POV-Ray : Newsgroups : povray.off-topic : BPM Server Time
5 Apr 2026 05:38:40 EDT (-0400)
  BPM (Message 61 to 70 of 77)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: New BPM
Date: 10 Jun 2010 12:17:39
Message: <4c111023$1@news.povray.org>
Invisible wrote:
> I believe the problem is that the library won't let me specify an
> absolute time, only relative times. So if I was "wait 100 ms", but the
> other processing that the program does takes 1 ms, the delay ends up
> being 101 ms, not 100 ms.
Well, yeah.
> Still, since no other API is available, there's not much I can do about
> it. (Other than whinge at the developers and see if it gets fixed in the
> next release of the library...)
No, you do your processing, then you look at the highest resolution clock
you have and figure out how much *longer* you have to wait, then you wait.
Adjusting for the length of time it takes to figure out how much longer you
have to wait.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Subject: Re: Microcode
Date: 10 Jun 2010 13:25:04
Message: <4c111ff0$1@news.povray.org>
>> And you actually know how it was wired up internally, do you?
> http://www.pagetable.com/?p=39
...Christ that's complicated! o_O
> so now it's an argument more over "what is microcode" than it is
> over whether a 6502 has microcode.
Yeah, well, that figures. ;-)
> I'd say anything that steps thru a ROM with a counter during one
> instruction is probably microcode, myself.
Well, a "ROM" can be just a grid of wires, some connected and some not.
http://blog.orphi.me.uk/
Date: 10 Jun 2010 13:25:51
Message: <4c11201f$1@news.povray.org>
>> about it. (Other than whinge at the developers and see if it gets
>> fixed in the next release of the library...)
> clock you have and figure out how much *longer* you have to wait, then
> you wait. Adjusting for the length of time it takes to figure out how
> much longer you have to wait.
Except that figuring out how long you need to wait would *itself* take
time...
Date: 10 Jun 2010 14:39:27
Message: <4c11315f@news.povray.org>
Yes?  I was saying something with a program counter that runs mulitple
instructions per CPU instruction would count as microcode, regardless of how
you stored the code it's running.
Date: 10 Jun 2010 14:39:53
Message: <4c113179$1@news.povray.org>
> time...
You missed the second sentence of the two-sentence paragraph, didn't you?
Date: 10 Jun 2010 15:15:45
Message: <4c1139e1$1@news.povray.org>
> time...
Here's another funny thing:
In CDMA cell phones (at least), not only do they have to figure out how long
they have to wait, they have to keep track of how long different parts of
the chip have been turned on, to compensate for the fact that the crystal
will vibrate at different speeds depending on how warm it is. So if you have
to read two packets before turning off, you have to plan to wake up slightly
later than if you only read one packet before you turned off, because the
chip will be running warmer and faster.
Date: 11 Jun 2010 04:00:19
Message: <4c11ed13$1@news.povray.org>
> how you stored the code it's running.
So if it doesn't use a counter it's not microcode?
As you say, we're just arguing about semantics now. I always thought of
microcode as being a block of ROM (or even some kind of EPROM) which
actual address decode circuitry, so that you can execute jumps and so
forth. By contrast, the CPU I'm designing has no such thing. It's just
that on each clock pulse, a different control line becomes active, and
that line connects to one or more control lines (possibly via logic
gates that pass the signal only if the opcode has certain bits set). I
wouldn't call that microcode; it'd call that "a custom arrangement of
gates".
Date: 11 Jun 2010 04:02:09
Message: <4c11ed81$1@news.povray.org>
>>> then you wait. Adjusting for the length of time it takes to figure
>>> out how much longer you have to wait.
>> time...
No, I failed to comprehend it.
Even so, I'd suggest that it's more or less infeasible to determine how
long a calculation takes.
Either way, this would be *so much* easier if I could ask for absolute
rather than relative start times...
(I also love the way the internal implementation look like it's likely
to fail if you call threadDelay just before midnight... That's a nice
touch.)
Date: 11 Jun 2010 08:47:40
Message: <4c12306c$1@news.povray.org>
> gates".
I might be wrong, but my definition of microcode is thus:
A sequence of one or more control signal sets configured to execute the
desired instruction. On mine, for example, the microcode rom is
basically a big LUT allowing for 16 microcode steps each instruction,
since an instruction can have more than one phase:
For example
ld a, [si]
decodes to a series of instructions:
output the contents of si to the address latches
fetch the memory word from that location and store it in the register a
fetch next instruction
(The second can be done is a single step, due to the mux/dmux pair that
allows most registers or busses to be connected to other registers or
busses)
~Mike
Date: 11 Jun 2010 12:35:33
Message: <4c1265d5$1@news.povray.org>
>> of how you stored the code it's running.
That's just *my* definition. If it doesn't have something serving as a
program counter, I wouldn't classify it as "code" instead of "logic". In the
case of the 6502, it's pretty clear that the T1 thru T6 lines act as a
program counter, and the other bits are acting as the code.
> forth.
Basically. And normally its instructions are wide enough to have one bit per
gating signal inside the CPU (so, a line for "register 1 reads bus", a line
for "register 2 writes bus" a line for "R3 writes to address bus" a line for
"PC reads from data bus", along with selecting the proper ALU unit, etc. So
microcode is not uncommonly 100's of bits wide. And it usually has the new
Micro-PC in each instruction too, so every instruction is a branch.
> gates".
I agree. There's no code there. You have hardwired logic.
