
server knows the object's mesh coords and the camera's location, this
should be pretty easy. A piece of mesh partially obscured might make
this a little harder.
> as target points),
Yeah. My object in SL took 57 objects to make a 5x5 board for 2 people.
Messy to instantiate. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 22 May 2008 22:36:14
Message: <MPG.229fdb834ffd0e7898a15b@news.povray.org>
In article <483627a0$1@news.povray.org>, dne### [at] sanrrcom says...
> easily.
Well. Yeah, I figure this is the case, but I also figured that complex
objects "might" be a bit more complicated than testing a bounding box
around them. However, if they already do basic detection to determine if
the need to "test" for such things anyway, then the bounding box already
exists. Since I don't know near enough of the math, I have no clue how
complicated something like a sculptie would make the whole mess, never
mind linked objects.
> > as target points),
Ah. You guessed it. lol Seriously though, HUDs and even things like
kiosks and door keypads waste anything from 6-7 prims and textures for
something "simple", like the animation overriders, to 9 for a keypad, to
10+ for some kiosks, etc. And every damn one has to have a script to
"say" things to the key prim, which needs a listener, etc. Just making
it detect where on a texture you touched, so you don't need all the damn
prims, could cut the amount of crap running server side, as well as the
number of prims and textures to be sent/rendered, in half.
As for your game.. Not sure that would have helped much. You still need
a key "listener" with the board texture, to detect where you clicked,
instead of talking to it, then lots of listeners in the pieces, to make
them rez, move and derez when needed. Its possible it would have helped
some, but maybe not as much as you think in that case.
void main () {
  else
Date: 22 May 2008 23:48:03
Message: <48363e73@news.povray.org>
> around them.
I'm not sure you followed my description.
The client looks at the click, and decides which facet of which prim was
drawn where you clicked. The server isn't involved yet.
The client then sends to the server the fact that you clicked at a
particular point on a particular triangle in a particular mesh on a
particular prim. The server merely needs to verify that the normal of
that triangle points towards the avatar and isn't blocked by something
else.
I.e., it makes the hard part ("what did I hit where") run on the client,
and the server only has to verify that (say) all three corners of the
triangle are in view of the camera. The actual mouse position relative
to the screen, for example, never needs to go to the server.
My game doesn't have movable pieces. It has poke-able places. I.e., more
like tic-tac-toe than chess.
Date: 23 May 2008 23:35:33
Message: <MPG.22a13af354b5b0a798a15c@news.povray.org>
In article <48363e73@news.povray.org>, dne### [at] sanrrcom says...
> > around them.
> else.
Actually, that *won't* work as I intended. In most cases you are going
to be dealing with something that only have *one* side to it, like a
HUD. In other cases, you may be dealing with something that has a
complex surface, but you don't want/need to know which "triangle" was
touched, you need to know where on the "texture" was touched, which
"may" overlap several such triangles, if its a complex shape. Using
tests against which face was touched just dumps you right back in the
same "Oh, prim xyz was touched, now what?", case you had before, since
you then would have to figure out if the texture is "on" that triangle,
which "part" of it is on that triangle, and "if" that somehow connected
to what you are looking for in the script. I.e., a total mess.
What I am looking at, instead, is much simpler. You have some complex
object that "happens" to fit in a box that is 5x3x1, and a texture on
*one* of the 5x3 faces, that is towards you. You touch it. The
client/server determines that you "would have" also touched that face,
of that virtual "box", and based on that, returns a set of coordinates
xp and yp, which ranger between 0-1 (you might have stretched the
texture, so you can figure where something "should be" based on
percentage of the texture far more easilly than by "dimension". So, if
you touch the virtual box at some place like 3.41x1.21, you get the
"apparent" location on the texture (assuming you touched the object at
all, since a complex one may not have any part of itself "at" those
coordinates) you get xp = 0.682 and yp = 0.4033. You can then test if
that falls within a region on the texture that would have had your
button on it. It won't work with *hugely* complex surfaces, but for
anything that uses a relatively flat surface anyway, the result will,
even if you map over something not 100% flat, be "close" to what you
figured when designing the texture. And of course, if you had such a
system, you could add a feature to any "editors" that may be designed
later to produce an "accurate" location, even if it is on a complex
surface.
You method would require something a lot more complicated, involving
determining if the right texture is on that part of the object, if it
is, where that is in relationship "to" that texture, and a mess of other
things that are, frankly, not likely to be in the library anyway, since
textures are just mapped via GPU to the surfaces, and there probably are
not any functions, either in the GPU, or in the library used to place
them there, that can return that kind of information, especially not
with enough "precision" to tell you where you touched it, not just,
"Yes, the texture overlaps the face you touched."
void main () {
  else
Date: 24 May 2008 13:10:37
Message: <48384c0d$1@news.povray.org>
Well, adjust as needed.
Sure. But the client knows why it drew the pixel you clicked on in red,
or blue, or orange. So the client is already doing all the math to
figure out exactly which texture is drawn where on each pixel. That's my
point.
After that, the server only needs to know if the client's request is
*possible* to make sure it's legal.
Well, is it the client, or the server, that figures that out? I thought
that's what you were asking.
> surface.
But you don't have to do that. The client is already doing all the
"accurate location" math when it draws the object on the screen, even
for a HUD.
In other words, start out not thinking of it as "where on the object did
I touch", but instead think of it as "where on the screen did I touch"
followed by "what did I draw on the screen at that location".
That seems like a pretty sucky library. :-)  Obviously the math is easy
enough to do in a small fraction of a second, tho.  In any case,
anything you can offload to the client is something you *should* offload
to the client, in that architecture. Once the client has figured out
what you touched where, chances are the server can confirm it more
easily than it can iterate through all the possible textures and prims
within visual distance of your camera. Especially if you're close to the
edge of a server.
Date: 25 May 2008 22:40:31
Message: <MPG.22a3d0edd9b3cdf398a15d@news.povray.org>
In article <48384c0d$1@news.povray.org>, dne### [at] sanrrcom says...
> edge of a server.
Well, I admit I don't know much about 3D libraries of the type they are
actually using, so wasn't sure how much was handled via the software and
how much the GPU, with respect to textures.
void main () {
  else
Date: 26 May 2008 01:45:08
Message: <483a4e64$1@news.povray.org>
I don't know either. But certainly the server won't be able to use the
GPU to calculate anything, and it's clearly something you want to
offload out to the client as much as possible. I imagine the client is
at least doing the clipping-to-viewport or something that would reduce
the amount of calculation needed.
