POV-Ray : Newsgroups : povray.off-topic : Database Questions Server Time
29 Nov 2026 19:17:22 EST (-0500)
  Database Questions (Message 49 to 68 of 68)
<<< Previous 48 Messages Goto Initial 50 Messages
Subject: Re: Database Questions
Date: 10 Mar 2011 04:17:52
Message: <4d789740$1@news.povray.org>
On 09/03/2011 05:11 PM, Darren New wrote:
> I think they turned off the encryption of the low bits back in Clinton's
> timeframe, when other countries started threatening to launch their own
> satellites. I think civilian GPS is quite accurate now.
My satnav device cannot accurately determine which motorway I'm on.
Given that a six-lane motorway isn't exactly small, this implies a very
large inaccuracy in the GPS location.
(Of course, I suppose they may have turned off the encryption, but that
doesn't mean that a specific device knows about this fact...)
Date: 10 Mar 2011 11:51:22
Message: <4d79018a$1@news.povray.org>
Yeah, and your calculator can't run DOOM. We already know you make bad
technology purchase choices.  ;-)
No, it implies a crappy GPS receiver.
Plus, GPS while you're moving is somewhat harder to get accurate than GPS
while you're stationary. The way you get millimeter precision even when the
encryption is turned on is to leave the receiver in the same place for a
couple of days, integrating the position samples.
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 10 Mar 2011 14:13:41
Message: <4d7922e5@news.povray.org>
Last time I checked, TomTom is the leading brand.
>> very large inaccuracy in the GPS location.
My dad has a crappy GPS receiver. It takes approximately 30 minutes to
locate a GPS satelite. Mine, on the other hand, requires nearer to 30
seconds...
> GPS while you're stationary. The way you get millimeter precision even
> when the encryption is turned on is to leave the receiver in the same
> place for a couple of days, integrating the position samples.
Just because I'm on a motorway doesn't mean I'm *moving*! :-P
http://blog.orphi.me.uk/
Date: 10 Mar 2011 16:48:10
Message: <4d79471a$1@news.povray.org>
Sometimes, for a few minutes, a GPS receiver will be wrong, I've noticed.
I'm assuming it happens when it picks up on a satellite for which it doesn't
have ephemeris or something.  It usually corrects itself after a minute or less.
Of course, a GPS built into a car is going to assume the car is on one of
the roads on the map, which can also throw things off.
     "That was fatal?"
Date: 10 Mar 2011 16:57:05
Message: <4d794931$1@news.povray.org>
> of the roads on the map, which can also throw things off.
More precisely, it assumes that you're on the road it's telling you to
drive down, until you get X number of yards away from that road, at
which point the location indicator suddenly snaps to the road that
you're *actually* on.
Some of this might be the inaccuracy of the road maps, but even at low
speed it seems to take a very long time to figure out where you actually
are, which leads me to think that most of the time it's guessing,
because the GPS fix isn't very accurate.
Date: 10 Mar 2011 16:58:48
Message: <4d794998$1@news.povray.org>
Yes, that's another behavior. I don't think it's because the GPS fix is
inherently inaccurate, but more that it's not especially reliable. You
wouldn't want your navigation to turn off every time you went through a
tunnel, either.
     "That was fatal?"
Date: 10 Mar 2011 18:20:20
Message: <4d795cb4$1@news.povray.org>
On 3/9/2011 2:57 PM, Darren New wrote:
> Tom Austin wrote:
>> I see - the primary key thing should prevent the 'error'.
> Yeah. OK, imagine a database of oh receipts, say.
> If the primary key is some arbitrary integer, it's possible to get the
> same receipt into the table more than once, which will screw up your
> accounting.
> If the primary key is the cash register number + timestamp to the
> second, the only way you get a collision is to make two sales on the
> same register within one second of each other, which probably *should*
> throw some sort of error. It also makes it easy to print on the paper
> receipt all you need to know to get the exact record.
> Whether you can do this sort of thing with any particular table of yours
> is another question.
This makes sense.
I think what still boggles my mind is how to do a double primary key /
double foreign key relationship.
In the case of the receipts, what relationships do you create to have a
table reference a particular receipt?
> Or not updating them at all, if you pass in the same data twice by mistake.
> Look at a CSV file full of receipts like above. Reading each row is
> going to clobber the record already there. If you use an auto-increment
> ID, you'll wind up with 200 reciepts if you read a 100-row CSV in twice.
So, the primary key relationship keeps the data from being inserted by
default.
> IME, a large part of database fuckage is either operator error (like
> loading stuff twice) or simple programming errors (like debiting
> everyone's account instead of just the account of the person you should
> have debited). The idea of making idempotent updates and keeping
> write-once historical records came about because that makes these things
> easy to fix.
And the trick is to have the database strong enough to prevent such
errors from causing trouble in the first place.  You spend your time
setting it up right or making fixes for problems that crop up.
>> pretty much - the owner didn't want to invest the time to make it
>> better and gain the rewards. new owner - new ideas
> Cool. Let's hope it stays that way. :-)
I think it will - but the new push is to be very dynamic - so dynamic
that taking the time to set up a proper database is not possible.  From
one extreme to another.  I guess I rather take this extreme - it means
we are moving someplace.
>> I think I have run into this already
>> select A from b where A.ID in ( select ID from C)
> No, that's cool. Well, not that exact query, but that sort of thing. The
> trick is it's all in SQL. You aren't looping inside the PHP code or
> Javascript code or whatever you're using to submit that code to the
> database engine.
So what's not cool about the query - should something like that be avoided?
>> in its simplest form leaving out fluff like owners and such:
>> table poles: (each pole)
>> ID, GPS Location
>> 1 entry for each pole
>> table connections: (how poles are connected)
>> ID, PoleID1, PoleID2, Distance
>> 1 entry for each pole-pole joining (1 for each 'set' of cables)
> See, this is what I mean. There's no need for an ID on this table. You
> don't want two rows, one where it's
> (27, Pole 3, Pole 4, 500 feet)
> (29, Pole 3, Pole 4, 800 feet)
> You get that, your data is screwed, and you know it, but you can't fix it.
> A connection between two poles is defined by the two poles it's
> connecting. The distance and what types of cables go through are
> dependent data.
> table connections:
> PoleID1, PoleID2, Distance (pk=PoleID1+PokeID2)
> table cables:
> PoleID1, PoleID2, height, cable type. (pk=PoleID1+PoleID2+cable type)
Does this keep from having this case?
PoleID1	PoleID2
1   	2
2   	1
Does keying prevent this or does it have to be taken care of some other way?
>> table attachments: (cable attached to poles & height)
>> ID, PoleID, Height
>> multiple entries per pole
>> 1 for each attachment
> Is there a row in this table for a pole that has no cables attached?
> I.e., does this represent "Cables attached to this pole" or "places
> where it's posslbe to attach a cable"?
actual cables attached - so a pole can have 0 attachments.
>> table midspans: (lowest height between poles for each cable)
>> ID, AttachmentID1, AttachmentID2, Height, ConnectionID(redundant)
>> multiple midspans for each 'connection'
>> 1 midspan per cable over the connection
>> essentially 1 midspan for each connection on a pair of poles
> Consider a slightly different layout: a span.
> Cable type, poleID1, attachmenthieght1, poleID2, attachmentheight2,
> midspanheight.
> Then poleid1+poleid2+cabletype becomes your primary key.
Ok, I was confused but now I think I see clearly.  Instead of
dereferencing to attachmentID like I did, one just uses the (poleID) and
(attachment height) as the key from the attachments table.
> That gives you poles, distances between poles, and spans of cable. If
> you need to know connectivity, you could have a table that lists the
> first pole and last pole along with a collection of spans.
> I'm not saying you should do it this way. I'm just pointing out there
> are lots of ways to organize the data, and you might want to think of a
> drastic simplification in the structure that will still give you
> everything you need with a bit of SQL processing time.
No, but it gives a lot of food for thought.
I don't think you have proposed anything much different than what we
have - it just rids the tables if ID's that can cause more trouble than
they are worth.
> What you want is a structure where it becomes impossible to have only
> some of the information you need. Just like you couldn't have a GPS
> location without a pole, you don't want to have (say) a connection
> height on a pole without a mispan, or a connection height on one pole
> but not on the other pole.
yes, and this is done in the schema without the need for any real code
at this point.
I like the concept - make it robust enough that it can't get fouled up -
no matter what you try to do.
I don't know if we will get there, but I know we will make a few steps
in that direction.
>> The rest is pretty much straight forward - objects and properties
>> associated with each of the above.
>> As you can see, there are some circular references going on
>> (attachments and midspans connect poles
> Yeah. That means you're doing it wrong, if it's actually *circular*.
> It's often easier to draw stuff as pictures on paper when you're
> designing things.
> Draw a box for each table, and an arrow each time there's a foreign key.
> Any box with no outgoing arrows is a fundamental real-world entity. In
> this case, for example, the poles better be in the real world, because
> they're not attached to anything else.
Now that I think about it more, I don't think I have actual circular
going on.
I do have the case where I get connections from the connection table
(pole1, pole2, distance) and I can also get the same information from
the attachments table (poleID, height) and midspans( attachment1,
attachment2) table.
The touble arises if the attachments/midspan tables create a connection
that is not defined int he connections table.
>> You have presented some new ideas that 'extend' my thinking and
>> stretch it. I do not know how much will make it in to the system, but
>> it is good food for thought.
> It takes practice. I'm just trying to explain how I initially approach
> things, and why. Of course each situation varies.
I have the knowledge on how to make a database work - even properly in
the sense that it is clean.  but the other 10% is the icing that makes
things really work well and keep working well with less effort.
>> I agree with it to a point - mainly for ease of working with the data,
>> but not at the sacrifice of usability of the data. The drive is so
>> hard that there is talk about flattening the database to make it
>> 'simpler' and that adding more tables makes it more complex.
> Add lots of tables. Create "simpler" tables by creating views. When you
> find in six months that you need new functionality, create other views
> that expose the data organized in the new way.
OK, a question
I have a table with a descriptor - let's say pole color.
Right now it is just that - a descriptor, but is to be presented to the
user as a list of distinct items to choose from.
I can vaguely see in the future that I will want to group the color into
families (maybe reds, blues, greens), but because of time I can't define
what they are so I will ignore them for now.
At some point in the future the need comes up to define the families and
add them to the DB.
How would one go about this kind of 'building' and how would keys play a
role.
Would I simply specify the column as 'text' and just put the color into
it for now.  Then pull from a distinct query to get the list of
available colors.  Then in the future make a new table that uses this
column as a foreign key that gives the families.  but then the distinct
query is no longer needed as the new table has the distinct values.
Or should I go ahead and create the additional table so that it can
provide the colors with a 1 stop place to add a new one?  Then as the
families are needed just add them to the table?
I know this might not be 100% clear, but how would you go about this?
>> Additionally some of our issue is that when we finish a job for a
>> client we do not need to reference the data any more. Rarely have we
>> found ourselves going back to old data. How much effort should be put
>> into a system that supports saving everything and making it accessible
>> when one does not refer back to it?
> Another good reason to avoid using auto-increment IDs. :-) You can have
> a "job" table that gives you top-level pointers for a job to each thing
> involved in a job. (I.e., if a Job consisted of a bunch of connections
> on a bunch of poles, you'd have a Job ID and a collection of poles. The
> collection of poles would give you the collection of cables. Etc.) You
> could then write out (as SQL even) all the rows associated with a given
> job, then delete those rows. If you ever needed them back, run that SQL
> back into the database. (Altho, honestly, most database engines with
> autoincrement IDs can handle actually inserting records with a given ID
> and not generating a new one.)
yes, I have seen this with Access - updates fail, but inserts work.
> But honestly, I don't know how big your database is, but a database can
> store millions of rows before you even start to see anything getting
> slow. It's not a case of "do we need to keep it around" as it is "do we
> need to throw it away?" But if you manage to build the data in a way
> that each chunk you might want to archive (i.e., a job) has a record
> that lets you get the whole collection of everything associated with
> that record, then you don't have to worry about the actual
> archive-and-delete part of the code until there's a reason to. Then you
> can write that code, confident that you know what you need to store out.
We won't get very big.  We survey maybe 5000+- poles in a given year.
>> Thanks for your feedback - it is very helpful.
> I like helping,b ecause writing the thoughts out clearly enough to
> explain to someone else always clarifies things to me too.
Yes, I like helping others as well for much the same reason.
Date: 10 Mar 2011 20:46:10
Message: <4d797ee2$1@news.povray.org>
You just store the same columns.
Let's say you had a table that recorded customer service records about a
particular receipt.
create table receipts (
    register INT NOT NULL,
    issued TIMESTAMP NOT NULL DEFAULT CURRENT_TIMESTAMP
       ON UPDATE CURRENT_TIMESTAMP, -- MySql sucks
    amount decimal(10,2) NOT NULL,
    clerk INT NOT NULL,
    primary key (register, issued),
    FOREIGN KEY (clerk) references clerks(ID),
create table complaints (
    receipt_register INT NOT NULL,
    receipt_issued TIMESTAMP NOT NULL,
    csr_talking INT not null,
    complaint_answered TIMESTAMP NOT NULL,
    resolution blob,
    previous_call_csr INT,
    previous_answered timestamp,
    primary key (csr_talking, complaint_answered),
    foreign key (receipt_register, receipt_issed)
       references receipts(register, issued),
    foreign key (previous_call_csr, previous_answered)
       references complaints(csr_talking, complaint_answered)
So, modulo the fact that MySql dicks with timestamps in tables depending on
how many timestamps are in the table, and disregarding the fact that MySql
"NOT NULL" doesn't prevent you from inserting records with NULLs, we can
look at this structure:
A receipt is identified by the register number it was issued at and the time
it was issued. There's also other details, like the clerk that was logged
in, the amount of the sale, and so on.
When the phone rings and someone complains, the CSR creates a new complaint
record. This record is identified by the CSR taking the call and when they
took the call. The complaint is about a particular receipt, identified by
the register the receipt came from and the time that receipt was issued.
This may be a follow-up call, in which case the CSR has the previous calls
about this on the screen and may point out that this is a follow-up call
from a particular previous complaint, identified by *that* csr at *that* time.
Does that clarify?
>> mistake.
> default.
Or at least you know when something goes wrong, instead of happily inserting
two copies of every credit card, or pole, or whatever.
>> easy to fix.
Precisely. That's exactly the "C" part of the database. But if you *do*
screw up, being able to go back and fix it and send out the next set of
bills with a credit for the screw-up is helpful compared to going "I don't
know, boss, all the balances are wrong and there's no way to know who we
billed twice for last week."
Your database sounds somewhat different, but to the extent you can actually
figure out by looking at the database what happened to change it, the easier
it's going to be to fix problems caused by going fast. Just something to
keep in mind.
Well, good luck with that. Some people can make that work, but I strongly
suspect your boss is just a jerk. :-)
>> database engine.
No, the query is cool. It's fine. (I mean, other than being syntactically
wrong. :-) What you probably wanted to write is
select A from B where B.ID in (select ID from C)
but a better way of writing that is
select A from B, C where B.ID = C.ID
The nice thing about SQL is that both those statements will probably do
exactly the same thing inside the server.
The thing I'm trying to get you to avoid is putting a query inside a loop
that doesn't involve user interaction. I.e., you shouldn't have a for loop
or while loop in your code with a SQL select statement inside the body of
the for loop unless there's other I/O to read non-database files or take
clicks from the GUI or something.  You should never need to do something like
$first_result = query_mysql("SELECT name from CUSTOMERS")
foreach ($name in $first_result)
    $second_result = query_mysql(
        "SELECT account from ACCOUNTS where ACCOUNTS.NAME=" + $name)
Instead, that should be one query:
select name, account from customers, accounts
    where customer.name=accounts.name
> PoleID1    PoleID2
> 1       2
> 2       1
Well, technically not.
> way?
To prevent this, you'd probably have to use a trigger. The "consistency" in
a database is supposed to be done by having a trigger reject the insert if
the poles in a different order are already there.
That's why you have to take time to think about it: If you just type it in
as fast as you can think, you wind up with something like this and then
you're screwed. :-)
Yes, you can do it that way.
> they are worth.
If you can manage that, it makes things more clear.
For one thing, for example, if you identify cables by (for example) the
poles they're run between in the GUI, you don't have to then go look up the
ID from that information in order to use it elsewhere. If you find that
you're never actually referencing the ID in queries when you're not also
referencing the pole and height, chances are that ID can be replaced by the
pole and height.
That's the goal, yes. That's the idea behind the "C" part of ACID. When you
have a monsterous database that has to live for decades, it's worth spending
weeks or months figuring that bit out. How much it's worth to *you* depends
on how easy it is to clean up mistakes.  If each job essentially starts
over, it might not be worth putting too much time in up front, if you can
just (say) re-import the excel sheets for where the poles are on the third
job if you find the second job messed stuff up too bad.
> going on.
It didn't sound to me like you did.
Exactly. There really isn't an attachment without a midspan or a midspan
without an attachment, nor is there an attachment on just one pole.
> role.
I would say "color" is an attribute that deserves its own table. Assuming
that all colors are equal and don't need any calculations and such, I'd
store the colors in a table with
    ID int, ColorName varchar(20)
or something like that.
This lets you change the color names (boss wants them all in caps) or later
add internationalized names (now you have ID, ColorName, Language in the
table), etc. Plus, it's more space efficient to store an ID number than a
color name everywhere. It also keeps people from misspelling a color and you
wind up having both Green and Gren poles.
When adding family support, I would then add a second table that holds the
allowable families. If each color was in only one family, I would put the ID
of the family in the colors table. Otherwise, I would have a third table
with Color.ID and Family.ID.
Generally, if you have the same thing repeated many times in a table's
column from a small selection of values, but it's *not* a foreign key,
you've probably done something wrong. You probably want a table with that
set of values as its primary key.
You can certainly start out with the color in its own column, then move
things around later when you find it's problematic. You might have some
processing time, taking the system offline for half an hour while you
rearrange the tables and such, but I'm guessing (given you were using Access
before) that this wouldn't be a problem every month or two. :-)
You can even start out with the color as text in the column, later add
another table that has the colors as the primary key and add the FK
constraint, and after that start putting the different translations or
families or whatever on that second column. I.e., where I refered to the
"color.ID" above, you could just use the text of the color name as the ID,
then have the translation or the family or whatever keyed off of that. Only
after space or speed becomes a problem do you really need to worry about
making it into an integer ID or some such.
You should have zero concern about performance. Even a pretty weak machine
should be able to do something with everything in your entire database
several times a minute, let alone individual small groups of stuff.
     "That was fatal?"
Date: 11 Mar 2011 03:43:02
Message: <4d79e096$1@news.povray.org>
Indeed, whilst moving the accuracy is not good enough to determine
whether you're on the motorway or on the slip-road 5 metres to the side
of it, so it assumes you're following the route (if any) or staying on
the road (if no route planned).  Once the receiver knows, with a
specific degree of certainty, that you are on a different road, it will
snap you there on the map.
Once you're more than 10 metres or so away from the route it should snap
instantly, if it doesn't then you've either got a low signal (GPS
antenna positioning?) or a rubbish GPS receiver.
BTW the ones built into the car are far superior as the GPS antenna is
placed in the best spot and it gets input from the steering angle and
wheel speed (so it still works underground and from the second you turn
on the car).  If you've used one you'll never go back to the portable
add-on ones.
Date: 11 Mar 2011 04:26:20
Message: <4d79eabc$1@news.povray.org>
> of it
Which is what I said. GPS isn't very accurate.
> instantly
I haven't measured whether it's 10 meters, but yeah, that's
approximately what it does.
And outside of everybody's price range.
> If you've used one you'll never go back to the portable add-on ones.
Well, you will, because nobody has £80,000 for a car that has one. :-P
Date: 11 Mar 2011 05:16:59
Message: <4d79f69b@news.povray.org>
When you consider that the satellites orbit about 12,550 miles above the
earth and the clock in your Tom Tom is not very expensive. The accuracy
is acceptable IMO.
Regards
Date: 11 Mar 2011 05:25:35
Message: <4d79f89f@news.povray.org>
> earth
...then it's amazing that it can fix your location to the nearest
landmass, never mind the nearest city. I agree. ;-)
Date: 11 Mar 2011 05:42:26
Message: <4d79fc92$1@news.povray.org>
>> earth
> ....then it's amazing that it can fix your location to the nearest
I have used my Tom Tom to navigate around Chester by foot. It saved
memorising a page of the A to Z.
Regards
Date: 11 Mar 2011 05:54:41
Message: <4d79ff71$1@news.povray.org>
Maybe 10 years ago, today navigation is usually an option even on most
B-segment cars (small mini size cars).  I just checked the Renault
website, even on the Clio you can get navigation built-in for £470.  I
imagine in 10 years time pretty much every car will have it as standard
(and obviously more and more 2nd hand cars will have navigation installed).
Date: 11 Mar 2011 11:57:53
Message: <4d7a5491$1@news.povray.org>
It's not GPS that isn't accurate. It's the cheap GPS receiver in your car
that isn't accurate.  GPS has a client and a server and they have to work
together for the accuracy.
     "That was fatal?"
Date: 11 Mar 2011 14:09:50
Message: <4d7a737e$1@news.povray.org>
>> a table reference a particular receipt?
Sounds like a lot of 'extra' data storage, but if a DB is fast anyway,
then the gain of .01s on a query doesn't make a difference.
> particular receipt.
> clerk INT NOT NULL,
> resolution blob,
> on how many timestamps are in the table, and disregarding the fact that
> MySql "NOT NULL" doesn't prevent you from inserting records with NULLs,
> we can look at this structure:
MySQL changes timestamps....  just precision or something else?
> time it was issued. There's also other details, like the clerk that was
> logged in, the amount of the sale, and so on.
> complaint record. This record is identified by the CSR taking the call
> and when they took the call. The complaint is about a particular
> receipt, identified by the register the receipt came from and the time
> that receipt was issued. This may be a follow-up call, in which case the
> CSR has the previous calls about this on the screen and may point out
> that this is a follow-up call from a particular previous complaint,
> Does that clarify?
Yes, I think I am seeing it clearly.  Just store the data as it is.  be
smart about what is picked for the keys and use IDs sparingly.
IDs are great, but they can allow duplicates and potentially break your
DB unless your application is smart enough to prevent the error - but
wait, the goal of a good db is that it cannot be broken no matter what
accesses it.
IDs also require that you get the ID so that you can join on it - even
if you have the other data.  If you have the other data anyway, why go
fetch an ID...
>>> mistake.
>> default.
> inserting two copies of every credit card, or pole, or whatever.
I like the idea of building a database that prevents errors in the first
place.  Let's see if I can get it put into place here.  If so, I think
it will happen over time just because of how fast people like to work here.
> don't know, boss, all the balances are wrong and there's no way to know
> who we billed twice for last week."
We currently have some of this.  But it a balance - is our data good
enough to get the client's requirements done.....  Most of the time yes.
> actually figure out by looking at the database what happened to change
> it, the easier it's going to be to fix problems caused by going fast.
> Just something to keep in mind.
Yes, that's some of the push for simplifying it - but from a usability
standpoint.  I think the person sees how much effort I have put into
coding and how long some things take and wants to reduce that.  The main
problem is that everything was done at lightening speed so it will suck
by definition.
> strongly suspect your boss is just a jerk. :-)
No, the boss isn't a jerk in this case.  We just have a bunch of young
people who don't know how to slow down.  Out of 6-7 people, only 2 of us
are over the age of 26.  If we are to keep the younger crowd, we have to
cater somewhat to their needs/expectations - as long as it moves us in
the right direction.
>>> database engine.
>> avoided?
> syntactically wrong. :-) What you probably wanted to write is
Ok, so I typed it off the top of my head and referenced the wrong table :-)
But at least you knew what it was getting at.
> loop that doesn't involve user interaction. I.e., you shouldn't have a
> for loop or while loop in your code with a SQL select statement inside
> the body of the for loop unless there's other I/O to read non-database
> files or take clicks from the GUI or something. You should never need to
> do something like
Yes, 100% agreed - this should be avoided.  The only way I have any of
this at this point is by putting objects with other objects to make the
objects easier to work with.  I know - there is a better way of doing
this....
>> PoleID1 PoleID2
>> 1 2
>> 2 1
>> other way?
> in a database is supposed to be done by having a trigger reject the
> insert if the poles in a different order are already there.
> in as fast as you can think, you wind up with something like this and
> then you're screwed. :-)
Yes, triggers, I remember those back from my SQL Server days.  They can
do a lot for you - more than just keeping your data straight.  I can't
wait to get back to those and be able to use them as a tool :-)
> the ID from that information in order to use it elsewhere. If you find
> that you're never actually referencing the ID in queries when you're not
> also referencing the pole and height, chances are that ID can be
> replaced by the pole and height.
yes, I do have to 'fetch' the ID from time to time.  I like not having
to do that.  It's just getting things straight enough so that not using
an ID doesn't mess me up too bad.  I don't have as much experience with
setting up keys and making sure they don't mes things up.  Bu that is
something that I am going to be working on :-)
>> - no matter what you try to do.
> you have a monsterous database that has to live for decades, it's worth
> spending weeks or months figuring that bit out. How much it's worth to
> *you* depends on how easy it is to clean up mistakes. If each job
> essentially starts over, it might not be worth putting too much time in
> up front, if you can just (say) re-import the excel sheets for where the
> poles are on the third job if you find the second job messed stuff up
> too bad.
I think for the time being we will be morphing with each job until
things get more stable.  Then we may start putting the data more together.
Well, there is - transformers and cables that are perpendicular to our
direction of travel :-)
>> a role.
> Assuming that all colors are equal and don't need any calculations and
> such, I'd store the colors in a table with
> later add internationalized names (now you have ID, ColorName, Language
> in the table), etc. Plus, it's more space efficient to store an ID
> number than a color name everywhere. It also keeps people from
> misspelling a color and you wind up having both Green and Gren poles.
So on lists like this, an ID is a good idea - and you wouldn't use the
ColorName as the pk/fk.
> the allowable families. If each color was in only one family, I would
> put the ID of the family in the colors table. Otherwise, I would have a
> third table with Color.ID and Family.ID.
yes, a table to group the items according to how they can be grouped (1
2 many, many 2 many...)
> that set of values as its primary key.
OK, that helps.
One can take the ideas of using non ID columns for pks too far.  So, in
the case of colors, go ahead and set up a pk/fk relationship even if it
is the *only* thing in the second table.
> Access before) that this wouldn't be a problem every month or two. :-)
So, if we see it probably needing to be 'broken out' in the future, we
should go ahead and break it out now.
> ID, then have the translation or the family or whatever keyed off of
> that. Only after space or speed becomes a problem do you really need to
> worry about making it into an integer ID or some such.
With what little you know about what we are trying to do, what approach
would you do in this case?  Remember, you know you may want to do
something with color families, but you don't know yet.
> machine should be able to do something with everything in your entire
> database several times a minute, let alone individual small groups of
> stuff.
I agree, it seems that the only way we would need a beast of a machine
is if we somehow make it very inefficient..... but that's a trade off -
development time or hardware cost.....
Date: 11 Mar 2011 18:05:42
Message: <4d7aaac6$1@news.povray.org>
It can be. Like all things, you have to make the trade-off between
readability, reliability, size, and speed.
MySQL basically assumes the first timestamp is the time you last changed the
record, and the second was the time you created the record, or something
stupid like that. You need to read the timestamp documentation.
Basically, MySQL will change your data without telling you, depending on
what order you declared the columns in. Yes, MySQL sucks.
Yep.
> accesses it.
Yep.
> fetch an ID...
Right. Altho the join doesn't have to use the ID.
select * from receipts,sales where receipt.time=sales.time and
receipt.register=sales.register
works even if receipts and sales both have ID columns.
Good job. :-)
Indeed, it's always a balance. That's something a lot of people don't manage
to recognise for some reason.
> by definition.
Time. Cost. Quality.  Pick any two.
Fair enough. Get input from them, teach them why you're doing it the way you
are, and leave places in the system where they can do things the way they
like (say, the GUI) while keeping the database clean.
Yeah.
> this....
Objects inside objects isn't a problem. SQL doesn't really do objects well.
The trick is to encapsulate that in a business layer. The bottom end of the
business layer is the database table definitions, and the top end is the
conceptual things your business thinks about.
I don't think MySQL has triggers.  Heck, you have to go out of your way to
get MySQL to enforce foreign key constraints, let along triggers or views.
Cool. And again, it's mostly just a personal preference of mine borne out by
experience. It's rejecting the concept that every table, by default, must
have and be referenced by an arbitrary integer key.  It's not saying they're
bad, but just "think about it for more than 2 seconds."
Yeah, keep it agile. Keep every version of your schema around so you can
tell what you changed.
Oh, fair enough. But you see what I'm trying to say.  If, logically, you
can't have one without the other, they need to both be in the same row.
Not necessarily. Either an integer or the color name itself would work. This
table is likely not to change often enough to be at risk of being screwed
up, and honestly color names are already pretty arbitrary.
If you had a table of color RGB values, that would be different. Then you're
talking about something "real". But the names themselves are already just
symbols for the actual color, and one color can have multiple names etc.
Yes. The point there is to enforce that all the colors are selected from a
fixed list of possible colors. The text isn't really text, it's an
identifier for a color in textual form. If you store it multiple times in
textual form, it gives an opportunity to accidentally get a piece of text
that isn't a color identifier into the color column.
Now, if you wanted to map colors to unique-names-of-colors (for PANTONE or
something, say), I'd say make the RGB of the color be the PK.
I would write code that accesses the database while being aware that it
might need to be broken out. I wouldn't necessarily break it out now. You
can break it out later, but only if you don't have a big rewrite to break it
out.
Figuring out where the fracture lines lie is experience.
If you have a fixed number of colors (i.e., if you're talking about using
color as a label rather than an *actual* color) then I would put the colors
in a table with an ID and a color label and refer to the ID and not worry
about the families and such.
I.e., if you're talking about "this is a green tag pole, that is an orange
cable, this is a blue-white terminal" then the colors are tags. If you care
about which shade of orange it is because you're mixing matching paint or
something, that's not using the color as a label so I'd have a different answer.
So I would start with the colors in a table with
   ID int, ColorName varchar(50), primary key ID, unique index ColorName.
Use the ID to refer to colors, and you'll have the most flexibility in the
future. Don't store IDs outside the database, tho - always translate them to
color names before sticking them in external files or hard-coding them into
a UI or something.
Yeah, where a "beast" machine is $1000. :-)
     "That was fatal?"
Date: 14 Mar 2011 09:46:23
Message: <4d7e1c2f$1@news.povray.org>
Yes, I gathered that ;-)
Will make any transition easier as ID's don't have to be removed cold
turkey.
> manage to recognise for some reason.
yes, tho even when recognized people may have different notions of what
it should be.
That's our motto to our clients who want all three.
>> the objects easier to work with. I know - there is a better way of
>> doing this....
> well. The trick is to encapsulate that in a business layer. The bottom
> end of the business layer is the database table definitions, and the top
> end is the conceptual things your business thinks about.
Yep, SQL does tables well - if you want objects it has to come from the
outside.
> to get MySQL to enforce foreign key constraints, let along triggers or
> views.
I've been following it a bit over the years - at least some table
formats in MySQL support triggers now.
> a fixed list of possible colors. The text isn't really text, it's an
> in textual form, it gives an opportunity to accidentally get a piece of
> text that isn't a color identifier into the color column.
I think I am grasping the concept.  If you need a 'pick list' you should
have a table with the picklist values.  Storing an ID or piece of text
doesn't matter as long as you have pk/fk set up correctly to prevent
data corruption.
> using color as a label rather than an *actual* color) then I would put
> the colors in a table with an ID and a color label and refer to the ID
> and not worry about the families and such.
That's how I would approach it myself - I just wanted to hear how
someone else would approach it.  Thanks for helping to verify my gut
feelings.
> the future. Don't store IDs outside the database, tho - always translate
> them to color names before sticking them in external files or
> hard-coding them into a UI or something.
Yes, that would not be smart - ID's have no meaning outside the DB.
Thanks for all your input.  You have helped to confirm that my gut
feelings on how to set up a DB are mostly in the right directions.
2 big points I take from this:
Be willing to explore better PK/FK uses.
I have always known that a PK doesn't have to be a number, but it always
felt foreign to use text or some other number as they don't feel as
'precise' as an integer.  I guess I've run into too many cases of trying
to match floats or case sensitive text to let it feel natural.
Design the DB purely from 'what is out there'.  Don't take use into
account (or at least minimize it).
Now for a good DB engine...  I'll start a new thread for that :-)
Date: 14 Mar 2011 12:54:16
Message: <4d7e4838@news.povray.org>
> data corruption.
Exactly. And it gives you a hook to expand on in the future. You have a
place now to talk about colors divorced from where you reference them.
No problem. It helped me clarify how to word explanations too.
Yeah, exactly. You still have to be careful.
The other thing is, if upper/lower case makes a difference, or you're using
a float, those are probably not things distinct enough for a real-world
"unique identifier" anyway.  If you have trouble due to possible confusions
with representation or precision, it's likely not a unique attribute of the
object anyway.  I.e., if upper/lower case can be a confusion because it's
(say) a human's name, well the name isn't a unique identifier anyway. If
you're measuring the height of something and you don't know the precision to
which you have to round it, chances are it's not a unique height anyway.
To use something like an email address, you have to decide how you're going
to normalize it. Even tho RFC822 allows case-specific email addresses, in
practice everybody lower-cases it. If you're talking about GPS coordinates
and you don't have a significant minimum distance between objects, the GPS
coordinates aren't going to be unique anyway.  E.g., telephone poles? Sure,
the diameter of a phone pole is orders of magnitude smaller than the
distance between them.  GPS locations of mail boxes? Probably not what you'd
call unique.
And using a third-party identifier works well too. House addresses, zip
codes, airport codes, phone numbers (plus timestamp of course), etc. If you
can push the authoritative decision onto some other public organization,
you're in good shape.
Yes. This is one of the really important ones that the self-educated guys
tend to mess up.
     "That was fatal?"
Date: 14 Mar 2011 13:20:13
Message: <4d7e4e4d$1@news.povray.org>
On 3/14/2011 12:54 PM, Darren New wrote:
>> should have a table with the picklist values. Storing an ID or piece
>> of text doesn't matter as long as you have pk/fk set up correctly to
>> prevent data corruption.
Now I have to get that through the other guys here <sigh>
you can say that again
> you can push the authoritative decision onto some other public
> organization, you're in good shape.
All good food to chew on.
> guys tend to mess up.
I have no idea what you could be talking about ;-)
