POV-Ray : Newsgroups : povray.off-topic : Web page construction Server Time
6 Apr 2026 22:19:20 EDT (-0400)
  Web page construction (Message 26 to 35 of 35)
Subject: Re: Web page construction
Date: 21 Sep 2010 16:59:14
Message: <4c991ca2$1@news.povray.org>
On 12/09/2010 01:21 PM, Orchid XP v8 wrote:
> 2. I want to build a file tree where you can collapse or expand tree
> nodes. The obvious way to do this is with the <ul> element. However, I
> also want each file to have attributes, a creation date, and so forth,
> and all these columns should line up vertically. The obvious way to do
> that is with a table. But it can't be a table and a list at the same time!
> I could use nested tables I suppose, but nested tables are EVIL! Is
> there some more semantically-transparent way that I can do this?
> Root 2009-09-12 Ahsc
> Resources 2009-09-10 Ahsc
> Main.css 2009-09-10 Ahsc
> Main.js 2009-09-10 Ahsc
> Packages 2009-09-12 Ahsc
> ansi-terminal 2009-09-12 Ahsc
Facepalm moment: Using CSS, you can render any element AS A TABLE! >_<
http://blog.orphi.me.uk/
Date: 22 Sep 2010 05:14:24
Message: <op.vjffyfepmn4jds@phils>
And lo On Tue, 21 Sep 2010 21:59:13 +0100, Orchid XP v8 <voi### [at] devnull>
did spake thusly:
>> time!
Well yeah that was going to be my first response, but you wanted the
columns offset within rows and that would have ended up just as messy as
absolute positioning.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 22 Sep 2010 05:35:10
Message: <4c99cdce@news.povray.org>
Well, I can make it so that a <ul> who's <li> elements contain multiple
<span> tags gets rendered as a regular table. What I *cannot* do is make
nested <ul> elements render correctly. Not for love nor money.
I can, however, take a <table> and annotate each <tr> with a style class
indicating how far to indent it, and get a result that looks exactly
like what I want.
So I have a choice here: The information I want to present is
semantically tabular *and* hierarchical. I can mark it up as <ul> (which
lets be expose the hierarchy but hides the tabular nature in <span>
tags), or I can mark it up as <table> (which exposes the tabular
structure but hides the hierarchy in style class declarations).
I think I'm going to go with <table>, simply because it lets me actually
achieve the rendering result I want. Sure, tables are evil. OTOH, my
data actually *is* a table! So putting it in <table> isn't that much of
a hack.
Date: 22 Sep 2010 05:50:08
Message: <op.vjfhl0s3mn4jds@phils>
And lo On Wed, 22 Sep 2010 10:35:08 +0100, Invisible <voi### [at] devnull> did
spake thusly:
> a hack.
Well yeah if it's tabular data present it in a table nothing evil about
that well unless you're going to use nested tables just for display
purposes that's frowned upon; and if you're not then you're going to have
to style every single cell and that's just messy.
Phil Cook
Date: 22 Sep 2010 05:52:31
Message: <4c99d1df$1@news.povray.org>
> spake thusly:
>> actually achieve the rendering result I want. Sure, tables are evil.
>> OTOH, my data actually *is* a table! So putting it in <table> isn't
>> that much of a hack.
> have to style every single cell and that's just messy.
Nested tables won't even help me here. And no, I don't need to style
every single cell. I just style each row (so I can get alternating
colours) and each cell in column 1 (so I can set the indent). And since
the whole table will be machine-generated anyway...
Date: 22 Sep 2010 06:02:21
Message: <4c99d42d$1@news.povray.org>
Only remaining problem is how to expand/collapse subtrees (now that a
subtree isn't a single XML element any more). I'm sure it's solvable.
Date: 22 Sep 2010 06:04:38
Message: <op.vjfh96rsmn4jds@phils>
And lo On Wed, 22 Sep 2010 10:52:30 +0100, Invisible <voi### [at] devnull> did
spake thusly:
>> spake thusly:
tr:nth-child(odd){background-color:red;}
tr:nth-child(even){background-color:blue;}
Seeing as you don't care about IE :-)
As for column 1 styling how will that line up the dates? You'll need to
line up column 1 of rows 2 and 5, and then column 1 of rows 3, 4, and 6
and then do the same for column 2.
Phil Cook
Date: 22 Sep 2010 06:34:05
Message: <4c99db9d@news.povray.org>
>> since the whole table will be machine-generated anyway...
That works? Impressive... (As you say, it's only taken 10 years!)
Just adjust the padding property for column one. The other columns
automatically line up, the way they always do in a table.
Date: 22 Sep 2010 09:05:28
Message: <op.vjfqnlq5mn4jds@phils>
And lo On Wed, 22 Sep 2010 11:34:03 +0100, Invisible <voi### [at] devnull> did
spake thusly:
Well would you look at that. You learn something new every day.
Phil Cook
Date: 22 Sep 2010 16:12:48
Message: <4c9a6340$1@news.povray.org>
> spake thusly:
See, that's what's so awesome about this newsgroup. ;-)
