POV-Ray : Newsgroups : povray.off-topic : An observation Server Time
5 Jul 2026 07:02:34 EDT (-0400)
  An observation (Message 58 to 67 of 107)
Subject: Re: An observation
Date: 29 Oct 2010 13:51:10
Message: <4ccb098e$1@news.povray.org>
On Fri, 29 Oct 2010 09:49:18 -0700, Darren New wrote:
> Patrick Elliott wrote:
>> In this specific case, probably true, but then you have "phones" and
>> other things running this OS too..
> No you don't.  The OS in the phones is not the normal Windows OS, any
> more than your Droid phone is running Ubuntu.
However both run a Linux kernel.  I doubt that the Windows kernel is
what's running on both the Windows platform and Windows Mobile platforms.
Jim
Date: 29 Oct 2010 15:22:54
Message: <4ccb1f0e@news.povray.org>
It's hard to say. I would be very surprised if a majority of the OS code
wasn't in Windows. Of course I'm sure a bunch of it gets chopped, but I
would guess (uninformed, mind you) that the WinPhone OS is to normal Windows
like BusyBox is to Ubuntu.  Lots chopped out and left hanging, but enough
there to make porting stuff like .NET and silverlight and all that much
easier than if they started over.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 30 Oct 2010 00:41:35
Message: <4ccba1ff$1@news.povray.org>
>> platforms.
> Windows like BusyBox is to Ubuntu.  Lots chopped out and left hanging,
> but enough there to make porting stuff like .NET and silverlight and all
> that much easier than if they started over.
Busybox is more to bash than to Ubuntu.  It's a shell, not a kernel.
I'm fairly certain that the Windows kernel code is not platform-
independent.  Microsoft stopped doing that back when they dropped support
for RISC-based Windows to the best of my knowledge.
Jim
Date: 30 Oct 2010 14:18:46
Message: <4ccc6186$1@news.povray.org>
Sure.  My point being that there's a whole lot more to Linux than the
kernel, probably little of which is running on Android.
They stopped *selling* it. I don't know why they'd let it no longer be
platform independent if they know they want to pursue such things. But since
neither of us really knows, there's not a whole lot of point in arguing it.
   Serving Suggestion:
Date: 30 Oct 2010 16:08:56
Message: <4ccc7b58$1@news.povray.org>
True, but the analogy doesn't really hold, which was my point.  It was
like comparing donuts to rollercoasters.  (OK, maybe not *quite* that
disconnected). :-)
>> support for RISC-based Windows to the best of my knowledge.
> since neither of us really knows, there's not a whole lot of point in
> arguing it.
True, but I suspect that there's a lot more platform-dependent code in
Windows than in Linux, based on my own experience.
Jim
Date: 30 Oct 2010 21:54:01
Message: <4ccccc39$1@news.povray.org>
> Jim
Generally its CE. In other words, a version that has about 90% of the
crap in Windows PC stripped out, and replaced with a *much* smaller
subset of drivers and interfaces (which are, never the less, up to a
point, supporting most of the same API calls).
One of the things left out, at least in earlier versions, since I
haven't read anything about the newer ones, was the "try/catch" error
system in the OS. Basically, you either had to code your own variation
on this, or you have to rely on your code "never" causing an error or
fault, which might do things it wasn't supposed to. Sort of.. reversion
to how Win3.11 handled memory allocation and error trapping. lol
So, yeah. Its not exactly the same thing.
Now.. Linux based ones.. As I understand it the kernel may as well be
the same, assuming the same processor, but the interfaces, i.e. drivers,
to the rest of the stuff, isn't. If you could build a PC with the same
processor, then added in the right drivers for the hardware on that
machine, it would act like any other version of Linux, assuming you
compiled you code for that machine.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 30 Oct 2010 22:08:50
Message: <4ccccfb2$1@news.povray.org>
Given that Linux *does* run on lots of different CPUs and such, I'd
certainly believe that. But if MS picks one second platform, I suspect they
could port significant parts of the kernel and APIs.
   Serving Suggestion:
Date: 30 Oct 2010 23:04:20
Message: <4cccdcb4$1@news.povray.org>
> they could port significant parts of the kernel and APIs.
Without a doubt.  Windows' roots (starting with NT) was on DEC equipment,
after all, not x86.
Jim
Date: 30 Oct 2010 23:05:55
Message: <4cccdd13$1@news.povray.org>
On Sat, 30 Oct 2010 18:54:00 -0700, Patrick Elliott wrote:
>  As I understand it the kernel may as well be the
> same, assuming the same processor, but the interfaces, i.e. drivers, to
Um, no, actually, the APIs would be the same because it's the same kernel
code.
> If you could build a PC with the same processor, then added in the
> right drivers for the hardware on that machine, it would act like any
> other version of Linux, assuming you compiled you code for that machine.
Wait, what?  You seem to be contradicting yourself....
Jim
Date: 31 Oct 2010 16:29:26
Message: <4ccdd1a6@news.povray.org>
> code.
> Jim
How so? Drivers can be compiled into kernel, but most are not any more,
and they can be added or removed, without effecting the kernel itself.
You do have to compile it for the specific processor though, so where
exactly do you think I contradicted myself?
void main () {
   else
