![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible <voi### [at] dev null> wrote:
> I'm the kind of person who will go for a walk beside a beautiful lady
You get to do that? I'm envious.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK, this has to be the best typo in history.
Obviously I intended to type "lake". O_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp <war### [at] tag povray org> wrote:
> clipka <ano### [at] anonymous org> wrote:
> > Also note that "brain work" burns quite a lot of glucose. (Though I'm
> > not sure from your anecdotes whether your daily work does qualify as
> > "brain work" :-P)
> I'm pretty sure that constant frustration and facepalms do burn more
> glucose than any brain work you could do... :)
Constant facepalms could explain a headache by means other than how much glucose
they consume :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
> I pretty much only get headaches on the first day back at work after
> some time off.
If you work in an office building, I'd bet you $20 it's bad air. Air
conditioning doesn't ever really bring the CO2 levels down to the same as
outside air.
C# - a language whose greatest drawback
is that its best implementation comes
from a company that doesn't hate Microsoft.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's called a freudian slip.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Slip? Try *landslide*. o_O
Man, it's a good thing you can't sustain Freudian head-injuries from
this stuff...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 8/10/2010 3:05 AM, Tim Cook wrote:
> On 2010-08-10 04:20, Invisible wrote:
>> This is where things get really weird. I ate a bunch of painkillers over
>> an hour ago, and they still haven't had any effect. But as soon as I
>> started eating food, within literally *minutes* my headache almost
>> completely vanished. WTF is *that* about?!
>> Any unsubstantiated theories? Wild speculation? Baseless diagnosis?
> Sounds like the migraines I get that are triggered by (and corrected by
> fixing) my poor sleep/eating habits. They can also be triggered by
> sudden change in caffeine level in body.
> Tim Cook
> http://empyrean.freesitespace.net
That was my first thought too. Though, mine are "usually" triggered by
not drinking enough. Its notable that a) they can seem to fade, a bit,
after eating, especially if you didn't eat enough, and that accelerated
the problem, b) drinking water to rehydrate does **nothing** to stave it
off, and c) at least in my case, it can seem fairly bad, but not
horribly so, until I actually have to try to rest any, and then
*everything* drives me up the wall.
The prevention of these tends to be a) acetometiphin (I think its
called, and in Tylonol?) + caffeine. The caffeine effects blood flow in
the brain, so if you decrease intake, it takes a bit for your brain to
re-adjust. Basically, you end up creating one of the conditions that
**helps** create a migraine by going off it (oh, joy lol). Not sure what
the other does, but both are needed to deal with it. The **problem** is,
this combination will only work, and this has been tested medically, if
you take one *before* you get any symptoms at all, or *just as* you
start to notice the preliminary symptoms (which in my case is a stiff
neck and ache in the nerves there). If you take it after you have the
headache, it does absolutely nothing for you.
Given how easy it is, on my job, to dehydrate, I have made it a habit of
taking one before work, every day I work more than 4 hours. Its been
months since I had one. Where, before, I could get one 1-2 times a month.
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 8/10/2010 8:25 AM, Darren New wrote:
>> some time off.
> as outside air.
Actually.. Could be bad lighting too. Some people are susceptible to the
flicker in florescent lights, whether working properly or not, though
not tends to be worse for those people. This can, and does, trigger
headaches in some people, and could go away, once "re-acclimated" to the
lighting. Since those types of lights are endemic in most offices, and
it only effects a small percentage of people, so no one has any plans to
fix it, it is not at all uncommon.
void main () {
If Schrödingers_cat is alive or version > 98 {
else
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www.youtube.com/watch?v=ZOaMeq7HQwE#t=5m40s
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
>>>> Possibly hypoglycaemia.
>>> That was my thought too. However, it seems hypoglycaemia produces a wide
>>> range of symptons, and I only had one of them.
>> It is not obligatory to have all the symptoms. ;-)
> Sure. But only one of them? That's kind of improbable.
No it isn't. You may have noticed it early enough, relatively, and
treated it with food before it progressed to other symptoms. You can
have a cold virus with only a fever. Hypoglycaemia can also be a single
symptom of other things. And you did end up with the nausea after eating.
Three 9's odds, though, that it is just a headache. Speculation and
baselessness, get someone with a blood sugar meter to test ya first
thing in the morning.
>>> Also... why the **** would I suddenly have hypoglycaemia one day? It's
>>> not as if I've just had a blood transfusion or I haven't eaten for
>>> months or anything...
>> It is a judgement from One on High for swearing with asterisks.
> Oh goodie...
Doesn't need to be no food for a month. Bet your diet changed while you
were off for a week, maybe had a few more snacks while on break? Extra
carbohydrates during the morning, maybe. The vacation gods will do that
to you, to remind you that you must obey them more often.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
