POV-Ray : Newsgroups : povray.off-topic : iPhone4 component costs Server Time
4 Jul 2026 19:51:05 EDT (-0400)
  iPhone4 component costs (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: iPhone4 component costs
Date: 22 Oct 2010 16:02:51
Message: <4cc1edeb$1@news.povray.org>
> [A large chunk of this response is mostly directed at invisible]
> Right. Filtering the signals. Caps are used a lot of time in digital
> circuits to prevent switching noise from corrupting signals via ground.
> When some digital circuits (TTL in particular) switch they create a lot
> of noise on the ground plane that must be dealt with. Too much
> fluctuation between power and ground, and the circuit begins to behave
> erratically. Also, its a good idea to limit current. Resistors are used
> to stabilize signals, pull up or pull down an input or output, bleed off
> excess voltage so FETs don't retain a charge, etc... You need RC
> networks to run a clock crystal, etc... Just connecting together a pile
> of digital components won't work. You need supporting components to make
> sure everything is stable in the system, especially when dealing with
> large-scale digital systems like an iPhone. Keep in mind, that device is
> also going to require a oscillators and filters for the RF parts, as well.
Well, the iPhone runs on battery power, so yeah, the power supply is
probably a little unstable. I'm thinking more about desktop PC
motherboards. Why do *they* need so many million capacitors?
> It gets even more interesting when you start dealing with designing
> circuit boards, where you actively need to avoid traces from running
> parallel to each other for too much distance, lest they build a
> parasitic capacitance between them. In systems with very tight voltage
> and current tolerances, the length of traces and thickness of traces
> becomes very important as well. Traces can also act as inductors.
> Some of the discrete components may be in there to also counteract some
> of these effects caused by the traces themselves on the board. You'll
> notice caps and resistors will often be very close to the pins of an IC
> to minimize any effect the circuit trace may have.
Meh, well, fortunately I don't have to care about such things.
(Presumably a few attofarads only starts to matter once you're operating
into the GHz range anyway...)
http://blog.orphi.me.uk/
Date: 22 Oct 2010 16:57:13
Message: <4cc1faa9@news.povray.org>
That's what *makes* them digital.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 23 Oct 2010 01:42:27
Message: <4cc275c2@news.povray.org>
  Capacitors are not digital. You are confusing them with transistors
(which, technically speaking, aren't digital either, but can be used
for that purpose when their multiplying factor is ignored).
Date: 23 Oct 2010 06:21:31
Message: <4cc2b72b$1@news.povray.org>
Perhaps it would be more accurate to say that no single component is
digital, more that a particular circuit design can be digital. (I've
seen logic gates used to make an analogue circuit, for example...)
Date: 23 Oct 2010 12:30:10
Message: <4cc30d92$1@news.povray.org>
Nothing is digital. Digital is an interpretation of an analog signal. To
"make an analog signal digital" requires analog components. You have to
drive the analog signal so it doesn't linger between the fully-on and
fully-off states (however those may be defined).
And yes, capacitors can be digital in a voltage-driven circuit.
   Serving Suggestion:
Date: 23 Oct 2010 12:49:02
Message: <4cc311fe$1@news.povray.org>
> Nothing is digital.
As an example, even your keyboard needs debounce circuits, and power
supplies have to be careful not to let the inductance fry things when you
toggle the switch.
   Serving Suggestion:
Date: 25 Oct 2010 08:02:31
Message: <4cc571d7@news.povray.org>
Not just that, but from a single voltage (the battery) several very stable
voltages must be generated.  This involves lots of analogue components (eg
how do you efficiently make accurate 3.3V, 5V and 8V lines from a LiPo
battery that can be between 3 and 4.5V?).
> I'm thinking more about desktop PC motherboards. Why do *they* need so
Noise reduction, basically they allow everything to run correctly at much
higher frequencies than would be possible without them.  It works two ways,
the capacitors around each IC help to keep a smooth voltage level for that
IC, ie shielding it from any noise on the power supply lines.  Also the
capacitor then prevents a lot of noise being put back onto the supply line
from the ICs.
There are also a lot of resistors on the signal lines, these in conjunction
with the tiny parasitic capacitances cause a low-pass filter effect on the
signals.  This also helps to reduce noise emission from the lines.
Date: 25 Oct 2010 08:17:35
Message: <4cc5755f@news.povray.org>
> stable voltages must be generated. This involves lots of analogue
> components (eg how do you efficiently make accurate 3.3V, 5V and 8V
> lines from a LiPo battery that can be between 3 and 4.5V?).
1. Why do you need several different voltages?
2. I'm not aware of any way to change the voltage of a DC circuit. You
can use a resistor to limit current, but AFAIK there's no way to
actually change voltages.
> much higher frequencies than would be possible without them. It works
> two ways, the capacitors around each IC help to keep a smooth voltage
> level for that IC, ie shielding it from any noise on the power supply
> lines. Also the capacitor then prevents a lot of noise being put back
> onto the supply line from the ICs.
> conjunction with the tiny parasitic capacitances cause a low-pass filter
> effect on the signals. This also helps to reduce noise emission from the
> lines.
Mmm, interesting. (And ridiculously complicated.) I wonder how much of
this stuff is to do with electromagnetic radiation? (You don't want EM
interference stopping your motherboard working, and you don't want the
board to radiate EM either...)
Date: 25 Oct 2010 08:44:41
Message: <4cc57bb9$1@news.povray.org>
Different circuits need different voltages.  It's why the connector you plug
from the PSU to your motherboard has 20-odd wires and not just 2 big fat
ones.  In an iPhone I imagine you'd at least need different voltages for the
digital circuits, the audio circuits, the display and the RF ciruits.
This is often used for battery powered devices as it's very efficient:
http://en.wikipedia.org/wiki/Charge_pump
I assume they must pass certain legal test standards for EM compatibility,
but there are products that require stricter controls, especially ones that
are used near other RF equipment where interference is unwanted (eg medical
equipment, circuits in radio receivers, on planes, near to any
safety-critical device etc).
Date: 25 Oct 2010 09:46:57
Message: <4cc58a51$1@news.povray.org>
I made an example using that Java circuit simulation applet:
http://tinyurl.com/2cplrbn
