POV-Ray : Newsgroups : povray.off-topic : iPhone4 component costs Server Time
4 Jul 2026 19:51:05 EDT (-0400)
  iPhone4 component costs (Message 17 to 26 of 26)
Subject: Re: iPhone4 component costs
Date: 25 Oct 2010 08:02:31
Message: <4cc571d7@news.povray.org>
> Well, the iPhone runs on battery power, so yeah, the power supply is
> probably a little unstable.
Not just that, but from a single voltage (the battery) several very stable
voltages must be generated.  This involves lots of analogue components (eg
how do you efficiently make accurate 3.3V, 5V and 8V lines from a LiPo
battery that can be between 3 and 4.5V?).
> I'm thinking more about desktop PC motherboards. Why do *they* need so
> many million capacitors?
Noise reduction, basically they allow everything to run correctly at much
higher frequencies than would be possible without them.  It works two ways,
the capacitors around each IC help to keep a smooth voltage level for that
IC, ie shielding it from any noise on the power supply lines.  Also the
capacitor then prevents a lot of noise being put back onto the supply line
from the ICs.
There are also a lot of resistors on the signal lines, these in conjunction
with the tiny parasitic capacitances cause a low-pass filter effect on the
signals.  This also helps to reduce noise emission from the lines.
Date: 25 Oct 2010 08:17:35
Message: <4cc5755f@news.povray.org>
> stable voltages must be generated. This involves lots of analogue
> components (eg how do you efficiently make accurate 3.3V, 5V and 8V
> lines from a LiPo battery that can be between 3 and 4.5V?).
1. Why do you need several different voltages?
2. I'm not aware of any way to change the voltage of a DC circuit. You
can use a resistor to limit current, but AFAIK there's no way to
actually change voltages.
> much higher frequencies than would be possible without them. It works
> two ways, the capacitors around each IC help to keep a smooth voltage
> level for that IC, ie shielding it from any noise on the power supply
> lines. Also the capacitor then prevents a lot of noise being put back
> onto the supply line from the ICs.
> conjunction with the tiny parasitic capacitances cause a low-pass filter
> effect on the signals. This also helps to reduce noise emission from the
> lines.
Mmm, interesting. (And ridiculously complicated.) I wonder how much of
this stuff is to do with electromagnetic radiation? (You don't want EM
interference stopping your motherboard working, and you don't want the
board to radiate EM either...)
Date: 25 Oct 2010 08:44:41
Message: <4cc57bb9$1@news.povray.org>
Different circuits need different voltages.  It's why the connector you plug
from the PSU to your motherboard has 20-odd wires and not just 2 big fat
ones.  In an iPhone I imagine you'd at least need different voltages for the
digital circuits, the audio circuits, the display and the RF ciruits.
This is often used for battery powered devices as it's very efficient:
http://en.wikipedia.org/wiki/Charge_pump
I assume they must pass certain legal test standards for EM compatibility,
but there are products that require stricter controls, especially ones that
are used near other RF equipment where interference is unwanted (eg medical
equipment, circuits in radio receivers, on planes, near to any
safety-critical device etc).
Date: 25 Oct 2010 09:46:57
Message: <4cc58a51$1@news.povray.org>
I made an example using that Java circuit simulation applet:
http://tinyurl.com/2cplrbn
Date: 25 Oct 2010 10:18:47
Message: <4cc591c7@news.povray.org>
Hmm, interesting.
1. It's possible to edit the circuits. I never knew that.
2. It's possible to encode the circuit description in the URL. (I'm
pretty sure you'll quickly hit a limit on the maximum size for a URL!)
3. No matter what values I change, the circuit always stabilises to
exactly 8V.
Date: 25 Oct 2010 11:13:12
Message: <4cc59e88@news.povray.org>
That's freaky.
> compatibility, but there are products that require stricter controls,
Like, a radio transmitter that's designed to run for hours or days on a
small battery? :-)
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 25 Oct 2010 15:34:04
Message: <4cc5dbac$1@news.povray.org>
Different components require different voltages. Sometimes you get lucky
and everything will run all one a single voltage. You may have high
intensity LED's that have a voltage forward of more than 3.3 volts, so 5
volts is a logical choice to power the backlight circuitry allowing the
LED's to function, but pumping 5 volts into a chip requiring 3.3 volts,
would possibly overheat at best or fry at worse, etc...
You're kidding, right?
You can affect voltage by either using a regulator (true, it does this
by altering current) or if you need more voltage than is supplied by the
source you can use a charge pump, which will increase voltage by
alternately charging and discharging a bank of capacitors configured in
a very specific way (lots of caps for that one)
Filtering probably helps that. But at those timings every little thing
in the design becomes critically important. You can literally have a
parasitic capacitance completely filter out the signal.
~Mike
Date: 25 Oct 2010 15:51:55
Message: <4cc5dfdb$1@news.povray.org>
another simple charge pump based on a 555 timer.
http://tinyurl.com/2a8wf2x
~Mike
Date: 26 Oct 2010 04:02:00
Message: <4cc68af8@news.povray.org>
Cool!  I know also that you can use a circuit with inductors rather than
capacitors to make it more efficient, but the downside is the inductors need
more physical space than the capacitors on the board (only a problem if
space is very limited).
Date: 26 Oct 2010 09:53:06
Message: <4cc6dd42$1@news.povray.org>
> need more physical space than the capacitors on the board (only a
> problem if space is very limited).
I have yet to attempt a boost converter using an inductor. I should
attempt such a thing one of these days. ;) From what I understand, you
can get some pretty nasty high voltages with such a circuit. Probably
one of the reasons I haven't messed with it.
There's a regulator circuit geared toward LED use that, iirc used a very
small capacity that used the same theory to supply enough voltage to
overcome the high output LED's VF from a very small battery, even when
the battery is nearly spent and has a voltage drop. Something called a
joule thief. Essentially a boost converter using a transformer.
~Mike
