POV-Ray : Newsgroups : povray.off-topic : Not a geek Server Time
16 Jun 2026 13:46:46 EDT (-0400)
  Not a geek (Message 51 to 60 of 259)
Subject: Re: Not a geek
Date: 11 May 2010 15:29:19
Message: <4be9b00f$1@news.povray.org>
On Tue, 11 May 2010 19:06:12 +0100, Orchid XP v8 wrote:
> Darren New wrote:
>> Also the narrator of Cosmos.  I don't know anyone who didn't watch
>> Cosmos.
> Apparently you don't know me then.
> What's Cosmos then?
A TV programme that was narrated by Carl Sagan.
http://tinyurl.com/26x3ade
Date: 11 May 2010 15:31:05
Message: <4be9b079$1@news.povray.org>
>> What's Cosmos then?
> A TV programme
Ah, well, that would explain it then. I don't watch TV. :-)
(The irony is that I don't watch TV because there's never enough science
to watch...)
http://blog.orphi.me.uk/
Date: 11 May 2010 15:31:55
Message: <4be9b0ab$1@news.povray.org>
On 11/05/2010 2:29 PM, Mike Raiford wrote:
> Actually, in the vein of computer science: For the fun of it I'm
> designing CPU from scratch. I plan to build it with TTL gates
Feck! About 35 years ago I built a digital clock out of TTL. It used 30
amps at 5 volts Vcc. The power supply was bigger than a modern PC.
> Eventually, I want to take a simplified version of that design and
> create a CPU entirely out of relays.
You are mad, you know ;-)
> One consideration for the relay version is that the machine should be
> able to halt and only resume processing on an interrupt. So, ideally,
> you'd give it inputs, issue a command, and send it clacking away to get
> a result.
Does your wife know about this ?
> The TTL version should be fun, too. I plan to have lots of LEDs to show
> what's happening inside the machine.
I hope that you have comprehensive fire insurance :-P
BTW let us know how you get on. :-)
Best Regards,
Date: 11 May 2010 15:33:26
Message: <4BE9B10A.1000504@gmail.com>
On 11-5-2010 15:29, Mike Raiford wrote:
> On 5/11/2010 7:41 AM, Invisible wrote:
>> You know that there are people who do scientific experiments *about*
>> computer programs, right? ;-)
> Yeah :)
> designing CPU from scratch. I plan to build it with TTL gates after I
> have the design complete and have vetted it through simulation. I have
> the ALU designed. (Fairly simple, it can add, perform bitwise logic and
> shift, as well as calculate the twos complement. Other operations will
> take multiple cycles) I also have most of the control logic put
> together, but I need to make some changes to ensure an ALU instruction
> can occur within 2 cycles (One to latch the ALU result, one to store the
> result in the accumulator)
Still more complicated than my own 1984 design. ;)
> create a CPU entirely out of relays. Obviously, I'd need keep the design
> as simple as possible, but still functional to keep the relay count
> down. Something about a bit stack of clacking relays with blinking
> lights really appeals to me. That machine will likely still have IC
> memory, though, but the registers will be relay latches.
> a result.
> It's fun stuff, and occupies a good deal of time. Also a great way to
> learn HOW a computer like the one you're sitting at actually works. e.g.
> how each instruction of machine code does what it does, etc...
If you do it to give you new insights into how to make a CPU than that
might qualify you as a scientist. The border is vague, possibly
something along the line of how deep the insight is, how many people
already know it (if nobody than you are definitely in) and if you are
able to pass on that knowledge. If you are paid to do so that also
helps, but you aren't.
Date: 11 May 2010 15:35:36
Message: <4be9b188$1@news.povray.org>
5 amps?!
How thick was the damned wire??
Hmm, yes... I think they're calling you a nutjob, Mike.
THIS IS THE REAL WTF! o_O
Date: 11 May 2010 15:36:09
Message: <4BE9B1AD.6000207@gmail.com>
On 11-5-2010 20:06, Orchid XP v8 wrote:
>> Cosmos.
you are too young.
> What's Cosmos then?
http://en.wikipedia.org/wiki/Cosmos:_A_Personal_Voyage
Date: 11 May 2010 15:36:22
Message: <4be9b1b6@news.povray.org>
On Tue, 11 May 2010 20:31:10 +0100, Orchid XP v8 wrote:
>>> What's Cosmos then?
>> A TV programme
> to watch...)
You would probably find QI interesting, not always about sciencey stuff,
but a good programme to watch.
But that also would explain why you haven't heard of some fairly well
known scientists or be aware of what their achievements are, things like
that tend to be newsworthy, and people often hear the names while
watching the news or various news commentary.
Jim
Date: 11 May 2010 15:37:13
Message: <4be9b1e9$1@news.povray.org>
Anybody else attempted this crazy task?
Depends on your definitions. I would say that anybody who follows the
scientific method is a scientist, regardless of whether what they
discover is actually new. But then, if you mean a *professional*
scientist, or even a *reputable* one, that's another matter... ;-)
Date: 11 May 2010 15:37:59
Message: <4BE9B21A.7040104@gmail.com>
On 11-5-2010 20:05, Orchid XP v8 wrote:
>> Again, Jane Goodall probably fits that bill.  If we counted people who
>> have lived in our lifetimes, Carl Sagan.  Vint Cerf, Sir Tim
>> Berners-Lee, both of whom I previously mentioned, are also quite well
>> known.
> I would refute that... Perhaps I need to do a straw poll when I go down
> the pub tonight? (Although I can't *pronounce* most of those names, so...)
Ah, this would be the perfect time to mention Dijkstra.
Date: 11 May 2010 15:38:10
Message: <4be9b222@news.povray.org>
I just remembered that I download from the net the circuit diagrams of a
Honeywell H316 which was made using TTL (and ferrite core memory) :-D
Best Regards,
