![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Random wonderings 0x20c26764ae15b956c9a5eb7c1a237639
Date: 8 Mar 2011 13:07:41
Message: <4d76706d$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Roman Reiner wrote:
>> Yep. There's really only two infinities you get when you talk about
>> "numbers" - Aleph0 and Aleph1.
> Wasn't the question whether there is a set that is larger than a countable
> infinite set and smaller than an uncountable infinite set proven to be
> unprovable?
My memory is that it was thought to be unprovable but later proven to not be
so. However, wikipedia (Cardinal_numbers) agrees with you. Not that it's
unprovable, but that its provability depends on the axioms of set theory you
accept. I suspect it depends in part on things like the axiom of choice, etc.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 13:22:18
Message: <4d7673da@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> countable
>> unprovable?
> not be so. However, wikipedia (Cardinal_numbers) agrees with you. Not
> that it's unprovable, but that its provability depends on the axioms of
> set theory you accept. I suspect it depends in part on things like the
That was my recollection - that the question is provably "independent"
of the standard axioms of set theory. (I believe the axiom of choice is
specifically implicated - although I have no idea WTF the axiom of
choice is.)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 13:23:07
Message: <4d76740b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 07.03.2011 12:58, schrieb Mike Raiford:
> Take any mass and collapse it down small enough and it'll become a black
> hole. Once it reaches a critical ration of mass/volume, then you'll have
> a black hole. It may not last too long, or it may; and if it does, it
> would be rather irresponsible to create one so close to our own planet.
Don't worry - if such an experiment can be conducted by man (and some
say that with the newest CERN particle accelerator it might be
possible), then nature does it all the time as well, thereby having
already proven it a harmless prank.
Essentially, any success in creating an artificial black hole in a
controlled environment with current technology would prove that black
holes do decay over time, as otherwise our universe would already be
full of them.
(I personally favor the idea that leptons, quarks and the like might be
black holes themselves; kind of like the smallest black holes you can
possibly get.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 13:29:27
Message: <4d767587$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> It is undeniably infinite. But is it countable?
> Tell me when you're done counting from 0 to 1 in infinitesimally small
> intervals.
"Countable" doesn't mean that you can actually count them in finite
time. It means that you can assign a unique positive integer to each one.
Now, between 0 and 1 in the rationals, there are a countable infinity of
values. But in the reals (which inclused irrational numbers), there is
an uncountably infinite supply of values.
So I suppose "how many points are there on the unit square" comes down
to "are the coordinates rational?"
>> Sure. Regular Sudoku is 9x9. But you can make 'em other sizes (with
>> other numbers of unique symbols).
> Right, but, even if it were 25x25 it still has a specific layout.
You can make them rectangular, you know. ;-)
> Graph
> coloring problems don't necessarily have a consistent number of borders.
True...
>> But if you have a small mass, why would it be crushed to a small size?
> An incredible amount of force acted upon that mass?
Oh. You mean something *outside* the mass itself causes it to become a
black hole?
But then, wouldn't that just mean that as soon as you remove the force,
it wouldn't be a black hole any more?
>> But the speed of sound is /not/ constant. It changes depending on the
>> motion of the source and the receiver. Light, on the other hand, has the
>> seemingly impossible property that the relative motion of source and
>> receiver somehow makes no difference to the apparent velocity of the
>> light... but somehow *does* affect its wavelength? WTF?
> For the purposes of Doppler shift, it has a constant rate in the medium
> it is in. The actual speed the waves move through the medium doesn't
> change. The /relative/ speed does change, however. And is the same for
> light. Sure, the relative speed of light can even be superluminal.
No, it cannot.
This is exactly what relativity states. The speed of light, no matter
which way you measure it, is always constant. (Except as noted below.)
> And, light does travel at different rates in different media.
This part is correct. And I would expect light entering or leaving a
different medium to exhibit Doppler shift as a result (although it
doesn't seem to do this...)
> Umm, to keep track of what's in your account? I generally do reconcile
> my bank statement to my register (I keep mine electronically, so it's
> fairly simple to do)
> I think this is basic home finance 101.
Wait - you actually use a sophisticated electronic accounting package
just for your home finance?
>> A "root" is generally a part of a plant. Whereas a "route", as in, "this
>> is how you get to this square number", would logically make more sense.
> Isn't the root considered the base of something? A Plants roots are at
> its base, for example. for example the root word of unbelievable is
> believe. You wouldn't say route in that context, would you?
Hmm, I suppose...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 13:31:22
Message: <4d7675fa@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> choice is.)
The axiom of choice essentially says that if you have an infinite set each
of whose elements is a set, you can construct a new set by picking one
element from each of the elements of the infinite set.
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 13:40:52
Message: <4d767834$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Draw a dot at sqrt(2),sqrt(2).
> black hole?
Yes.
No. Science!
(Altho there's arguments over whether quantum effects would eventually make
a black hole too small to form on its own evaporate, but I didn't take that
to be what you meant.)
> No, it cannot.
It can travel faster than the speed of light in the medium in which it's
traveling.
The speed of light in a vacuum is always constant. That doesn't mean it
can't travel faster than the speed of light in the medium in which it is
traveling.
That's not how light slows down. Light slows because it is being absorbed
and re-emitted, not because the speed per se is different in different
media. The train always travels the same speed - but sometimes it stops at
more stations.
Yes. It's not all that sophisticated.
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 13:48:16
Message: <4d7679f0$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 07.03.2011 14:26, schrieb Invisible:
Non-gravitational external force. Smash two particles into each other
hard enough, and you /might/ get them close enough together that they
can't escape each other's gravitational well anymore.
>>> If the speed of light is constant, how the hell does light undergo
>>> Doppler shift?
>> Same way sound Doppler shifts.
That's one of the fun things about Einstein's theory of relativity
(don't know if this one falls into the domain of special or general
relativity).
You can put it like this: In your frame of reference, things buzzing
towards you simply have a faster-ticking clock than things buzzing away
from you (presuming that you define "now" based on when light from
"somewhere" reaches you, rather than "when" it was emitted).
>>> Do spiders have a sense of smell?
Insects do, so I guess spiders do as well - though if they follow the
insect way, then their "noses" are on their legs.
Even more generally, a "root" is something from which something bigger
grows, so it does make sense. Also note that if it was "route", it would
be "route to", rather than "root of".
> Probably means the original mathematician who worked all this out was
> French or something... :-P
Maybe, but he spoke (or at least) wrote Latin. The original word was
"radix" (latin for - guess what - "root"). In German it's "Wurzel",
which also means "root".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 15:03:00
Message: <4d768b74@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I suppose if we're not talking about real, physical space, but about
some mathematical abstraction, it can have whatever properties we define
it to have - including the point you describe not being part of the set.
>> black hole?
> Yes.
Right. So you have to take some matter and mash it somehow?
>> force, it wouldn't be a black hole any more?
> No. Science!
I don't know... Normally if you remove external force, pressure decreases.
>> No, it cannot.
> traveling.
I was under the impression that light does not require a transmission
medium.
> traveling.
I don't understand.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 15:20:43
Message: <4d768f9b@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 08/03/2011 01:36 AM, Jim Henderson wrote:
> Receipts are useful for expense reports (nee required in most cases),
Agreed. In a commercial context, you want to keep track of this kind of
thing.
> and
> yes, I do check that what I was charged is what I paid. That's how you
> (a) avoid getting ripped off, and (b) avoid finding yourself in an
> overdraft situation.
So, what, you literally sit down and check all of the thousands of
transactions you make, one at a time, to make sure every single one
matches the printed recipt?
Doesn't that take an insane amount of time?
>> Why is it called a "square root"? Surely "square route" would make far
>> more sense...
> It seems to have grown out of the old English "Rote" (there's a citation
> circa 1425). Etymologically it derives from the French word
> 'racine' (which translates to 'root', natch). "radix" also is used, and
> that's latin for 'root'.
I knew it would be French! :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2011 15:24:26
Message: <4d76907a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, sure. But if you're going to start screwing with the defintion of
"unit square" rather than using the standard "set of points whose X and Y
are both from 0 to 1", then the answer comes out of your definition and you
don't have to ask.
Plus, I'm not sure that physical space is actually continuous, so it's
possible such a square doesn't have a sqrt(2),sqrt(2) point either.
>>> black hole?
>> Yes.
Basically. You can do it by taking some matter and slapping it together so
forcefully it overcomes the non-gravitational forces. I'm not sure that's
physically possible in the universe as it exists today.
>> No. Science!
It's not pressure. It's gravity.
>>> No, it cannot.
>> traveling.
> medium.
It doesn't. But it does have different speeds in different media. Otherwise,
you wouldn't have prisms and lenses and such.
>> traveling.
> I don't understand.
The speed of light in a diamond is less than half the speed of light in free
space/vacuum. Hence, it's possible to move through a diamond at faster than
the speed of light in a diamond but slower than the speed of light in a
vacuum. Hence, superluminal travel, for some definition of that word.
http://en.wikipedia.org/wiki/Cherenkov_radiation
It's what gives the weird blue light coming out of nuclear reactors
underwater - particles from the reactor hitting the water at speeds faster
than the speed of light through water.
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
