POV-Ray : Newsgroups : povray.off-topic : BPM Server Time
17 Mar 2026 18:07:35 EDT (-0400)
  BPM (Message 71 to 77 of 77)
Subject: Re: Microcode
Date: 11 Jun 2010 12:41:58
Message: <4c126756$1@news.povray.org>
Mike Raiford wrote:
> A sequence of one or more control signal sets configured to execute the
> desired instruction.
I guess, depending on how you define "control signal sets" and "configured"
and "sequence", sure.  *I* consider it microcode if the configuration is ROM
instead of hardwired logic, and "sequence" implies having something
counter-like to sequence it.
The idea being that all you need to change what instructions a microcoded
CPU supprts is to change the ROM itself without rewiring other gates.
People used to build computers that would load different microcode depending
on the program you were running. The first Smalltalk machines had a
Smalltalk microcode set, so there weren't any "primitives" - the CPU ran
Smalltalk code directly. Other machines could switch between FORTRAN and
COBOL microcode.  The original 8" floppies were designed to hold the
microcode for those mainframes.
> n mine, for example, the microcode rom is
> basically a big LUT allowing for 16 microcode steps each instruction,
> since an instruction can have more than one phase:
And how do you step thru those instructions?  A program counter type thing?
Then it's likely microcode in my book. :-)
Don't think I'm trying to be authoritative on this one.  There's probably
some actual official definition out there that's relatively arbitrary due to
things on the edge of the definition.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Subject: Re: New BPM
Date: 11 Jun 2010 12:44:23
Message: <4c1267e7$1@news.povray.org>
Invisible wrote:
> Even so, I'd suggest that it's more or less infeasible to determine how
> long a calculation takes.
Nonsense. People do it all the time.  If nothing else, do it by
experimentation. Try sleeping one milisecond using the technique, measure
how fast the clock goes, and adjust. You can even adjust dynamically based
on when you wake up. If you wake up 29 microseconds later than you asked,
subtract 29 microseconds the next time.
> Either way, this would be *so much* easier if I could ask for absolute
> rather than relative start times...
Read the absolute time, subtract it from the time you want to wake up,
subtract the length of time you were late last time, and sleep that long.
When you wake up, read the absolute time, subtract it from the time you
wanted to wake up, and store that for the next cycle.
> (I also love the way the internal implementation look like it's likely
> to fail if you call threadDelay just before midnight... That's a nice
> touch.)
What system are you looking at?
Date: 11 Jun 2010 13:20:00
Message: <4c127040@news.povray.org>
> thing? Then it's likely microcode in my book. :-)
well, of course there's some sort of counter. Else how would it work? ;)
> due to things on the edge of the definition.
I'm sure there is ... But I don't necessarily think it has to be ROM,
per se, it could be a gate array...
~Mike
Date: 11 Jun 2010 13:37:47
Message: <4c12746b$1@news.povray.org>
That's what I'm saying. It *is* possible to design logic that doesn't have a
counter like that.
Anything that works like a ROM where all you need to do is change *that*
part to have a new instruction set would do. Whether your ROM is implemented
with wires or gates doesn't matter that much to me.
Date: 12 Jun 2010 04:57:01
Message: <4c134bdd$1@news.povray.org>
Darren New wrote:
>> By contrast, the CPU I'm designing has no such thing.
> I agree. There's no code there. You have hardwired logic.
It seems we are in agreement then.
(I'm actually wondering if microcode would have been easier though...!)
http://blog.orphi.me.uk/
Date: 12 Jun 2010 06:04:11
Message: <4c135b9b$1@news.povray.org>
The GHC threading library.
The source code looks like it does a POSIX "get time of day" call, and
then uses the "microseconds past midnight" field to determine when the
schedule the wakeup call.
It strikes me that if between now and the intended wakeup time the clock
wraps past midnight, things are going to go wrong. But maybe I'm mistaken...
I'm also not sure if the same thing happens under Windows. It's kinda
tricky to follow all the CPP directives.
Subject: Scientific experiments
Date: 12 Jun 2010 14:43:38
Message: <4c13d55a$1@news.povray.org>
Right. So I just fired up Cubase, imported an audio track, dialed in the
BPM I found from that website, and listened to the click track against
the recording.
Except for some phase-alignment problems, and the click track gradually
going out of phase, the BPM readings I had were very, very close to
being correct. Close enough that it's difficult to figure out whether
they're too high or too low.
In other words, the trivial algorithm the website uses already produces
really very accurate measurements. Nothing to fix here. (Unless you
actually wanted beat-perfect matching, rather than a general estimate of
speed...)
