POV-Ray : Newsgroups : povray.off-topic : Web-based access to SQL database Server Time
16 Dec 2025 08:09:57 EST (-0500)
  Web-based access to SQL database (Message 1 to 10 of 11)
Subject: Web-based access to SQL database
Date: 29 Apr 2010 04:26:52
Message: <4bd942cc$1@news.povray.org>
I might soon be faced with the task of writing a web-based application
accessing an SQL database (MySQL probably) - unfortunately that's not
really my special area of knowledge. I can hack together a HTML page
with forms, even with CSS, and am somewhat familiar with JavaScript, but
that's about it (yet).
Any sophisticated suggestions what technology to use? CGI? PHP? JSP (I
can do some Java coding)? How about those fancy new frameworks like Ruby
on Rails and some such?
Robustness is probably paramount. Database is likely to be MySQL; web
server will probably be that ugly Microsoft thing (running on Windows of
course), but easy portability to Apache on Linux would be a great
benefit. (Then again, the guys might be more than willing to start on
Linux right away.)
Subject: Re: Web-based access to SQL database
Date: 29 Apr 2010 04:39:18
Message: <4bd945b6$1@news.povray.org>
Personally, I'd probably use Haskell. But then, I'm crazy.
If you use CGI then you can, in principle, use any programming language
in the world. (Realistically, any programming language that already has
a decent CGI library. You do *not* want to write this code yourself!)
It also depends on the complexity of what you want to do. If you just
want to grab some rows from a DB and show them in an HTML table, you can
probably do that pretty simply with just about _any_ technology. If you
want something more sophisticated like session management and so on, you
probably want something with prebuilt libraries to make the job easier.
When I was at uni, we used an Oracle DB which had some kind of plugin
that allowed you to run an SQL query and then apply XSLT to the
resultset to generate... well, you can generate HTML or XHTML or plain
text or just about any text-based format, really. I don't think XSLT is
Turing-complete, but for certain kinds of set-based transformations,
it's pretty darn easy.
Other than that, you're looking at Perl, PHP, ASP and so forth.
Personally I hate Perl, and PHP looks a mess, but I guess it depends on
what you actually want to do. Certainly if you have a problem getting
something like PHP to work, a quick Google search will probably give you
a million web pages explaining how to fix it.
I can't comment on Ruby on Rails or similar. Never tried it.
Date: 29 Apr 2010 05:43:44
Message: <4bd954d0$1@news.povray.org>
These days, one can setup an entire, complex web-based application in a
short time without writing a single line of code, so it really depends on
how specific your needs are. In most cases there's no need to reinvent the
wheel, and popular frameworks and content management systems have
modules/libraries (commercial or free) that take care of typical situations,
each system being more or less easily customisable. They'll handle SQL
queries, the display, theming, users management etc, and for the really
specific stuff you can develop the required modules/libraries yourself.
They're mostly OS-independent (and more or less SQL-engine-independent) too.
On the other hand it may be possible that the application is so peculiar
that it has to be built from scratch, or that using a framework/CMS is not a
good idea (performance issues, dependency hell, security). Perhaps you
should have a look at different frameworks and see what they offer (IIRC
there's a comparison chart somewhere on Wikipedia).
G.
4bd942cc$1@news.povray.org...
>really my special area of knowledge. I can hack together a HTML page with
>forms, even with CSS, and am somewhat familiar with JavaScript, but that's
>about it (yet).
> Any sophisticated suggestions what technology to use? CGI? PHP? JSP (I can
> do some Java coding)? How about those fancy new frameworks like Ruby on
> course), but easy portability to Apache on Linux would be a great benefit.
> (Then again, the guys might be more than willing to start on Linux right
> away.)
Date: 29 Apr 2010 09:08:58
Message: <4bd984ea@news.povray.org>
  PHP is nowadays what most use. I think some people use Python. Both have
libraries to easily interface with MySQL and to create http content.
Date: 29 Apr 2010 12:40:19
Message: <4bd9b673$1@news.povray.org>
> benefit.
You might want to peek at ASP.NET (and mono) to see if it'll do what you
want. I don't know how good their mysql support is, but IIRC it's not terrible.
If you're interfacing with lots of other libraries and/or servers, PHP is
probably the way to go, unfortunately.
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 29 Apr 2010 19:34:05
Message: <4bda176d$1@news.povray.org>
> Linux right away.)
Take your pick, everything you mentioned and more are usable. Since you
are looking at MS stuff, you have all of .NET; ASP, C#, and so on.
http://en.wikipedia.org/wiki/List_of_web_application_frameworks is a
good place to start. JQuery is close to JavaScript, though I read about
it because someone asked 'how do I do addition of integers that are
class elements, in javascript' (or something similar to that) and the
answer was "Use JQuery" instead of something rational. A friend who uses
it says "It is the answer to everything. It will make a link so you
don't need to write HTML, it will shut down a computer, it will bake a
sweet potato pie."
There isn't really a limit to what languages work now. I like my
applications to be applications, so Adobe AIR, SQLite built in for what
ever you can cache, and talking through what ever middle-ware you want
(PHP in my case) or directly to the server via sockets.
Date: 29 Apr 2010 20:56:38
Message: <4bda2ac6$1@news.povray.org>
JQuery is a javascript library. I'm not sure it's a server-side thing.
JQuery is kind of "this is what javascript should have been in the first
place."  Like, if you had to start over from scratch with CSS and JS, you'd
do something like javascript.
Date: 29 Apr 2010 21:00:57
Message: <4bda2bc9@news.povray.org>
	Django is the equivalent of Ruby on Rails in the Python world. I've
used it extensively.
	You could use PHP and write the SQL queries yourself (not fun). Stuff
like RoR and Django create the SQL queries for you (so it doesn't matter
much whether you use MySQL or some other supported database). *You*
write the "queries" in the language (Ruby or Python). No idea how good
the Windows support is - should be in the docs.
	There are some frameworks in PHP that do that for you, but I don't know
much about them.
	Even if you do use these frameworks to abstract away from SQL, you
still need to _design_ your database (what tables, what foreign keys,
etc). So you should learn the very basics of databases (I myself know
only as much).
	You may want to consider looking at CMS's like Drupal, Joomla, etc.
Using various modules/plugins, you may be able to set up your site
without writing any code.
I considered atheism but there weren't enough holidays.
Date: 30 Apr 2010 12:09:03
Message: <4bdb009f$1@news.povray.org>
> you'd do something like javascript.
It's something I haven't used. I looked at it, found people suggesting
it's use for things like "how do I add two numbers in javascript" and
figured it was, at best, vastly overused.
At worst, it is a joke played on us by it's creators. You know, like
C++. ;-)
Date: 30 Apr 2010 23:25:25
Message: <4bdb9f25$1@news.povray.org>
It is. Here is a XSLT stylesheet that can "convert" a TMML document
(Turing Machine Markup Language) into plaintext with the computation
result:
http://www.unidex.com/turing/utm.htm
