POV-Ray : Newsgroups : povray.off-topic : Mini-languages Server Time
20 Jun 2026 02:27:38 EDT (-0400)
  Mini-languages (Message 99 to 108 of 108)
Subject: Re: Mini-languages
Date: 15 Nov 2010 16:42:07
Message: <4ce1a92f@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   Basically, preprocessor macro expansion should never create new tokens
> > unless the token pasting operator (##) is explicitly used to do so. However,
> > Microsoft's C preprocessor doesn't take this into account at all.
> I see. I can see where that would (A) really annoy and confuse people
> expecting the standard behavior and (B) would really annoy people who relied
> on it if it got changed. :-) All the more reason to make sure stuff works
> before releasing it.
  I have really hard time believing that they aren't fixing it because they
don't want to break existing programs. I can't think of a rational situation
where you would *want* the buggy behavior of the preprocessor. It can only
be used for obfuscating code (for example, you don't expect something like
"-x" to really mean "--something_else"; that would be obfuscating beyond
belief).
Date: 15 Nov 2010 18:04:59
Message: <4ce1bc9b$1@news.povray.org>
Well, there's always the possibility that they just don't find it
economically worthwhile. But yeah, you'd be surprised at what existing
programs rely on, bugwise. :-) I *don't* think it's because they can't
figure out how to fix it. I think it's an intentional business decision, for
whatever reason, not a "our compiler writer guys can't figure out how to fix
this."
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 15 Nov 2010 18:33:11
Message: <4ce1c337@news.povray.org>
> this."
  Since this sidetrack started with you being surprised why compiled
regexps in .NET present exponential behavior (when it's possible to make
them linear-time), are you suggesting that the reason for that *is* because
they don't know how to (in contrast to this C preprocessor issue, which
might have economic reasons behind it rather than competence reasons)?
  Whatever the reason for either one of these two things might be,
my suspicion is that the reason is primarily laziness in both cases:
They could figure out how to do it properly, and they could implement it
properly, but they won't bother because it works "well enough" as it is
now. That's why I brought up this C preprocessor issue as an example.
Date: 15 Nov 2010 19:29:21
Message: <4ce1d061$1@news.povray.org>
No, that I put down to laziness. ;-) The .NET regexp engine support
backreferences (i.e., non-regular regexps), which you can't do without
backtracking. I was simply surprised they put in enough effort to turn an
"interpreted" regexp into a compiled regexp without special-casing the
presumably common case of not having back-references.
Maybe I'm wrong and simply being able to extract groups is enough to require
backtracking, and MS looked and saw the number of regexps that didn't
extract groups but had this sort of behavior was low enough not to bother.
I imagine this may be also "economic" reasons in that they didn't have time
to do a better job or something? Dunno.
That's why I was surprised.  FWIW, I'm also surprised that the token parsing
is broken. I'm less surprised they don't *fix* it, is all. I mean, hell, *I*
can think of trivial ways to fix it - just put a space around each argument
you substitute in, unless it's with a # or ## operator.
Well, I'm guessing "laziness" of the original implementors in the first
case. I'm guessing it's not "laziness" for *fixing* the tokenizer, and more
"well enough" at this point.
I.e., I don't think reported bugs get left in because they're too lazy to
fix it. Not enough economic incentive, maybe, which you might equate to
"laziness" in your terminology, but which I'd call "not worth fixing"
instead. But an active decision not to fix isn't what I'd call "lazy". But
that might just be a terminology issue.
Whereas the regexp thing, I don't think that decision was likely made after
the code was already released. It might have been "we don't have time" or
"we don't think it'll help enough people" or even "if I bring it up, I'll
wind up having to do it", all of which I'd classify as "lazy". But I think a
manager telling the programmer not to program something isn't "laziness".
   Serving Suggestion:
Date: 16 Nov 2010 06:32:01
Message: <4ce26bb1$1@news.povray.org>
> after the code was already released. It might have been "we don't have
> time" or "we don't think it'll help enough people" or even "if I bring it
> up, I'll wind up having to do it", all of which I'd classify as "lazy".
> But I think a manager telling the programmer not to program something
> isn't "laziness".
Reading several MS blogs it becomes obvious (if it wasn't already) that they
have a limited amount of resource.  There are many things the developers
would love to do, but they (or rather their managers) simply have to make a
choice what to work on.  And of course they have to release software,
because if they don't more people complain than if they release it with some
feature not implemented or buggy.
Date: 16 Nov 2010 12:05:47
Message: <4ce2b9eb$1@news.povray.org>
> they have a limited amount of resource.
Yeah. I wouldn't call that "lazy" is all. :-)
The reason I was surprised at the regexp result was that they spent I'm sure
a lot more time implementing a compiler for them than they would have
implementing a better algorithm.
   Serving Suggestion:
Date: 19 Nov 2010 05:36:38
Message: <4ce65336$1@news.povray.org>
> sure a lot more time implementing a compiler for them than they would have
I guess sometimes they just make mistakes or bad decisions like anyone else,
and then it's not deemed worth it to spend the time going back and changing
it.  That's just life, the only difference is when MS does it there's a lot
of people who are affected!
Date: 19 Nov 2010 11:24:06
Message: <4ce6a4a6$1@news.povray.org>
>> I'm sure a lot more time implementing a compiler for them than they
>> would have implementing a better algorithm.
> else, and then it's not deemed worth it to spend the time going back and
> changing it.  That's just life, the only difference is when MS does it
> there's a lot of people who are affected!
Could be. Or whoever was assigned to implement it just looked at other
peoples' implementations and dove in without really thinking it thru. It's
pretty easy to get disaffected enough with a job that that sort of thing
happens.  "Yeah, yeah, I'll get it written, get outa my face."
   Serving Suggestion:
Date: 27 Nov 2010 22:55:30
Message: <4cf1d2b2$1@news.povray.org>
Invisible wrote:
> "Syntactically JavaScript resembles Java with some influence from Perl,
> and features Perl-like regular expressions."
> Since when does JS have regular expressions?
Like in Java, you can create a regular expression object with normal
object-creation syntax, using the RegExp class:
var regex = new RegExp("I( have|'ve) never seen ([^.,]*)");
var text = "I've never seen a system that can do that, but...";
return "he says he has never seen " + text.match(regex)[2];
But Javascript also has regex literals built into the language:
   text.match(/I( have|'ve) never seen ([^.,]*)/)[2];
(both return "Invisible has never seen a system that can do that")
Date: 27 Nov 2010 22:58:33
Message: <4cf1d369$1@news.povray.org>
Er, of course I mean both return "he says he has never seen a system that
can do that". I replaced "Invisible" in the input texts and didn't change it
in the last line.
(I was planning to write a regex to find "is obviously impossible", but then
couldn't find any good sample text in the p.o-t messages still in the
server; looks like they really did beat that out of your vocabulary :P)
