POV-Ray : Newsgroups : povray.off-topic : Electronics research Server Time
5 Apr 2026 16:03:15 EDT (-0400)
  Electronics research (Message 85 to 94 of 104)
Subject: Re: Electronics research
Date: 23 May 2010 10:39:01
Message: <4bf93e05$1@news.povray.org>
scott wrote:
> You should never be leaving any inputs as floating anyway, that's just
> asking for trouble (for example if you use a different IC series later).
> Best to always tie your inputs to whatever you want them to be.
So what might be a good value for a pull-down resistor then?
(4.5V supply, 74HCxx ICs.)
http://blog.orphi.me.uk/
Date: 23 May 2010 17:22:00
Message: <4bf99c78$1@news.povray.org>
Am 23.05.2010 16:38, schrieb Orchid XP v8:
A very common choice is 10 kOhm.
Date: 24 May 2010 03:48:05
Message: <4bfa2f35@news.povray.org>
OK. That should only be a few pence...
Date: 24 May 2010 08:39:39
Message: <4bfa738b$1@news.povray.org>
On 5/21/2010 9:57 AM, Invisible wrote:
>>> That and the subcircuit label...
>> Actually, if you click on the subcircuit, you'll see some items in the
>> attributes window. One item is label. But, if you have multiple
>> instances of the same circuit and change the label for one, it changes
>> for all.
>> Again, somewhat annoying.
> Yes, the "label" is so that if you have a dozen subcircuits, you can
> tell which type each one is. It's _not_ for labelling a specific
> instance. (E.g., if you insert a register, you can't label it with a
> register name. You can only label it with the kind of register it is.)
Right, but sometimes it would be nice to have a label that identifies
the particular instance. At least, that's what I would expect when
clicking on the item.
>>> It's trying to be helpful by detecting circuits which are unstable.
>> I think it's more or less bailing out on a potential infinite loop.
> Hey, if it just wasn't handled, the program would crash. The fact that
> it's *noticing* the problem means that it's doing extra processing
> specifically to deal with it. But yes, it is a tad annoying. (Presumably
> the problem goes away if you use the built-in latch primitive...)
Well, of course the built-in latch primitive doesn't exhibit that
problem. But with the Falstad app, the oscillation tends just to
continue due to the way it's simulated. Logisim uses a propagation
method where the values are carried from one component to the next,
which can cause an infinite loop. Whereas Circuit Sim uses a timeslice
method, where the entire circuit is calculated each tick, an oscillation
can occur without any detriment to the program.
>>> Yeah. The whole wiring concept is just awkward. For example, Reactor
>>> (which has nothing to do with electronics but does involve wiring things
>>> together) has wires that go in a straight line from pin to pin. And when
>>> you move stuff, IT DOESN'T BREAK ALL THE WIRES OR RANDOMLY CONNECT THEM
>>> TO OTHER PINS! Sheesh, it's not rocket science...
>> Actually, it can be a little tough to reroute wires when restricted to
> All I know is that I seem to spend more time trying to figure out how to
> move a component slightly to the side to make more space than actually,
> you know, designing my stuff! >_<
Yeah, Routing can be a pain when moving components. You can turn on an
experimental feature where it allows you to sort of autoroute the wires
in some cases when moving a component, but I've found if you move too
far it will make bad connections. The algorithm that autoroutes needs to
be a bit smarter, but I think it may be an instance of the halting problem.
>>> I'd prefer something less ugly to look at, personally.
>> Well, sure, but function before form. I mean,
>> this one was pretty, but was a pain to work with:
>> http://www.logiccircuit.org/
> What's up with it?
Not a clue... all the pretty ones aren't all that bright. ;)
>>> KLogic was easier to wire up. And it could do simulation graphs, which
>>> is extremely useful when you're trying to check, e.g., that your flip
>>> actually flops on the rising edge.
>> Also, not available for Windows platform...
> I'd be surprised if nobody has ported it yet... but yeah, that's the
> least of the problems. A simulator that gives you THE WRONG ANSWER isn't
> very useful.
No, I suppose not. :)
>> http://www.falstad.com/circuit/
> I didn't even know that thing had logic gates...
It does. While it makes a great general circuit simulator, for anything
non-trival its far from ideal for logic simulation, though.
>> The hex editor when I get finished with it will be very nice, though.
> No it won't. You'll never finish it. >:-)
Now I'll finish it just to prove you wrong, so ... Nyah!
~Mike
Date: 24 May 2010 08:56:36
Message: <4bfa7784$1@news.povray.org>
I won't disagree with that... ;-)
The Halting Problem is unsolvable. I doubt wire routine is unsolvable.
Finding the "perfect" wire routine sounds a bit like the Travelling
Salesman problem, which is NP-Complete, not *not* unsolvable. And a
routing algorithm which doesn't alter topology and gives "reasonable"
results ought to be quite possible, though possibly not easy...
>> What's up with it?
I tried it on Friday. Jesus, it sucks so hard! Eats RAM like candy,
locks up for minutes at a time for no apparent reason, and doesn't even
look particularly good anyway. Basically there's nothing to recommend
it. (Plus I had to wait 30 minutes for the .Net framework to install...)
Yeah, it's designed to show you examples, not for serious design work.
Heh. I'd like to see that. ;-)
Date: 24 May 2010 08:59:01
Message: <4bfa7815$1@news.povray.org>
BTW:
http://sourceforge.net/projects/logicsim/
Requires .NET Framework 3.5
Only really just tiny pieces of the UI implemented, but you can sort of
see how it will work.
~Mike
Date: 24 May 2010 10:08:36
Message: <4bfa8864@news.povray.org>
>> wires in some cases when moving a component, but I've found if you
>> move too far it will make bad connections. The algorithm that
>> autoroutes needs to be a bit smarter, but I think it may be an
I suppose that's correct.
http://www.freerouting.net/index.php?page=home
But can be rather difficult to calculate an optimal route. Of course,
the program above treats wires as physical obstacles.
On thinking a bit more about it, it's probably not horribly difficult.
Yeah, I didn't get that far.... about the point where I had to drag and
drop components to the circuit was when I decided it wasn't a viable
solution.
>> anything non-trival its far from ideal for logic simulation, though.
Yup, but a great learning tool :)
You'll see... you'll see.
~Mike
Date: 24 May 2010 15:16:31
Message: <4BFAD097.1030008@gmail.com>
>> later). Best to always tie your inputs to whatever you want them to be.
There is seldom a need to use a pull-down resistor at the input. You can
simply connect it to the ground. With e.g. a 7400 you can connect both
inputs together in stead of one to the positive power supply line to get
functionally an inverter (that is often easier to route than the
alternative).
Date: 25 May 2010 03:05:54
Message: <4bfb76d2$1@news.povray.org>
Unless you are connecting a switch to the input, I don't see why you'd need
a pull-down resistor, just connect it directly to ground.
Date: 25 May 2010 04:06:32
Message: <4bfb8508$1@news.povray.org>
> need a pull-down resistor, just connect it directly to ground.
Indeed. So it looks like I'm going to end up needing a seperate
pull-down resistor for each "external" input to the logic system. I was
hoping I could get away with just one, but that apparently won't work at
all...
Oh well, I guess I'm not going to have all that many manual inputs.
The other problem is that I suspect connecting an LED to an output drags
the voltage out of spec, so I probably can't connect the same output to
an input. I guess I'll just buy myself a hex buffer and be done with it.
