![](/i/fill.gif) |
4c0e6853$1@news.povray.org...
> Well, it could certainly be worth a giggle...
Here it is. Have fun figuring that out. Note that it pulls the data from a
database first. Also I've removed the code that writes the results in the
database.
G.
Public Sub Regression(RelationCode, NEXP)
Dim MaBd As Database, stSQL As String, DataSet As Recordset
Dim I As Integer, J As Integer, K As Integer, NOBS As Integer
Dim S(0 To 9) As Double, SSY As Double, D As Double, A As Double
Dim SPYX(0 To 9) As Double, SPXX(0 To 9, 0 To 9) As Double, VY As Double
Dim VYX(0 To 9) As Double, VXX(0 To 9, 0 To 9) As Double
Dim B(0 To 9) As Double, SB(0 To 9) As Double, R2 As Double, R2ADJ As
Double, SY As Double
Dim F As Double, T(0 To 9) As Double, P As Double, PCoeff(0 To 9) As Double
Dim ta As Double, Pa As Double
Dim Unitcode As Integer, DataBasisCode As Integer, stCoeff As String
Dim SST As Double, SSR As Double, SSD As Double, SA As Double
Dim MSD As Double, MSR As Double, M(0 To 9) As Double
Set MaBd = CurrentDb
' NEXP = number of predictors
stSQL = "SELECT DISTINCTROW Y "
For I = 1 To NEXP
stSQL = stSQL & ", X" & CStr(I)
Next I
stSQL = stSQL & " FROM RELATION_TEMP"
'Debug.Print stSQL
NOBS = 0
Set DataSet = MaBd.OpenRecordset(stSQL)
If DataSet.EOF Then Exit Sub
DataSet.MoveFirst
' Browse the data table
Do Until DataSet.EOF
' sum of squares Y
SSY = SSY + (DataSet(0) ^ 2)
' for all variables
For I = 0 To NEXP
'sum of data
S(I) = S(I) + DataSet(I)
Next I
' for all predictors
For I = 0 To NEXP - 1
' sum of products Y * X
SPYX(I) = SPYX(I) + DataSet(0) * DataSet(I + 1) ' sum of products
Y*x
For J = 0 To NEXP - 1
' sum of products X * X
SPXX(I, J) = SPXX(I, J) + DataSet(I + 1) * DataSet(J + 1)
Next J
Next I
' number of observations
NOBS = NOBS + 1
DataSet.MoveNext
Loop
DataSet.Close
If (NOBS - NEXP - 1 <= 0) Then
frm!CurrentMessage = "Relation " & RelationCode & " - Not calculable :
N obs <= " & Str(NEXP + 1)
Exit Sub
End If
' total sum of squares and variance of Y
SST = (SSY - S(0) ^ 2 / NOBS)
VY = SST / NOBS
' Means of Y and X (M(0)=mean for Y)
For I = 0 To NEXP
M(I) = S(I) / NOBS
Next I
' covariances of Y and X
VYX(I) = (SPYX(I) - (S(0) * S(I + 1)) / NOBS) / NOBS
Next I
' covariances of the predictors X
VXX(I, J) = (SPXX(I, J) - (S(I + 1) * S(J + 1)) / NOBS) / NOBS
Next J
Next I
' inversion (Gauss method) of the XX covariance matrix
' the original matrix is destroyed
For K = 0 To NEXP - 1
D = VXX(K, K)
If (D = 0) Then End 'null determinant
VXX(K, K) = 1
VXX(K, J) = VXX(K, J) / D
Next J
If (I <> K) Then
D = VXX(I, K)
VXX(I, K) = 0
VXX(I, J) = VXX(I, J) - D * VXX(K, J)
Next J
End If
Next I
Next K
' calculation of the coefficients
B(I) = B(I) + VXX(I, J) * VYX(J)
Next J
Next I
' calculation of the sum of squares of deviations attribuable to the
regression
SSR = SSR + B(I) * VYX(I) * NOBS
Next I
' calculation of the sum of squares of deviations about the regression
SSD = SST - SSR
' R2 and R2 for the degrees of freedom
R2 = 1 - (SSD / SST)
R2ADJ = 1 - (SSD * (NOBS - 1)) / (SST * (NOBS - NEXP - 1))
' mean square attribuable to the regression
MSR = SSR / NEXP
' mean square of deviations about the regression
MSD = SSD / (NOBS - NEXP - 1)
' standard error estimate
SY = Sqr(MSD)
' F value and Probability
F = MSR / MSD
P = FISHER(F, NEXP, NOBS - NEXP - 1)
' calculation of the standard error of the regression coefficients
SB(I) = Sqr(VXX(I, I) * MSD / NOBS)
T(I) = B(I) / SB(I)
PCoeff(I) = TSTUDENT(T(I), NOBS - NEXP - 1)
Next I
' constant a
A = M(0)
A = A - B(I) * M(I + 1)
Next I
' standard error of constant a, t-value and probability
SA = 0
For I = 1 To NEXP
For J = 1 To NEXP
SA = SA + M(I) * M(J) * VXX(I - 1, J - 1)
Next J
Next I
SA = Sqr(MSD * (1 + SA) / NOBS)
ta = A / SA
Pa = TSTUDENT(ta, NOBS - NEXP - 1)
'For i = 0 To NEXP - 1
' Debug.Print SY
'Next i
End Sub
Public Function TSTUDENT(T, DF)
' Calculates the probability of Student's t-distribution value of being less
in absolute value than t
Dim teta As Double, I As Integer, K As Integer, A As Double, P As Double, Q
As Double, cs As Double
Dim Pi As Double
Pi = 3.14159265358979
T = Abs(T)
teta = Atn(T / Sqr(DF))
If DF Mod 2 = 0 Then ' even degrees of freedom
I = DF / 2 - 2
Q = 1
For K = 0 To I
Q = Q * (K * 2 + 1) / (K * 2 + 2)
cs = Cos(teta) ^ (K * 2 + 2)
A = A + Q * cs
Next K
A = Sin(teta) * (A + 1)
Else ' odd degrees of freedom
If DF > 1 Then
I = (DF - 1) / 2 - 1
Q = 1
For K = 0 To I
If K = 0 Then
Q = 1
Else
Q = Q * (K * 2) / (K * 2 + 1)
End If
cs = Cos(teta) ^ (K * 2 + 1)
A = A + Q * cs
Next K
A = (2 / Pi) * (teta + Sin(teta) * A)
Else
A = 2 * teta / Pi
End If
End If
A = 1 - A
If (A < 0.0001) Then A = 0
TSTUDENT = A
' Debug.Print P
End Function
Public Function FISHER(F, DF1, DF2)
' Calculates the probability of a F = (X1/DF1)/(X2/DF2)
Dim teta As Double, X As Double, I As Integer, K As Integer, A As Double, B
As Double
Dim P As Double, Q As Double, cs As Double, NU1 As Double, NU2 As Double
Dim Pi As Double
If DF1 Mod 2 = 0 Or DF2 Mod 2 = 0 Then
X = DF2 / (DF2 + DF1 * F)
If DF1 Mod 2 = 0 Then
NU1 = DF1
NU2 = DF2
Else
NU2 = DF1
NU1 = DF2
X = 1 - X
End If
I = (NU1 - 2) / 2 - 1
Q = 1
P = 1
For K = 0 To I
Q = Q * (NU2 + K * 2) / (K * 2 + 2)
P = P + Q * ((1 - X) ^ (K + 1))
Next K
P = (X ^ (NU2 / 2)) * P
Else
P = 1 - (X ^ (NU2 / 2)) * P
End If
Else
teta = Atn(Sqr(DF1 * F / DF2))
' Debug.Print "teta=", teta
NU1 = DF1
NU2 = DF2
' calculation of A
If NU2 > 1 Then
I = (NU2 - 1) / 2 - 1
For K = 0 To I
If K = 0 Then
Q = 1
Else
End If
A = A + Q * Cos(teta) ^ (K * 2 + 1)
Next K
Else
A = 2 * teta / Pi
End If
' calculation of B
If NU1 > 1 Then
B = 1
Q = 1
If (NU1 > 3) Then
I = (NU1 - 3) / 2 - 1
For K = 0 To I
Q = Q * (NU2 + K * 2 + 1) / (K * 2 + 3)
B = B + Q * Sin(teta) ^ (K * 2 + 2)
Next K
End If
' Debug.Print "b=", B
' note : the exponentation is necessary due to overflow
B = (2 / Sqr(Pi)) * Exp(FACTLN((NU2 - 1) / 2) - FACTLN((NU2 - 2) /
2)) * Sin(teta) * (Cos(teta) ^ NU2) * B
Else
B = 0
End If
P = 1 - A + B
End If
If (P < 0.0001) Then P = 0
FISHER = P
End Function
Public Function FACTRL(N)
Dim J As Integer, ntop As Integer
Dim A(1 To 33) As Double
ntop = 0
A(1) = 1
If (N < 0) Then
End
ElseIf (N <= ntop) Then
FACTRL = A(N + 1)
ElseIf (N <= 32) Then
For J = ntop + 1 To N
A(J + 1) = J * A(J)
Next J
ntop = N
FACTRL = A(N + 1)
Else
FACTRL = Exp(GAMMALN(N + 1))
End If
End Function
Public Function GAMMALN(xx)
' Holy cow!
Dim ser As Double, stp As Double, tmp As Double
Dim X As Double, Y As Double, cof(1 To 6) As Double
Dim J As Integer
cof(1) = 76.1800917294715
cof(2) = -86.5053203294168
cof(3) = 24.0140982408309
cof(4) = -1.23173957245015
cof(5) = 1.20865097386618E-03
cof(6) = -5.395239384953E-06
stp = 2.506628274631
X = xx
Y = X
tmp = X + 5.5
tmp = (X + 0.5) * Log(tmp) - tmp
ser = 1.00000000019001
For J = 1 To 6
Y = Y + 1
ser = ser + cof(J) / Y
Next J
GAMMALN = tmp + Log(stp * ser / X)
End Function
Public Function FACTLN(N)
Dim A(1 To 100) As Double
Dim I As Integer
For I = 1 To 100
A(I) = -100
Next I
If N < 0 Then End
If N <= 99 Then
If A(N + 1) < 0 Then A(N + 1) = GAMMALN(N + 1)
FACTLN = A(N + 1)
Else
FACTLN = GAMMALN(N + 1)
End If
End Function
![](/i/fill.gif) |
