![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> So how come BluRay disks are 5x the storage capacity, yet still have
> roughly the same run time? I thought it was because HD video requires
> more space to store.
On DVDs you'd be limited to under 2 hours if you used the maximum
bitrate (around 10 MBit/s IIRC), so you are forced to use lower bitrates
if you want to include menus and other various extras on the disc. With
BluRay, even if you used an average of 30 MBit/s (which is extremely
high quality with h264, and likely never actually needed, it usually is
around half that) you have about 4 hours run time. This is why you can
fit two versions of an entire film (eg 2D and 3D version) on a single
disc, plus all the extras. That would be impossible on DVD.
> I thought it was more or less the case that *all* codecs work by
> transforming the input, deciding how "important" each signal component
> is, and then keeping only the most important bits, according to what the
> requested bitrate was. I don't see anything there that makes a higher or
> lower bitrate change the amount of compute power required.
The whole point of video compression is trying to find patterns
frame-to-frame to reduce the information needed to reconstruct the
correct video (otherwise you'd just have a series of JPEG images). The
longer and more detailed you search for such patterns, the lower bitrate
you will be able to achieve for a given level of quality, or
equivalently higher quality for a given bitrate.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> Ah, but what's this I see? A "privacy filter"? Yes, it's a small piece
> of plastic which is transparent only when viewed from certain
> directions. In other words, you stick it to your screen to reduce the
> viewing angle. WTF, people!? :-D
What part of "privacy" did you misunderstand?
> First of all, it's supposedly a video camera, and yet it costs less tha
n
> £2,000. Actually, it costs less than £500. To be blunt, it co
sts £75.
> This is highly suspicious.
Let me blow your mind:
http://www.dealextreme.com/p/usb-rechargeable-1-3mp-pin-hole-spy-av-camer
a-disguised-as-sunglasses-tf-slot-42736
> Quite why anybody would pay for an expensive 2MP photosensor and then
> stick it behind a crappy 7mm lens I have no idea.
I've never understood that, unless a 2MP photosensor is actually cheaper
in
bulk than a lower quality one.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> OK, so you can change the frequency weightings and how often a keyframe
> is put in, and so forth. I'm not seeing much that fundamentally changes
> the whole algorithm such that it might require less computer power.
Making every frame a keyframe reduces the computing and memory you need. Not
using any B frames significantly reduces the amount of memory you need. Not
doing motion prediction reduces how much compute power you need. (At least
for MPEG. I don't know H.264, but I'd assume it's similar.)
> (Although, as I say, I imagine the really hungry bits probably
> have custom hardware acceleration in a device like this.)
Exactly.
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I've never understood that, unless a 2MP photosensor is actually cheaper in
Well, as technology advances it often quite ironically happens that
the older some technology gets, the more expensive it becomes to purchase.
The reason is simple: Lack of demand reduces supply, and low supply means
that the product becomes expensive to produce. Production lines get
upgraded for the newer technology (if not even dismantled outright), so
the older technology becomes more difficult to produce.
Thus the price of most technology experiences a strong U-shaped behavior
as time passes: When the technology is brand new, it's extremely expensive
(both because production costs are still high due to the lack of cheap
production lines, and to capitalize on the eagerness of early adopters).
Then it quickly gets cheaper and cheaper, until it reaches the bottom of
the price valley (and depending on the product it can become almost
ridiculously cheap compared to its original price). Then it stays there
for some time, and when the technology gets more and more obsolete, and
demand decreases, it starts becoming once again more and more expensive
to produce. Depending on the product, it may at some point become impossible
to purchase anymore (because nobody is making it), or extremely expensive
(even more expensive than when it was brand new).
This is the reason you eg. don't find half-gigabyte USB memory sticks
anymore, even though one could think that they would be very cheap to
produce. In fact, they might not be. They might actually be pretty
expensive to produce, which is why nobody does anymore.
It may also explain why it's cheaper to produce a camera with a 2MP
sensor than one with eg. 1MP.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That was what I had intended to imply, yes. :-)
It's more that the technology requires a shake-down period. Yields are
tremendously low until every one of the hundreds of precise steps gets
adjusted just right. A 10% yield on early runs is a good number.
You're also paying off the design. I have a friend who designed RISC chips
for one of the big CPU companies before ARM bought them out, and he told me
about half the cost of a chip over its lifetime is design costs. That is, if
you sell a total of $100million worth of CPUs over its lifetime, it costs
about $50million to design them and $50million to manufacture and distribute
them.
Oh, and if anyone cares, here's what the video from those glasses looks like:
http://darren.s3.amazonaws.com/PICT0001.AVI
http://darren.s3.amazonaws.com/PICT0003.AVI
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> The reason is simple: Lack of demand reduces supply.
I don't recall the details now, but the other day I discovered that
something like 128MB of PC100 RAM is more expensive than 1GB of PC3200.
Or similar. Which is quite bizarre, really...
Alternatively, if you're actually buying PC100, it means you have
something really critical that you need to keep working. (Rather than,
say, just replace the damned PC.) And if it's that critical, they can
charge you "sucker fees" (i.e., whatever they charge, you just have to
pay it, because you need it that badly).
In general though, I was under the impression that most technologies
don't dissappear, they just move down the food chain. For example, the
Z80 is still in production. It's extremely popular, apparently. And
rather cheap too. (I have no idea what the original sale price was, but
currently it's a few quid.)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Intel stopped producing the 80386 a few years ago, so it does happen
with some products.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> with some products.
I've seen printers and so forth that use old x86 CPUs inside. I wonder
if Intel stopped manufacturing the 386, or just licenced the design to
somebody else?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The Z80 is the CPU of choice for things that need a low-power CPU. Like,
digital voice recorders, toasters, remote controls, etc.
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 25/01/2011 06:28 PM, Darren New wrote:
>> keyframe is put in, and so forth. I'm not seeing much that
>> fundamentally changes the whole algorithm such that it might require
Presumably the bitrate is going to skyrocket if you do that though.
> Not doing motion prediction reduces how much compute power you need.
Does the standard actually allow that?
(Now that I think about it, the decoder algorithm is usually far more
tightly specified than the encoder...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
