POV-Ray : Newsgroups : povray.off-topic : Electronics activity Server Time
17 Mar 2026 06:36:03 EDT (-0400)
  Electronics activity (Message 6 to 15 of 65)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Electronics activity
Date: 23 May 2010 09:19:13
Message: <4bf92b51@news.povray.org>
On 23/05/2010 12:12 PM, Orchid XP v8 wrote:
>>> And then I walked back into the shop and bought some batteries. Because,
>>> batteries is pretty much a normal price really.
>> The next thing you should build is a dual voltage power supply.
> Uh, why?
> 1. If I actually wanted one, I could *buy* one for a very modest price.
> (And that way, it would actually work properly.)
Why not? It is educational, useful, fun and profesional. You will often
use one supply (5V for TTL Vcc) and another for a signal or maybe a
relay supply.
> 2. I don't know how many amp-hours an AA battery is, but with each IC
> using several micro-watts of power, I don't envisage running them flat
> any time soon.
But you will sometime and there is always the chance of you not noticing
the battery voltage dropping and your circuts not working properly.
But then I only worked in electronics for 25 years so what do I know ;-)
Best Regards,
Date: 23 May 2010 09:44:59
Message: <4bf9315b$1@news.povray.org>
On 23/05/2010 12:10 PM, Orchid XP v8 wrote:
> Well, I don't know where my soldering iron, solder or wire cutters are.
> And I know from experience that trying to strip wires is approximately
> impossible, and trying to tin the ends is very tricky.
Using propper snips gently compress the insulation,about a 1/4 to 3/8 of
an inch (6 to 10 mm) rotate the snips 90 degrees left then right.
Release the wire and grip it again where you first gripped it with the
snips and pull. Alternatively using a sharp knife, score the insulation
to the wire all round the wire and pull the insulation off with your
fingernails or teeth.
To tin stranded wire twist the strands so that none are sticking out.
Have either a loop of multicore solder sitting on your bench with a
couple of inches sticking up or your spool of solder with some solder
sticking up. Tin the iron with solder so that there is a drip on the
iron and tin a little bit of the wire. Take the wire to the top of the
solder and with the iron, gently melt the solder whilst drawing the wire
through the melted solder.
It is harder to write it than to do it. :-)
Best Regards,
Date: 23 May 2010 10:24:01
Message: <4bf93a81$1@news.povray.org>
>> Uh, why?
> Why not?
Because when it doesn't work, I will probably end up killing myself, for
starters... A power supply is far too complicated for me to get right.
>> any time soon.
Oh, I'm sure they'll do that anyway. ;-)
Heh, where to buy capacitors cheap, I imagine. ;-)
http://blog.orphi.me.uk/
Date: 23 May 2010 10:29:03
Message: <4bf93baf$1@news.povray.org>
With the thickness of wire I'm using, 6 mm would be several times the
total diammeter of the wire. ;-)
Oddly, this is significantly harder than you'd think...
The 30-year-old solder I found seems to be quite "bubbly", which makes
it difficult to do this. It also doesn't seem to want to melt very
evenly, resulting on lots of blobs, or only one side of the wire tinned.
Now I remember why I wanted to buy wire ready-cut. ;-)
Still, I have just spent about an hour sitting on my driveway with a
workmate, several bunches of wire and a soldering iron. People probably
think I'm weird now... Everybody's out mowing the lawn, riding bicycles,
having a BBQ or sunbathing, and some sad tosser over at number 11 is
sitting with a bunch of wires and tools.
Date: 23 May 2010 10:40:13
Message: <4bf93e4d@news.povray.org>
Buy? ROTFL
Best Regards,
Date: 23 May 2010 10:42:10
Message: <4bf93ec2$1@news.povray.org>
> Buy? ROTFL
Let me guess... REAL engineers MAKE capacitors out of foil and wrapping
paper? :-P
Date: 23 May 2010 10:50:01
Message: <4bf94099@news.povray.org>
So, you can always trim it.
You might be better using solid core wire if it is that thin.
These sort of things are learned by experience and listening to the old
men round the camp fire
I know, strip and tin one end first then strip the other end. That stops
the strands getting mangled.
Tin the end first then when the strands can't separate do the length.
Use a dry iron to stroke the blobs off.
BTW modern solder has better flux.
LOL
Good job they can't see you with PovRay ;-)
Best Regards,
Date: 23 May 2010 10:50:48
Message: <4bf940c8$1@news.povray.org>
>> Buy? ROTFL
> paper? :-P
LOL, They get them from work ;-)
Best Regards,
Date: 23 May 2010 11:10:03
Message: <4bf9454b$1@news.povray.org>
>> paper? :-P
There are people who get paid money to do stuff involving capacitors? o_O
Date: 23 May 2010 11:19:51
Message: <4bf94797$1@news.povray.org>
>>> paper? :-P
:-D
Best Regards,
