POV-Ray : Newsgroups : povray.off-topic : Friday WTF Server Time
4 Jul 2026 08:59:02 EDT (-0400)
  Friday WTF (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Friday WTF
Date: 21 Feb 2011 04:13:23
Message: <4d622cb3$1@news.povray.org>
On 21/02/2011 08:19 AM, Le_Forgeron wrote:
> Excel is a sandbox: it make nice graphics (yet not all of them keep
> being available across its versions) but is usually overused for database.
> It's fine to use excel as a sketch, but any real production should stay
> away from it. Alas, it's so eye-candy that it usually stays with the
> uneducated people in charge (like CEO and other administrative/marketing
> people).
It's true enough that my company's IT department keeps *all* of their
records in Excel spreadsheets. License keys, user account records,
everything like that... all spreadsheets. Never mind that only one
person can work on it at a time and that people can screw up each
other's updates and all the rest of it. How hard would it be to put this
stuff into a trivial Access database? Not very. But apparently our IT
department is too stupid to understand why this would be a good idea.
For my part, the entire reason that I'm using Excel is that I *want*
graphs. If it were somehow possible to make gnuplot draw graphs from CSV
data, I'd use that. (It's scriptable, after all.) But since it isn't,
I'm stuck with Excel.
Date: 21 Feb 2011 09:06:43
Message: <4d627173$1@news.povray.org>
Your friend on unix would be ploticus.
The script can read a separated data file in csv...
scripting in ploticus has a strange learning curve, best to copy & paste
from their gallery then play a bit.
For the lazy and/or always overbooked people:
http://ploticus.sourceforge.net/doc/welcome.html
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 22 Feb 2011 06:15:06
Message: <4d639aba$1@news.povray.org>
>> people).
Excel is good for simple databases with infrequent updates for many
reasons, the most important is that almost everyone has it installed on
their machine and most people are familiar with it.  If you store the
Excel file on a network drive it will get backed up regularly and ensure
that only one person can edit it at a time.
There are also more advanced features to lock ranges of cell based on
who is logged in if you want to limit certain parts of the database.  We
use this on a couple of files where managers have to authorise certain
items (it prevents non-managers from changing those cells).
If you have no experience with Access it's not trivial to set it up
properly, and if the only perceived benefit is that more than person can
edit it at a time it's unlikely to be seen as worthwhile.
Probably they just have other stuff to do they think is more urgent.
Date: 22 Feb 2011 06:28:37
Message: <4d639de5$1@news.povray.org>
> reasons.
It's like the fact that all screenshots are always emailed as Word
documents, even though it takes up far more space. It's just that nobody
knows any better.
We don't use that feature at all.
(Unrelated, but... I was astonished when I discovered how hard Access
security sucks. Excel is much better at this.)
> properly,
True. But we're talking about the IT department here. If we don't know
how to work it, what hope is there?
The other benefit of course is that you can trivially sort the data
without screwing it up. (Excel makes it very easy to accidentally sort
one column only, muddling up all the data.) It also makes inserting or
deleting records vastly easier. (The same goes for adding or removing
columns.) Don't even get me started on how difficult it is to
cross-reference data in a spreadsheet. (Although admittedly it's
unlikely you need to do that very often.)
This is from the department that has set most of our admin passwords to
"our1Tr0x!"...
Date: 22 Feb 2011 06:45:56
Message: <4d63a1f4$1@news.povray.org>
Err, you did turn on filtering first on your table (select the header
cells and click Data->Filter)?  This makes sorting and filtering a
no-brainer and AFAIK prevents people from sorting the data incorrectly.
If you need to cross-reference beyond simple drop-down selection lists
then you're probably beyond what Excel can easily offer as a simple
database.
Date: 22 Feb 2011 07:03:58
Message: <4d63a62e$1@news.povray.org>
Really? I had literally no idea that was possible. In 15 years of using
Excel, I didn't know about this. (I wonder how many other people didn't.)
Rather than clicking on an unintuitive command name buried in a menu, if
you click on the big "sort ascending" button right there on the toolbar,
it can *totally* mess up your data. Fortunately there's an undo button.
(I wonder how many people know that?)
> database.
I meant stuff like if you have one spreadsheet with all the license
keys, and another spreadsheet that tells you when each product was
purchased, you're going to have fun trying to link one to the other.
With a real database this would be a trivial table join.
(On the other hand, databases generally *need* to do joins more often
because the data is usually normalised - something people don't bother
with for Excel.)
Date: 22 Feb 2011 09:51:07
Message: <4d63cd5b@news.povray.org>
Odd, I've seen this used on pretty much every "database" style Excel
workbook from several different companies.  Particularly for "action
list" type databases where it's essential to be able to easily filter
out certain rows.
Yes, it's quite tricky to get two tables linked in the same way a proper
DB would do it whilst keeping the GUI friendly, but usually there is an
easy enough hack using the lookup and data validation stuff that works.
Date: 22 Feb 2011 11:47:15
Message: <4d63e893$1@news.povray.org>
I guess fundamentally it just irks me that supposed IT "experts" are
using the wrong tool for the job. I don't suppose an Access database
would actually be any faster to access over an encrypted WAN link,
that's for sure...
Date: 22 Feb 2011 11:49:09
Message: <4d63e905$1@news.povray.org>
I read a while ago that while LOTOS 1-2-3 and visicalc were putting in
ever-more sophisticated math stuff, MS went and looked at how people were
actually using the product and realized some surprisingly large number of
spreadsheets had no formulas at all. So MS made it easier to keep lists of
stuff in Excel, and that's part of why it won out over those others.
Actually, I think nowadays you can set it up for multiple edits and it'll
coordinate. It seemed simple, but I never had two people actually try at
once, so take it with a grain.
Last I looked, Access was only one user at a time making changes too. The
one guy would lean back in his chair and bellow "IS THERE ANYONE IN THE
DATABASE?"  That was their locking protocol.
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 22 Feb 2011 11:56:08
Message: <4d63eaa8$1@news.povray.org>
> were actually using the product and realized some surprisingly large
> number of spreadsheets had no formulas at all. So MS made it easier to
> keep lists of stuff in Excel
That wouldn't surprise me.
Perhaps. I can well imagine people being too stupid to work out how to
use a proper database product...
> it'll coordinate.
I've never seen that.
> The one guy would lean back in his chair and bellow "IS THERE ANYONE IN
> THE DATABASE?" That was their locking protocol.
I spent six months watching a group of three people in an office. They
had an Access database, which everybody had constantly open all day. So
clearly that's not the case.
On the other hand, I have seen "error - database in use", so I'm not
sure what's up with that...
