POV-Ray : Newsgroups : povray.off-topic : Random wonderings 0x20c26764ae15b956c9a5eb7c1a237639 Server Time
12 Oct 2024 07:12:55 EDT (-0400)
  Random wonderings 0x20c26764ae15b956c9a5eb7c1a237639 (Message 1 to 10 of 52)
Subject: Random wonderings 0x20c26764ae15b956c9a5eb7c1a237639
Date: 7 Mar 2011 05:15:42
Message: <4d74b04e$1@news.povray.org>
Why do the majority of cartoon characters only have 8 digits instead of 10?
The unit square contains an infinite number of points. But is it
countably or uncountably infinite?
Every Sudoku problem is a graph colouring problem. But is every graph
colouring problem a Sudoku problem? (For suitable size and shape of
Sudoku grid.)
A black hole forms when you have such an insanely vast amount of mass
collected together in one place that it actually collapses under the
sheer force of its own gravitational field, crushing itself into a space
having zero volume and infinite density. So... how *the hell* do you
make a /small/ black hole? Surely a small object wouldn't generate
anywhere near enough gravity to form a black hole.
If the speed of light is constant, how the hell does light undergo
Doppler shift?
Why do almost all species of birds bob their heads when they walk?
What is the purpose of receipts? I mean, seriously, if you're anything
like me, you have hundreds of the damned things. What do you *do* with
actually sit down and *check* these things? For every damned purchase
they make?! [Obviously, for high-value items that you might need to
return, or for goods that your employer is paying for, the usefulness is
more obvious.]
Do spiders have a sense of smell?
Why is it called a "square root"? Surely "square route" would make far
more sense...
Why do only large feathers fall out? I mean, you often find a single
long black tail feather. But birds must have lots of smaller feathers
also. How come you never see any of those laying around?
Who put the dip in the dip, di-dip, di-dip?
Subject: Re: Random wonderings 0x20c26764ae15b956c9a5eb7c1a237639
Date: 7 Mar 2011 06:59:38
Message: <4d74c8aa@news.povray.org>
I've heard its easier to draw 3 fingers than 4. But, really, I dunno.
I suppose you could say that it's an infinite set of all complex numbers
in the range of [0,1+1i)?
> Sudoku grid.)
I don't necessarily think so. Sudoku has a very specific layout.
Take any mass and collapse it down small enough and it'll become a black
hole. Once it reaches a critical ration of mass/volume, then you'll have
a black hole. It may not last too long, or it may; and if it does, it
would be rather irresponsible to create one so close to our own planet.
> Doppler shift?
Same way sound Doppler shifts. the packets of light are either closer or
further from each other depending on the relative velocity of the
emitter and the observer.
Good question. I thought it was mostly just birds from the columbidae
family that did that.
> more obvious.]
Right, you'd need to (at least in the United States) keep certain
receipts for tax purposes. If you purchase items on a debit card, it's
nice to have the slip of paper to take home and enter into your account
register. And, as you said, expense tracking is also another good
reason. Also, you may want to keep receipts to compare against your
account statement to make sure someone didn't pad the bill when they
cleared the credit card transaction.
I'm sure they do, but not as we do. I imagine their palps have some sort
of chemical sense that can pick molecules out of the air. Especially the
free roaming varieties that don't set up a web. They also might need a
sense of smell to find a suitable mate.
> more sense...
Wouldn't the square route be the perimeter of the square? Square root
because it is the root of exponentiation operation. The big number on
the bottom is the root, the little number on the top is the exponent. So
square root makes sense, as does cube root, 4th root, nth root, etc... :)
They're rather light and tend to drift around. I've seen lots of smaller
feathers. Go find a place where birds roost. You'll see all variety of
feathers, especially when they're molting.
The 1950's?
Date: 7 Mar 2011 08:26:27
Message: <4d74dd03$1@news.povray.org>
It is undeniably infinite. But is it countable?
>> Sudoku grid.)
Sure. Regular Sudoku is 9x9. But you can make 'em other sizes (with
other numbers of unique symbols).
But if you have a small mass, why would it be crushed to a small size?
>> Doppler shift?
But the speed of sound is /not/ constant. It changes depending on the
motion of the source and the receiver. Light, on the other hand, has the
seemingly impossible property that the relative motion of source and
receiver somehow makes no difference to the apparent velocity of the
light... but somehow *does* affect its wavelength? WTF?
Seen a chicken walk recently? ;-)
Who the heck has an "account register" just for their personal stuff?
For business expenses, sure. But just for, like, "I went to the corner
shop yesterday and bought a loaf of bread", are you *really* going to
check your bank statement to see if every single transaction like that
was correctly charged? Who does this?
Hmm, you're probably right. I think I recall something about a female
wolf spider's silk having a special taste to it...
>> more sense...
It's the "route" to that square.
> Square root because it is the root of exponentiation operation.
Which just means that the term is used elsewhere too.
A "root" is generally a part of a plant. Whereas a "route", as in, "this
is how you get to this square number", would logically make more sense.
Probably means the original mathematician who worked all this out was
French or something... :-P
Date: 7 Mar 2011 09:07:16
Message: <4d74e694$1@news.povray.org>
> Doppler shift?
Doppler shift is a shift in wavelength, not a shift in the speed the
wave travels.
http://www.loc.gov/rr/scitech/mysteries/pigeon.html
> more obvious.]
Proof of purchase.  Let's say the store clerk reported someone leaving
without paying.  You can show the cops your receipt and say "not me!"
Since another copy of the receipt is printed by the cash register, it
also makes sure that the store owner will be able to keep an accurate
inventory, as well as give the govt the sales taxes he collected from you.
What you do with the receipt once you've left the store is, of course,
up to you.
http://findarticles.com/p/articles/mi_m0EPG/is_n7_v29/ai_17027826/
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 7 Mar 2011 12:07:56
Message: <4d7510ec$1@news.povray.org>
It's easier to draw.
Uncountable. Even the numbers between 0 and 1 are uncountable.
Squeeze something small very hard. Like, during the big bang era, or inside
a nova or something like that.
You have to help.
> Doppler shift?
The frequency of light (so to speak) is related to the energy of the photon.
If you're moving towards the source of the photons, they'll have more energy
and hence look more blue. If you're moving away, they'll have less energy
and look read.
If I had to guess, I'd say it's to keep their eyes still while they're
walking, like a dancer spotting during a spin. However, that's entirely a guess.
To give you a record of what and when and how much you paid for something.
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 7 Mar 2011 12:25:15
Message: <4d7514fb$1@news.povray.org>
Tell me when you're done counting from 0 to 1 in infinitesimally small
intervals.
Right, but, even if it were 25x25 it still has a specific layout. Graph
coloring problems don't necessarily have a consistent number of borders.
An incredible amount of force acted upon that mass?
For the purposes of Doppler shift, it has a constant rate in the medium
it is in. The actual speed the waves move through the medium doesn't
change. The /relative/ speed does change, however. And is the same for
light. Sure, the relative speed of light can even be superluminal. And,
light does travel at different rates in different media. C is simply the
speed of light in a vacuum.
Oh, right. I'm thinking columbidae is unique in how they can tuck their
head ...
Umm, to keep track of what's in your account? I generally do reconcile
my bank statement to my register (I keep mine electronically, so it's
fairly simple to do)
I think this is basic home finance 101.
Isn't the root considered the base of something? A Plants roots are at
its base, for example. for example the root word of unbelievable is
believe. You wouldn't say route in that context, would you?
~Mike
Date: 7 Mar 2011 20:36:27
Message: <4d75881b$1@news.povray.org>
> them? If I buy some petrol, and the receipt says £52.98 but they
> actually changed me £62.51, am I really going to notice? Does anybody
> more obvious.]
Receipts are useful for expense reports (nee required in most cases), and
yes, I do check that what I was charged is what I paid.  That's how you
(a) avoid getting ripped off, and (b) avoid finding yourself in an
overdraft situation.
> more sense...
It seems to have grown out of the old English "Rote" (there's a citation
circa 1425).  Etymologically it derives from the French word
'racine' (which translates to 'root', natch).  "radix" also is used, and
that's latin for 'root'.
Jim
Date: 8 Mar 2011 04:20:00
Message: <web.4d75f370b2c958f62f6daef00@news.povray.org>
That depends on what numbers you are using. The number of points in the unit
square of rational numbers is countable, the number of points in the unit square
of irrational numbers is not.
By the way, IIRC, it is actually possible to constuct a bijection from [0,1]
onto the unit square, meaning there is actually the same number of points in the
unit square as there are points between 0 and 1.
Date: 8 Mar 2011 12:06:44
Message: <4d766224$1@news.povray.org>
Well, of course, yes. And the unit square of integers has a finite number of
points in it. :-P
Yep. There's really only two infinities you get when you talk about
"numbers" - Aleph0 and Aleph1.
     "That was fatal?"
Date: 8 Mar 2011 12:40:01
Message: <web.4d76698ab2c958f6ce07abed0@news.povray.org>
Wasn't the question whether there is a set that is larger than a countable
infinite set and smaller than an uncountable infinite set proven to be
unprovable?
Lovely sentence, isn't it? :D
