>>> Copyright ReactOS Foundation 1996-2009. Yeah right...
>> Wikipedia claims the first release was in 1998, so I guess it's
>> *plausible*...
> Except for the copyright violations, at least. I strongly suspect there
> was no clean-room development going on there.
Well, again, Wikipedia asserts that the entire thing was done using 100%
clean-room development, and that they've done extensive internal code
audits to make sure everything is legal.
All of which is of course completely irrelevant, since every single tiny
aspect of all M$ products are covered by 80,000,000 patents, so if this
product ever starts actually working properly, the developers will still
be sued off the face of the Earth.
http://blog.orphi.me.uk/
On 6/22/2010 7:59 AM, Invisible wrote:
> Mike Raiford wrote:
>> Cute... It pretends to be windows, but isn't...
> Cute or horrifying, depending on your point of view. There are some
> things about Windows that you wouldn't *want* to copy!
> Even so, many things look very similar yet not quite right. (E.g., that
> command prompt has a totally different aspect ratio.)
That aspect ratio issue is entirely dependent on font. You can change
that even in Windows, and, stupidly, some of the *sizes* are based on
.FON fonts, which have a completely different ration than the .TTF fonts
used for the other sizes. It doesn't scale them, or otherwise allow you
to set an arbitrary size, but is purely *fixed* to what ever internal
sizes exist in the font definition files. Got to be the stupidest, and
most annoying, aspect of the whole damn thing, especially if you planned
to have a "small" copy open, to look at something, but still have it
legible, while working in other, also open, windows, without having to
alt-tab between them. Hint - the small enough one for that, isn't
legible at all (well, unless maybe you had a display 40 inches wide..).
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Yeah, it's no secret that the Windows command prompt thing isn't
brilliant. (The number of people who complain about it not supporting
ANSI escape sequences is staggering, for example.)
Huh. Interesting. It's odd how they managed to get every little look pretty
much exact.
Eiffel - The language that lets you specify exactly
that the code does what you think it does, even if
it doesn't do what you wanted.
>> 100% clean-room development,
> pretty much exact.
Well, if you get somebody to disassemble the code, write down the
*exact* rendering parameters, and then give just the parameters to the
guy who writes the new code, then you have "clean-room development", yet
it looks pretty identical.
But take a closer look: Notepad has a line/column count. The command
prompt has a different aspect ratio. A lot of icons are completely
different. And so on. (And let's not forget, a lot of the very basic
Windows stuff uses quite simple layouts, probably thrown together quite
quickly.)
On 6/22/2010 11:18 AM, Phil Cook v2 wrote:
> And lo On Tue, 22 Jun 2010 14:16:53 +0100, Invisible <voi### [at] dev null> did
> spake thusly:
>> Check out the shutdown message. What's with that?
> They Live!
I recall a similar quote from Duke Nukem 3D.
How long do software patents last? I would guess that in the same amount
of time hardware and virtualization speeds would have increased so much
that you might as well just run the *actual* OS in VMWare or whatever.
http://isometricland.com
>> spake thusly:
>> They Live!
Yep, it's Dike Nukem.
lol More like, for so long, at this point, that you could build a VMWare
version that "mimics" 4 core processors, while running it on 64 cores,
while using only 2GB or the 16TB of memory available to your 5 year old
computer system. The patent system is that screwed up, from what I have
seen.
void main () {
else
> seen.
That sounds like way too many cores. AFAIK multi-core CPUs are just a
temporary "hack" to resolve heat issues. There's only so much room on a
motherboard, and with 64 cores you may run out!
> pretty much exact.
What looks exactly?
Note that the GUI widgets are probably all rendered by Wine code...
The problem isn't technology, it's law. ReactOS exists so you can run
Windows software without actually paying for Windows. (Of course, as I
pointed out, this doesn't actually work yet.)
I don't know, but I know a guy who just received one that the application
went in *8* years ago for.
Jim
And lo On Wed, 23 Jun 2010 18:22:31 +0100, SharkD
<pos### [at] gmail com> did spake thusly:
>>> did
>>> spake thusly:
>>> They Live!
Close, the quote from DN is "It's time to kick ass and chew bubble gum...
and I'm all outta gum." The original They Live is a more formal "I have
come here to chew bubblegum and kick ass... and I'm all out of bubblegum"
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Invisible <voi### [at] dev null> wrote:
> For those of you that don't know, there's a thing called ReactOS. It's a
> free operating system which is supposed to be binary-compatible with
> Microsoft Windows XP. (Despite the small and obvious problem that this
> _should_ be 100% illegal.)
Why would it be illegal? There's no law in any country I know of which
would forbid building a system which is capable of running an program.
It's not much different from making an emulator, and those aren't illegal.
It would be illegal for them to lift binaries (eg. system libraries) from
Windows XP and distributing them alongside their own OS, but it's perfectly
legal for them to build their own versions of those binaries.
I was under the impression that things like (for example) the API for
DirectX is patented, and therefore you can't write a library that has
the same API (i.e., the same functions with the same names and
signatures that do the same thing).
Invisible wrote:
> You *can* do stuff with it, but it's very unreliable.
Sounds like perfect Windows emulation to me!
John
There may be a term in the EULA which prohibits reverse engineering. It
does not strike me as terribly likely that someone managed to write a
Windows OS clone without doing that.
John
Heheh. What, you mean like this?
http://www.slimeland.com/winsim/
I would say, Win 3.x was quite reliable (then again, it doesn't *do*
anything), Win 9x was fairly unstable, Win NT was much better, Win XP
was initially hopeless, and now Win XP has got to the point where it
usually works just fine. Certinaly it doesn't crash just because you
open Notepad; ReactOS does. Like, in ReactOS, you can just open an
Explorer window, click on a few things, and then you notice that the
mouse has stopped moving and the system is using 100% CPU, and the
keyboard isn't responding, and...
I haven't seen the Blue Screen of Death from ReactOS yet. Maybe they
haven't implemented that part?
Depends on what you count as "reverse engineering". If you just mean
"disassembly", then I'd say you probably can write something functional
just by reading the API documentation and running tests to see how the
M$ implementation behaves in various situations. If you count "running
tests to see how the M$ implementation behaves" as reverse engineering
then no, not really...
Patents are not international. US patents are not recognized here (and
vice-versa, of course).
OK. But what's to say that M$ haven't patented the same thing in every
single duristiction that they operate in?
It would probably be the "look and feel" lawsuits, even ignoring the patent
problems.
... which *used* to be unenforceable in the US, since copyright law is
federal and allows reverse engineering, while EULAs are contract law which
is state law.
The DMCA and all that probably changed this in the 30+ years since I learned
that, tho.
The fact that software cannot be patented in most countries. The EU doesn't
acknowledge software patents.
> problems.
I have hard time believing that trade dress laws apply to basic computer
user interfaces. Else Microsoft could sue the creators of KDE and Gnome for
copying their windowing ideas (not to talk that Apple could probably sue
Microsoft for the same thing, as windowing was probably implemented in Apple
computers before Windows)l
>> problems.
> user interfaces.
It's copyright law here. Basically, the original lawsuit was over greeting
cards. One company hired people to think up and design greeting cards. At
another company, the CEO would go into stores and buy up competitor cards he
liked, then give them to his workers who would draw new pictures but give
the same basic "look and feel" to the cards. One example was a card with a
cute little girl in a sun dress and bonnet, and inside it said "I wuv you."
The competitor drew it with a pink background instead of blue, put a
teddy-bear instead of a girl, and put the same text inside. So the artwork
was all original, and the text wasn't copyrightable, but the overall
look-and-feel was (for better or worse) judged to be subject to copyright.
It's nothing to do with "trade dress", which is more like trademarks than
copyright. Microsoft wasn't making any products that could be confused with
Apple's products, which is what trademark is about.
Indeed, Apple is the one that started applying "look-and-feel" to Microsoft
in a lawsuit over the UI.
http://en.wikipedia.org/wiki/Apple_Computer,_Inc._v._Microsoft_Corporation
Unfortunately, the "look-and-feel" argument has been applied so much to
software that I can't easily track down the original lawsuit over greeting
cards that set off the whole "look-and-feel is subject to copyright even if
all the actual text and artwork is new" stuff. Altho I did find one
reference that greeting cards are the *second* most litigated look-and-feel
suit. :-)
>> seen.
Intel already has a 32 core system. They have given test models out to
various experts, to do their debugging/testing for them, to see how well
they work. Note, this isn't 32 cores on X chips. Its 32 cores on **one**
chip, so the issue is how much you can cram on the chip, not how much
room there is on the MB.
void main () {
else
It also depends what you want the "core" to do. A 32-core x86 processor?
Awesome. A 32-core FORTH processor? Yawn.
>>> It's a free operating system which is supposed to be
>>> binary-compatible with Microsoft Windows XP. (Despite the small and
>>> obvious problem that this _should_ be 100% illegal.)
>> illegal.
>> perfectly
Actually.. No. An API is an "interface". The underlying way that it goes
from, "I gave it this data", to, "It gave me this result", is what is
patented, not the API itself. Otherwise emulating **anything**,
including the BIOS, which you need to do things like DOSBox, would be
illegal too.
void main () {
else
I have a processor with 192 cores, capable of generating about 700
GFLOPS of compute power. And it's not even an expensive research
prototype. It's an off-the-shelf component. It's called a GPU. ;-)
Oh, right. I didn't know that.
Does this mean that software patents actually don't get granted? Or just
that hypothetically you could go to court to have them revoked?
>> DirectX is patented.
Really? Interesting. What underlies the API calls is obviously subject
to _copyright_ protection, but I didn't think you could _patent_
executable code. However, I thought that you *can* patent an API.
> illegal too.
Only illegal if the BIOS interface is patented. (AFAIK, it isn't.) The
actual BIOS code in any given motherboard has copyright protection
[usually], but then it only works with one given motherboard anyway...
> is what is patented, not the API itself.
Really, it depends what's in the patent.
For example, if you patent aspects of the MP3 data stream format, then any
API that accepts an MP3 data stream as input or generates it as output would
not be implementable without licensing the patent.
Um... they did?
> Microsoft in a lawsuit over the UI.
Oh thank god... It's nice to know my memory isn't *completely* defective!
Maybe they did, but it's so buggy that it always fails.
John
>> doesn't
If it's a clear cut software-only or algorithm-only with no physical
application it will be rejected, in fact you'd be dumb to waste the money
trying to apply for a patent, no legal firm would advise you to do this.
*But*, if it applies to some physical object that can actually be made, then
the algorithm/program *can* be patented. For example a novel image
processing algorithm for improving display quality on a display is fine, or
a control program for a crane, that sort of thing.
As you can imagine though, there is a huge grey area in the middle, so
probably some things get through that wouldn't be enforceable in court.
>>> doesn't
>> just that hypothetically you could go to court to have them revoked?
> money trying to apply for a patent, no legal firm would advise you to do
> this.
> then the algorithm/program *can* be patented. For example a novel image
> or a control program for a crane, that sort of thing.
Right. So as long as M$ describes the DirectX API as "a system for
allowing cool programs to run on our OS and nobody else's", they can
patent it. And then sue ReactOS for implementing it.
> patent it.
Not in the EU they can't, because it does not apply to some physical object
that can only be made utilising this patent. At a stretch they might be
able to get away with some GUI concept applied to a mobile device they were
manufacturing, but it's going to have to be quite a high level concept (eg a
novel way to select images from a database using a touch screen) rather than
an API.
There is no way to successfully sue anyone in the EU for patent infringement
if you're not dealing with anything physical.
And lo On Fri, 25 Jun 2010 09:01:40 +0100, scott <sco### [at] scott com> did
spake thusly:
<snip>
> infringement if you're not dealing with anything physical.
However that's just patents there are also trademarks which enforce the
'style' of something and that doesn't just apply to the physical. As for
whether that or even overseas patents are enforceable you have to look out
for TRIPs. In theory TRIPs allows non-physical patents and therefore any
signatory to TRIPs has to uphold them.
Phil Cook
Windows 3.x was stable? LMAO ... back then I only used windows when I
absolutely had to. Very crash prone.
9x was better than 3.x, NT was definitely much more stable.
Yep. I haven't had much problem with Windows 7 actually. Occasionally
there's some 64 bit awkwardness (64bit apps being able to allocate way
more memory that physically available causes trouble), but well, I chose
to install 64 bit.
Nah, it just goes into in infinite loop before it ever gets there
(apparently, based on your description)
~Mike
AFAIK even then it applies only to the device in question.
For example, a company could patent, let's say, a scanning device which
scans a barcode and tells what numeric code it corresponds to. The algorithm
which recognizes the barcode from the rest of the image and interprets its
meaning can be part of the device patent.
However, someone could implement the exact same algorithm on a PC so that
it would recognize barcodes from JPEG images and then distribute that program,
and it would be fine because it's not anymore related to the scanning device.
This person is not building the scanning *device* and distributing it, only
a program.
>>> doesn't
> this.
That's the same rules we have here in the USA.
The USA also has what's called "design patents". For example, if you invent
a novel way of carving glass or polishing paint or something, you can patent
it as a "design patent" and keep someone else from using it. (That's all
I've seen it applied to personally, but I suspect the intention was to allow
you to patent for example a phone where the keyboard slides open in two
different directions or something, regardless of how you mechanically
realized it.)
... yet.
I have decided that whenever MS comes out with a new OS, I'm going to stop
applying anything but the most vital patches to the old OS. I think my Vista
has gotten way, way flakier in the last three months than in the 18 or more
months or so before that.
>> processor? Awesome. A 32-core FORTH processor? Yawn.
Ah well, yeah. lol The one they are testing though *is* an x86 type.
void main () {
else
>>> do this.
>>> made, then the algorithm/program *can* be patented. For example a
>>> novel image processing algorithm for improving display quality on a
>>> display is fine, or a control program for a crane, that sort of thing.
>>> so probably some things get through that wouldn't be enforceable in
>>> court.
>> patent it.
> object that can only be made utilising this patent. At a stretch they
> might be able to get away with some GUI concept applied to a mobile
> device they were manufacturing, but it's going to have to be quite a
> high level concept (eg a novel way to select images from a database
> using a touch screen) rather than an API.
That would be "yet". Sadly, the US companies keep pushing for adoption
of our stupid ideas on the subject. They figure, "Why rule the US and
bankrupt/undermine anyone with new (or just improved) ideas, when you
can rule the world, and do the same to everyone else."
void main () {
else
> a program.
The problem here is that it all depends on the "breadth" of the
language. Someone a while back got sued, and lost, over a patent that
covered imprinting music data onto media, via a kiosk. The patent they
used to sue... was originally based on punching holes in paper scrolls,
to be fed into player pianos. The people successfully sued over it -
"Buy the music you want, per song, and have our kiosk burn those chosen
songs to a CD for you."
That is the problem in a nutshell. Patents, under the current bunch of
a) judges, b) patent lawyers, and c) system by which they are, if ever,
looked at before issuing pendings on them, allow you to make the details
so vague that it covers like 99% of every possible way to do something,
not just the "specific" device, and the "specific" usage, originally
applied for. So, of course, now, they **intentionally** make the
language that vague, knowing they can get by with doing it, instead of
being specific.
void main () {
else
>> goes from, "I gave it this data", to, "It gave me this result", is
>> Otherwise emulating **anything**, including the BIOS, which you need
>> to do things like DOSBox, would be illegal too.
Well, if I am wrong about that, and I may be. It still doesn't make
sense. Part of the patent law **explicitely* allows "interoperability".
You can't have it both ways and a) prevent someone duplicating the API,
and also b) allow people to design something that can inter-operate with
the software/hardware that uses the API.
void main () {
else
> any API that accepts an MP3 data stream as input or generates it as
> output would not be implementable without licensing the patent.
True enough. But, as I said in the other post to Orchid. I don't see how
you allow "interoperability", then tell people, "Oh, but sorry, you are
not allowed to duplicate how it works, so you can make it inter-operate."
void main () {
else
