http://hackage.haskell.org/trac/ghc/blog/LetGeneralisationInGhc7
"The old [engine] had grown to resemble the closing stages of a game of
Jenga, in which making any change was a delicate operation that risked
bringing the whole edifice crashing down. In particular, there were a
dozen open bugs [...] that I had no idea how to fix."
I think that's a really amusing quote. How many of you have worked on
programs that look like "the closing stages of a game of Jenga"? :-D
I'm working on one right now.
~Mike
My God have mercy on your soul.
Invisible escreveu:
I believe any software eventually reach that stage. The more you add,
the more complex, the more resistent to change, the more ugly, the more
fragile to subtle bugs. Its inertial mass at work...
a game sig: http://tinyurl.com/d3rxz9
And it certainly doesn't help when project managers get evangelized into
believing that methodologies like "rapid prototyping" will help making
better programs.
I would argue that it varies depending on what precisely you're trying
to add, how carefully you add it, how well the program was designed in
the first place, how often you go about code reorganisation / tidy-up,
and so forth. I don't think it's as simple as "all code eventually
becomes unmaintainable" (although there's certainly a very considerably
tendency in that direction).
> better programs.
Uh, no, not really.
Rapid prototyping /can/ be very useful for figuring out exactly what you
do and don't want from an application. And iterative prototyping (which
isn't the same thing) can be useful for trying out design alternatives.
But no, Rapid Application Development and similar management buzzwords
do not magically solve computer programming. (Quite the contrary,
usually...)
Actually, I come to the conclusion that if you look at most of the XP and
other Agile-style stuff, the main thrust is to let management slack off of
managing, and have employees who are decent coders but shit programmers, and
still think you can create something usable. Which might work if there's
only one customer for the software.
Serving Suggestion:
"Don't serve this any more. It's awful."
> > better programs.
> Uh, no, not really.
Well, that's the theory, and that's why so many project managers get
infatuated with the idea. Also, it helps catching design mistakes early
in the project, saving a lot of work (because the later in the project a
mistake is caught, the harder and more time-consuming it is to fix it).
At least in theory. The practice, however, can be quite ugly. What usually
happens in reality is something like this:
First the programmer is given a basic ascetic description of the program,
and the programmer makes a small prototype. Then new ideas start pouring in,
"add this and this... and let's also try this small thing... add a button
that does this". Each time a new small feature request comes in, does the
programmer start from scratch, or does he simply add the feature to the
existing prototype? Most probably he won't start from scratch just to add
a new small feature.
Thus the project advances. What started as a small, lean&clean prototype,
with nice little modules and functions, starts slowly but steadily growing,
as more and more small features are added and modified. Almost imperceptibly
the program grows into a humongous behemoth full of spaghetti code. The nice
200-line modules grow into huge 2000-line modules (and that's if the
programmer is being conservative and frequently splitting features into
new modules), and the dependencies between modules become more and more
complicated.
At some point the program will have become a monster. Basically a huge
pile of small prototypes built onto previous prototypes, small kludges
added to previous kludges. The time has come to throw everything to the
trash and start from scratch. However, there are these things called
deadlines. Managers want results. They don't want programmers spending
the next two months starting the project from scratch. This is especially
so because the managers want *rapid* prototyping. They don't want to wait
two months for a new prototype.
So the programmer keeps adding new features to the monster. This is
becoming increasingly laborious, but they try to cope. The end result is
a horrible and unmaintainable mess. Probably more horrible than what would
have been done with a more traditional development model.
> in the project, saving a lot of work.
Yeah, that's the theory.
From what I've seen, the theory goes wrong when one of the following
happens:
- You throw together a quick "prototype", which somehow becomes "the
final application", and you end up having to actually "support" this thing.
- The program gets so many feature requests that the entire scope of the
program is fundamentally altered. Sometimes a program designed for X
ends up having to do Y instead (where X and Y aren't really related),
but a much more common paradigm is where a program designed to do X ends
up being required to do X, Y, Z, W, K, R, J, L, S and V. And maybe you
could add F as well? By the weekend?
- Management think that "rapid prototyping" means "we can get away with
one tenth of the usual development time and one hundreds of the manpower
and still produce a working product". Uh, no, no you cannot.
Ah yes, the source of a million bugs...
I have a slew of them I have to support
They started as a very good idea that was decently cleanly coded, but
then ad-hoc requirements and programming made them into the beast that
they are.
I got to the point where I told my boss I could not change the programs
any more. We had a couple of incidents where his 'request/requirement'
caused the program to overwrite it's own data. Basically a couple of
days worth of work to re-do.
Really scary - especially when the bogus data makes it out to the clients.
