POV-Ray : Newsgroups : povray.off-topic : Small math/programming problem Server Time
14 May 2026 20:03:38 EDT (-0400)
  Small math/programming problem (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Small math/programming problem
Date: 1 Jul 2010 06:43:28
Message: <4c2c7150@news.povray.org>
scott wrote:
>> .....1,549,498,368
> I recognise those last 6 digits!  I think I got them from my program,
> but then my method was too slow to do any more digits in reasonable time.
Heh. Could be just fluke.
I'm still not 100% certain that my program works. For example, the
exponent is reduced as per the modulus too, which could affect the
answer. As a quick check, I tried rerunning with 20 digits:
.......1,225,862,901,549,498,368
So the digits don't change by making the calculation wider. Which
presumably means it's wide enough not to screw up the answer. (Or it's a
very big fluke. You never know - mathematics is like that!)
Date: 1 Jul 2010 07:52:00
Message: <4c2c8160$1@news.povray.org>
Next task, give us some indication of how big n is :-)
Date: 1 Jul 2010 08:22:19
Message: <4c2c887b$1@news.povray.org>
I can see I won't get much work done today...
OK, well we have
   d = λ n → n 2
   c = λ n → n 2^n
   b = λ n → c@n n
   a = λ n → b@n n
where "b@n" means "b applied n times".
If n = 100, then 2^n ≈ 10^30, while is a mere 10^2 times larger. As n
becomes larger, the difference becomes more and more insignificant. So,
we can approximate with
   c = λ n → 2^n
On that bases, the final result is guaranteed to be an exact power of 2.
We just need to figure out which one.
Using Knuth's "up-arrow notation", we have
   c = λ n → 2↑n
   b = λ n → 2↑↑n
   a = λ n → 2↑↑↑n
So the answer we seek is (approximately) 2↑↑↑2. In other words, the
pentation of 2 with 2. Unfortunately, I don't know of any efficient way
to compute the size of this ludicrously massive quantity.
Date: 1 Jul 2010 10:29:54
Message: <4c2ca662$1@news.povray.org>
Isn't that 4?
Date: 1 Jul 2010 11:25:28
Message: <4c2cb368$1@news.povray.org>
Invisible wrote:
> scott wrote:
>>> .....1,549,498,368
Nah. That would be a one in a million chance.
Wait, no, one in a million chances work out all the time!
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 1 Jul 2010 11:26:43
Message: <4c2cb3b3@news.povray.org>
Invisible wrote:
> So what's the answer? I make it
> .....1,549,498,368
I believe that answer is correct, although I'm not sure your reasoning
behind the algorithm was watertight.  In particular, since you're
applying modular exponentiation in each iteration, you're implicitly
assuming that a^b mod m == a^(b mod m) in the next iteration.
Fortunately this ends up bring very close to true in this case, so
everything still works out, but to be totally safe you should really
compute everything mod lcm(10^10,phi(10^10)) = 10^11.  Unless I was
overly conservative in my analysis somewhere.
Now for a tricker question, say I add another loop:
n = 2
for(a = n; a > 0; a--)
   for(b = n; b > 0; b--)
     for(c = n; c > 0; c--)
       for(d = n; d > 0; d--)
         for(e = n; e > 0; e--)
           n++
print n
What are the last five digits printed?
Note that I haven't actually worked through this yet to be sure that my
idea or solving it will actually work, so be forewarned that I'm not
positive it's possible.
Date: 1 Jul 2010 11:38:33
Message: <4c2cb679@news.povray.org>
> Isn't that 4?
No, since 2^^^2 = 2^^2^^2 = 2^^(2^2^2) = 2^^16 =
2^2^2^2^2^2^2^2^2^2^2^2^2^2^2^2.
However, in this case you can very easily give a somewhat tighter lower
bound of 2^^2048, that is 2^2^2^2^ ... 2048 times ... ^2^2^2
Date: 2 Jul 2010 00:11:41
Message: <4c2d66fd@news.povray.org>
> n = 2
>           n++
> print n
Ok, I haven't been able to post today since I've been on airplanes on or
airports without wireless the whole time, but I implemented the solution
and it seems to work, so this problem is totally solvable, and only
takes a fraction of a second on my computer.
It turns out that the solution is actually quite simple too!  Possibly
even more so than that to the last puzzle -- although certainly not as
mathematically concise.
Actually pretty fun, so feel free to give it a shot knowing that it does
indeed have a relatively simple solution!
Date: 2 Jul 2010 00:16:19
Message: <4c2d6813$1@news.povray.org>
Invisible wrote:
>  (Assuming you meant the last 10 *decimal* digits...)
Man, meaning the last ten binary digits would have made this the lamest
trick question ever (so yeah, you're correct in solving for decimal
obviously).
Date: 2 Jul 2010 00:50:33
Message: <4c2d7019$1@news.povray.org>
scott wrote:
>> .....1,549,498,368
It's interesting that you had an algorithm that could compute six digits
but not ten.  You might try running it on the second version of the
puzzle that I gave, since I only ask for the last five digits in that
case.  Maybe it'll work!
