http://www.haskell.org/communities/11-2010/html/report.html
Well, there goes the rest of my week...
So far I've already read about all manner of crazy stuff:
+ GHC 7.0 is in development, featuring more new bells & whistles than is
sane for any one system to have.
- The "Jenga" of the type checker has been replaced.
- Improvements to the inliner yield 80% speedups in some cases.
- There's a new LLVM backend.
- There's a new, faster I/O subsystem.
- A long-standing glitch with Parallel Strategies has been fixed.
(And in the process tonnes of new functionality is available.)
- There's work on improving numerical performance (finally!)
- I read a paper where somebody benchmarked the standard containers
library and managed to make it go about 25% faster.
- We might finally get concurrent GC too.
- Microsoft Research is funding further development of Haskell's
parallel capabilities. (!) There's some talk of an MPI binding.
- There's more DPH improvements.
- Tonnes of other stuff too small to mention.
+ UHC (the Utrecht University compiler for Haskell) contains a bunch of
interesting stuff. Most particularly, they're using an interesting
Attribute Grammar for performing tree transformations. It turns out this
is simpler and easier than writing the transformations in Haskell -
which is rather surprising, given how good Haskell is at data
transformations...
+ There's a big long paper about The Reduceron. It's basically an FPGA
processor for running Haskell (or something like it).
- First there's a great long section where they explain their design
decisions and various theoretical benchmark results.
- Then they describe the actual design of the hardware, and the
various decisions they chose there, and what the final thing looks like.
- Finally they measure the performance of the thing. And it's not too
shabby. A program running on the Reduceron is about 4x slower than the
same program compiled with GHC and running on an Intel Core 2 Duo at
3GHz. Which is very, very impressive when you consider that the
Reduceron runs at a piffling 96MHz. (!) On the other hand, no
floating-point support yet...
God only knows what I'll find when I scroll down further...
Invisible escreveu:
> - A long-standing glitch with Parallel Strategies has been fixed. (And
amazing news, huh?
concurrent GC is almost as hard as solving a halting problem... ;p
that SPJ guy sure has some ballz.
whoa!
how about an OpenCL port. ;)
a game sig: http://tinyurl.com/d3rxz9
> amazing news, huh?
Have *you* tried it? :-P
Seriously, analysing the structure of a huge chunk of data while it's
still being modified is no picnic.
I said MSR is funding it. I didn't say why. It might be nothing to do
with SPJ. There /are/ other people getting paid to use Haskell, you
know. ;-)
> whoa!
Oh, I gather somebody's doing that for their PhD thesis...
But still, modern CPUs are especially designed for the way normal
programs work. Functional programs work in a totally different way;
maybe by designing the hardware differently, it can go faster? It's
worth at least trying it out to see how it goes.
...and now I'm reading about Agda, a programming language which has
MELTED MY MIND! >_<
> > amazing news, huh?
If Haskell requires a garbage collector, it means that objects are not
strictly scope-bound (in other words, objects can outlive the scope where
they were creted, rather than being automatically destroyed when the scope
ends). This, consequently, means that objects are not handled by value, but
by reference (or pointer, or whatever you want to call it), which is a
requirement if you want to share the same object with more than one other
object. I know next to nothing about Haskell, but the little I have seen
doesn't look like it would be reference-based code. It *looks* to me like
everything is handled by value.
Could give a simple example which demonstrates the need for a GC?
Warp escreveu:
>>> amazing news, huh?
kinda weird your reasoning there. Java passes things by reference and
still needs a GC. I don't quite see the linking between the need for a
GC and passing things by reference or by value.
In normal Haskell code, all data is immutable. It's therefore impossible
to tell whether it's being passed by reference or by value; either
choice makes no difference to the end result. It only affects
performance. This is probably why Haskell "looks like" it passes by value.
I always used to think that creating a data structure who's size is not
statically known required handling it by reference. However, C++ somehow
manages to do this by value, so it seems my assumptions are incorrect.
In fact, thinking about it, you probably /could/ implement Haskell
without GC. It would just be far less efficient, that's all.
Anyway, as an example: Consider the function
linear a b x = a*x + b
You probably think that this function takes three numbers and returns a
number computed from them. Strictly speaking, this isn't true; in fact
this function takes three numbers and returns /an expression/ containing
them. What the caller actually gets back is a reference to the root of
an expression tree. For example, if I do "linear 2 3 5", I get back a
reference to the root of a tree that looks like
* 3
2 5
If I try to /use/ this value, this will execute the (+) function. The
first thing this does is inspect its arguments, which causes the (*)
function to execute. After it executes, the tree looks like
10 3
2 5
There are now two items of garbage: the 2 and the 5. Further, after (+)
finishes executing, we have
13
10 3
2 5
So now there's 4 items of garbage (2, 5, 10, 3).
The real situation is of course a bit more complicated than this, but
you get the idea.
nemesis <nam### [at] gmail com> wrote:
> Warp escreveu:
> >>> amazing news, huh?
> still needs a GC.
Isn't that what I said above? You write as if I had said the exact
opposite (ie. that languages using references don't need GC).
If you handle objects by reference, and you can pass references around,
it means that objects can be shared and that the lifetime of these objects
is not bound to the scope where they were created. If objects outlive the
scope where they were created, you need some kind of GC to destroy them
(unless the language is such that leaking objects is ok).
No, dynamically allocated objects can only be handled with a pointer.
You can of course wrap that pointer so that it looks and behaves like
the allocated object itself, but as if handled by-value (including being
scope-bound).
For example you can handle an instance of std::vector or std::string
by value, but internally they contain a pointer to dynamically allocated
memory (which they manage).
It would be less efficient because it would require always deep-copying
data when it's passed around?
> * 3
> 2 5
> 10 3
> 2 5
> 13
> 10 3
> 2 5
> you get the idea.
It looks like a really inefficient way of computing a simple calculation.
Warp escreveu:
doh! I read it wrong...
