POV-Ray : Newsgroups : povray.off-topic : Context switching Server Time
5 Jul 2026 22:05:34 EDT (-0400)
  Context switching (Message 211 to 220 of 222)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Context switching
Date: 24 Apr 2010 14:27:35
Message: <4bd33817$1@news.povray.org>
>> Isn't trying to figure out why an arbitrary piece of code doesn't work
>> formally equivilent to the Halting Problem? (With non-termination simply
>> being the most basic kind of program bug...)
> You're not asking grep to tell you why it failed, just to tell you where
> in the code the error is so one can manually inspect the file and see if
> one can determine why the failure occurred.
Oh, sure. I just meant that even once grep has found the location for
you, the task you're attempting to perform is almost impossible anyway...
http://blog.orphi.me.uk/
Date: 24 Apr 2010 14:30:49
Message: <4bd338d9$1@news.povray.org>
Warp wrote:
> Orchid XP v8 <voi### [at] devnull> wrote:
>> why would you want to do this?
>   Why would one want to do pattern substitution?
No, why would you want to find anything that's a number, parse it, and
add one to it. It doesn't seem like a particularly useful example. I'm
sure the same techniques could be used to do something more useful, but
I can't think of an example.
Anyway, I forget how we even got started on this topic, but this debate
has gone on long enough to make a few things clear. It seems that
low-level text munging is useful for the kind of stuff you do, and not
especially useful for the kind of stuff I do. Let's leave it at that.
Date: 24 Apr 2010 14:41:08
Message: <4bd33b44$1@news.povray.org>
And... you program computers?  Why, if you find it almost impossible?
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 24 Apr 2010 16:33:22
Message: <4bd35592$1@news.povray.org>
>>> simply being the most basic kind of program bug...)
>> where in the code the error is so one can manually inspect the file and
>> see if one can determine why the failure occurred.
> anyway...
Clearly it is, because I've only done it several times in my lifetime. ;-)
Come to that, I've even somehow managed this "impossible" or "almost
impossible" task a few times *without access to the code*. <gasp>
(There you go again, assuming because you can't see how it could be done
that it must be absolutely impossible for anyone to do - you really need
to stop doing that).
Now, from a *practical* standpoint, with access to the source, the way I
would do it is this:
1.  Grep for the error code in the source tree.
2.  Look at the function the error code is in; if it's a generic error
function, then it becomes a little more tricky, but not impossibly so,
because:
3.  I can use a tool like Source Navigator NG to show me the function
call stack; walking backwards through the stack and seeing what
conditions must exist in order to end up with that error message can
point to several causes.
4.  Then look at the options for causes, and see which one is likely on
the system.
5.  If it is easy to reproduce the cause, try it and see if the result is
what was expected.
Not so difficult to do - and I don't have a background in software
engineering. ;-)
Jim
Date: 24 Apr 2010 16:38:53
Message: <4bd356dd@news.povray.org>
Immediately one that comes to me is the output of a program that was off
by one - and the original program is no longer available or it would take
longer to re-run than to just correct the data.
It's entirely possible if you understood it better and what the
capabilities of the various programs are, you could save yourself time
(either now or in the future) by not doing things in a way that is harder
or takes more time.
I said earlier that I'm not a software engineer - and I'm not.  I took a
few courses in programming and Computer Science when I was at uni, but I
do understand that if the only language you know is BASIC (the first
language I learned - Commodore BASIC), many things will seem impossible
to do because the *tool* is limited.  By understanding that there are
other tools available and some tools are better suited to accomplish a
task than others, you broaden your ability to get the job done
efficiently.
If I had stuck with just programming in C (which was may main language of
choice), then doing the types of data manipulation I do with awk or sed
(I prefer the former, actually, but can use both), I'd be stuck in a
cycle of code, compile, run, analyze, modify code, compile, run,
analyze.....which takes a lot more time.
In C, a program to search and traverse the directory structure would be
quite long (actually, one can see what's involved by looking at the
source for grep!), but using a tool that's built for that purpose?  Much
more efficient than building your own.
You know the old saying, when the only tool you have is a hammer,
everything looks like a nail?
Jim
Date: 24 Apr 2010 17:40:58
Message: <4bd3656a$1@news.povray.org>
everything looks like a thumb.
Date: 24 Apr 2010 18:18:23
Message: <4bd36e2f@news.povray.org>
LOL, too true!
Jim
Date: 25 Apr 2010 01:37:25
Message: <4bd3d515@news.povray.org>
> add one to it.
  You don't understand the concept of a simple example, do you?
  An example is a simple proof-of-concept which demonstrates a feature.
Asking "why would you want to do that" is idiotic when we are talking
about examples.
  If you give someone an example of a short Haskell program which prints
"Hello World!", and that someone would then ask you "why would you want
to do that?", wouldn't you consider him an idiot? He is *missing the point*.
It was just an example to demonstrate something.
Date: 25 Apr 2010 04:35:31
Message: <4bd3fed3@news.povray.org>
My programs aren't arbitrary. They have some kind of structure to them.
Other people's programs do not necessarily have this property.
Date: 25 Apr 2010 10:34:42
Message: <4bd45302$1@news.povray.org>
So, everyone else is a *worse* programmer than you? And they write random
programs with no purpose? ;-)
Here's the deal that Turing figured out. You can't take every *arbitrary*
program, i.e., one created by generating a bunch of machine code
instructions with a random number generator, and figure out what it's going
to do without running it. But that's not how people write programs.
You also can't check that a program is typesafe, because you can't tell if
an arbitrary program every assigns the wrong type to a variable. But we
design strongly-typed programming languages that disallow well-typed
programs that the compiler can't prove are well-typed.
Since people don't debug arbitrary random programs, it's usually (usually!)
fairly easy to figure out, when you get an error message, what caused it.
Certainly easier than when you get no error message and just the wrong answers.
