![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is strictly a matter of curiosity, as the problem has gone away without any
action on my part. For two and a half days, I had extremely limited internet
connectivity... with odd symptoms unlike any problem I've experienced before.
If there's any kind soul out there in POV-Rayland thinking "Aha! I recognize
that", I'd very much appreciate any sharing of insight.
Here's what happened...
I come home from work on Friday to discover that my internet connection, which
is provided via cable modem through a company contracted by my local
municipality, is connecting very slowly to a few sites and timing out with all
the rest. On the POV-Ray site, for example, I could get the home page, but
"Support" would always time out. I did the usual restarts and checks, my system
(XP Pro) continuously insisted my network connection was just fine. "Ping" and
"tracert" tests repeatedly returned normal results. I spent nearly thirty
minutes on the phone with a support tech who seemed reasonably competent. No
other customers in my area were reporting similar issues. We tried powering
everything down and up (again), releasing and renewing the IP address as well as
assigning a static IP address. Nothing changed the connection status. We gave
up and made an appointment for a physical service call.
The situation continued throughout Saturday and Sunday. On Monday morning I
discovered that the connection was gone entirely. I did yet another standard
power down and up of the cable modem and, lo and behold, POOF! the problem is
gone like nothing was ever wrong.
Does this sound familiar to anyone? If it happens again, is there something
better to do about it than just wait patiently? Thanks in advance for all
replies.
Best Regards,
Mike C.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Question for network people - esp PHY & Data Link (maybe)
Date: 17 Jan 2011 08:33:26
Message: <4d344526@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Not really. Although at one time I had a router and I discovered that
reading a specific post on this newsgroup would reliably and repeatedly
crash the router. (WTF?) As in, trying to read the post would cause the
router to suddenly stop responding to all network traffic. Reboot and it
works again. Really frigging weird...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 17 Jan 2011 09:11:24
Message: <4d344e0c$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> replies.
> Best Regards,
> Mike C.
1) Did you ping with the regular 64 byte packets, or did you also try
larger packet sizes? If your line is noisy, larger packets will be mroe
enclined to suffer from it, statistically speaking. This is why a ping
test can look ok, but loading a web page is troublesome.
2) How was the weather like in your area on friday?
2.b) was there any power interruption?
3) Did your customer service rep mention anything about signal/noise ratio?
I ask this because I recently experienced something very similar, and it
turns out that the neighborhood signal booster died during a
thunderstorm and the signal coming from my modem was so faint that 9
times out of 10, they wouldn't even pick it up.
The CS rep also initially gave me the "none of your neighbors are
reporting the issue" line, to which I replied, "of course... they're all
at work. I'm the only one in my area that works from home". After a
little digging, he found out that the non-VoIP in my area were all
having the same problem as I did, and was able to confirm that VoIP
customers have a different make of router, one that seems to be less
affected by S/N problems.
Depending on your local carrier's network monitoring tools and the
skills of their operations staff, they may or may not be able to link
their network monitoring system warning them that booster unit AE-1135
is about to lose battery power, with customer calls in the neigborhood
of 243 Evergreen Terrace, so it's possible that their repair crew fixed
the problem on the pole last night without the guy to whom you spoke on
staurday knowing there was even a problem there to begin with.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> larger packet sizes? ...
No, didn't think of it.. good advice / will remember... thanks.
> 2) How was the weather like in your area on Friday?
No power interruptions, no drastic weather conditions.
> 3) Did your customer service rep mention anything about signal/noise ratio?...
> reporting the issue" line...
I'm familiar with the CS rep disinformation issue. That's why I asked the same
question of my *local* municipal service office. You can really count on the
phones there lighting up like Christmas trees if there's a local issue. It did
seem that it was just me reporting on a Friday afternoon when many users would
be online.
> is about to lose battery power, with customer calls in the neighborhood
> Saturday knowing there was even a problem there to begin with.
Although I wouldn't be able to be anywhere near as specific as you were, I was
tending to suspect something along similar lines, that an infrastructure issue
not visible to the Tech Support rep arose and was eventually fixed.
Thanks much for all the input. I'm feeling a bit less bewildered.
Best Regards,
Mike C.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 17 Jan 2011 12:53:31
Message: <4d34821b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Did the post have +++ATH in it? ;-)
Serving Suggestion:
"Don't serve this any more. It's awful."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 18 Jan 2011 04:06:30
Message: <4d355816$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> repeatedly crash the router. (WTF?) As in, trying to read the post
>> would cause the router to suddenly stop responding to all network
>> traffic. Reboot and it works again. Really frigging weird...
Nope. Actually, it didn't have much interesting in it at all. At first I
thought it was coincidence, but I was able to reliably repeat it. One
particular post, same one every time. Really odd.
You'd expect better from NetGear, but apparently not...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
