POV-Ray : Newsgroups : povray.off-topic : Interesting performance paper Server Time
4 Jul 2026 11:09:15 EDT (-0400)
  Interesting performance paper (Message 21 to 30 of 39)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Interesting performance paper
Date: 14 Jun 2010 15:19:22
Message: <4c1680ba@news.povray.org>
Am 14.06.2010 20:34, schrieb Orchid XP v8:
>>> Today if it doesn't fit in RAM, the OS makes the computer
>>> pretend it has more RAM than it does (with the *minor issue* of a vast
>>> slowdown and halving the life of your harddrive).
>> I'd rather put it this way: Today, if it doesn't fit in RAM, the OS
>> helps you "juggling" the memory chunks to work on. (And if it doesn't
>> fit in L1 or L2 cache, the CPU provides essentially the same service.)
>> Which makes life much easier in a world where you don't know how much
>> RAM you'll have when programming the software. (Back then, you /did/
>> know the specs of the one machine you wrote your programs for.) Plus,
>> it allows much easier and faster (and therefore more economical)
>> design of software where runtime performance doesn't matter that much.
> Well, there is that, yes. But I (and presumably everybody else) would
> prefer it if we could actually make RAM really, really fast...
... which will never ever again happen for main memory, at least not in
the sense of being equally fast as whatever caches we'll be using then:
We'll always have to live with memory being arranged in multiple tiers
of different speed.
>> (As for harddrive life, I guess that depends on your harddrive.)
> If stuff is being swapped out just because it isn't being used right
> now, that's fine. But watch a program trying to random-access several GB
> of data when you don't have multiple GB of RAM. It's an extremely
> efficient way to give your HD a *very* strenuous workout! ;-)
Sure, but some HDs are designed for this type of life.
BTW, it's not harddrive life that worries me in such situations, but the
bare struggle to get the system's attention back. Try killing a
swapping-mad program when it keeps thrashing the task manager out of
main memory... >_<
Date: 14 Jun 2010 15:29:18
Message: <4c16830e$1@news.povray.org>
> main memory... >_<
Heh. Fun... Actually, the one I usually have trouble with is Alt+Tab
from a game back to the Windows desktop. Takes several lifetimes in both
directions. No idea why.
One thing I discovered back at uni: If your Java program accidentally
goes into an infinite loop, it dies almost instantly with a stack
overflow. If your Smalltalk program accidentally loops forever, it's
usually a few minutes before you realise that it's actually filling the
entire VM address space with garbage. Now try stopping it. :-)
Literally, it's so determined to follow your instructions as efficiently
as possible that for a while you don't even realise what's wrong. It
just looks like it's "busy".
Of course, infinite loops are much, much more common in Smalltalk. A
very common idiom is to write
#new
   super new.
   ...stuff...
But if, by some slip, you instead write
#new
   self new.
   ...stuff...
...then calling #new immediately calls #new, creating an endless
allocation loop. o_O
http://blog.orphi.me.uk/
Date: 14 Jun 2010 17:40:01
Message: <web.4c16a0dd7fcd67b84f28787e0@news.povray.org>
> overflow.
That's just because the VM only claims a small amount of RAM to start with...
quite irritating actually, it took me ages to work out I had to increase its
allocation to get my fractal plotter to be able to hold a decent image :-)
(but then it was too slow anyway so I rewrote it in C)
Date: 14 Jun 2010 18:03:13
Message: <4c16a721$1@news.povray.org>
> main memory... >_<
Hell, even if it's just copying big files, you have the same problem.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 15 Jun 2010 04:03:20
Message: <4c1733c8$1@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> contains a couple of CPU cores plus (say) 2GB of RAM.
> What makes you think nobody has done this?
Au contrare, what makes you think that somebody *has* done this?
Date: 15 Jun 2010 04:07:23
Message: <4c1734bb$1@news.povray.org>
>> overflow.
Smalltalk seemed to be very, very good at handling large amounts of
objects in RAM. It didn't complain or anything, it just got on with it.
Unfortunately, usually the only reason for this happening was programmer
error. :-/
Haskell (or rather, GHC) is similar. It will happily eat several GB of
VM very quickly. The difficulty isn't figuring out how to allocate
enough space; it's finding the magic CLI switch that tells it to quit
rather than eat all available RAM!
(There's a switch that makes it die if the program tries to allocate
more than X. If you happen to know that your program can only possibly
require a few MB, set this switch and if there's a bug, the program will
die rather than kill you.)
Date: 15 Jun 2010 04:09:19
Message: <4c17352f@news.povray.org>
In other news... I get the impression that the world is probably heading
towards NUMA anyway. Not sure precisely how that changes the picture -
other than making it much, much more complicated...
(I'm not sure, but I think it might mean that you have explicit control
over what is stored where and when it gets moved, which could be a win
if compilers are smart enough to do the right thing.)
Date: 15 Jun 2010 11:00:02
Message: <4c179572@news.povray.org>
scott wrote:
> Sure, but just as an example, what's the fastest way to sort a 10 KB array
> when you have 16 KB or RAM?
You just go and do it. I'm sure the sorting algorithm fits in the remaining
6KB.
Or did you get those two numbers backwards?
Date: 15 Jun 2010 11:59:01
Message: <4c17a345$1@news.povray.org>
Well, two gig is a bit high, but several hundred meg is not uncommon.
Date: 15 Jun 2010 13:11:11
Message: <4c17b42f@news.povray.org>
Like I said, it seems there's a relationship between capacity and speed,
such that by the time you get to this size, there wouldn't be much speed
advantage to putting it on-chip.
