POV-Ray : Newsgroups : povray.off-topic : Electronics activity Server Time
14 May 2026 21:04:58 EDT (-0400)
  Electronics activity (Message 56 to 65 of 65)
Subject: Re: Electronics activity
Date: 26 May 2010 04:54:38
Message: <4bfce1ce$1@news.povray.org>
4bfcd758$1@news.povray.org...
> easier. (Except stripping the wires. I suck at that!)
Get a pair of strippers!
Date: 26 May 2010 04:58:16
Message: <4bfce2a8$1@news.povray.org>
Now that's more like it. ;-)
Date: 26 May 2010 07:59:43
Message: <4bfd0d2f$1@news.povray.org>
Haha ... Makes it a bit hard to concentrate though.
~Mike
Date: 26 May 2010 08:01:36
Message: <4bfd0da0$1@news.povray.org>
On 5/25/2010 11:52 AM, Darren New wrote:
> Mike Raiford wrote:
>> f I had read a tutorial on working with logic gates,
> Heck, if you've ever used a SCSI device you know *that* much. :-)
Wait ... I thought those were terminating resistors? Entirely different
function.
~Mike
Date: 26 May 2010 11:43:04
Message: <4bfd4188$1@news.povray.org>
> function.
They're not pull-down resistors at the end of the chain?
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 26 May 2010 17:14:17
Message: <4bfd8f29$1@news.povray.org>
Just did a quick read on SCSI termination. Yes, they are pull down
resistors!
~Mike
Date: 26 May 2010 18:16:49
Message: <4bfd9dd1$1@news.povray.org>
> resistors!
I never looked it up specifically, but it's pretty obvious from looking at
the SCSI protocol specs that the addressing and bus mastering and such works
by pulling down zeros and letting ones float. Hence the "SCSI Priority"
being the LUN and having "0" always be the host.  It's a pretty common way
of working a shared bus, from ISDN to those one-wire protocol capsules.
Date: 27 May 2010 09:17:52
Message: <4bfe7100$1@news.povray.org>
> at the SCSI protocol specs that the addressing and bus mastering and
> such works by pulling down zeros and letting ones float. Hence the "SCSI
> Priority" being the LUN and having "0" always be the host. It's a pretty
> common way of working a shared bus, from ISDN to those one-wire protocol
> capsules.
Yep... Except often times when I think terminating resistor, I'm
thinking a resistor connected at the ends of the line to damp reflected
signals.
~Mike
Date: 27 May 2010 11:52:14
Message: <4bfe952e$1@news.povray.org>
> signals.
Given that SCSI allows cables up to 50' or something, I suspect they serve
both purposes.
Subject: Switches
Date: 30 May 2010 07:33:04
Message: <4c024cf0@news.povray.org>
Well let me see now... I bought a couple of switches and resistors, and
spent the morning soldering them together. I now have two switches - a
rocker switch and a push switch. In one position, you get logic 0, in
the other position, you get logic 1, and no floating inputs. Yay, me!
It's kind of frustrating how many problems I'm having with this whole
exercise - and most of them aren't electrical. They're mundane physical
issues. (E.g., one of the switches I bought has metal terminals with
small holes to poke the wires through. Except they're too tiny to poke
any wire through!)
Still, it was gratifying to flick some switches and watch an LED light,
correctly implementing the truth table of a NAND gate.
I was about to try rigging up a simple binary half adder - and then I
realised that this requires 7 NAND gates, and I obviously only have 4. >_<
I've bought a small plastic box, and I'm hoping to somehow mount some
switches on it, common-up the power rails, and end up with a box which I
can just connect to the power and have a nice set of output wires. But
this requires drilling and soldering and all sorts.
It's times like this where I miss my old electronics kit. :-( Everything
seemed so much easier back then...
http://blog.orphi.me.uk/
