POV-Ray : Newsgroups : povray.off-topic : Context switching Server Time
12 Jun 2026 12:47:41 EDT (-0400)
  Context switching (Message 103 to 112 of 222)
Subject: Re: Context switching
Date: 22 Apr 2010 07:01:30
Message: <4bd02c8a@news.povray.org>
scott <sco### [at] scottcom> wrote:
> >> Or, in Windows, you can just type the string into the top right of any
> >> explorer view, in the box that says "Search".
> >  I wish it worked. It doesn't.
> Works fine here - I just tested it by typing in "Vector3" (used in XNA game
> studio to represent a 3D vector) and within about 1 second the explorer
> window had filled up with lots of C# source code files, plus lots of POV
> source files (I guess it uses Vector3 too).
  Lucky you.
Date: 22 Apr 2010 07:09:57
Message: <4bd02e85@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Heh. I didn't know the shell could do that either. (Although you didn't
> specify *which* shell - Unix has several...)
  I don't think there's a unix shell in existence that doesn't do file name
pattern expansion. It would be a rather useless shell if it didn't.
  The shell doing the expansion rather than the program is a rather clever
idea. In DOS it was always the program which did the expansion, which meant
that many programs didn't support expansion patterns because the programmers
were lazy. It's also handy because a more advanced shell can support more
complex expansion patterns without the need for the programs to support them.
  The program just ends up seeing a bunch of file names in the command line
(because the shell expands them before even launching the program).
> I'm still not seeing what's so useful about being able to search a file
> for something.
  Suppose that you have a httpd log file and you want to list all entries
within a specific day. Or the number of requests for a specific file (or
a group of files). Suppose you want to list all entries *except* those
which match a certain pattern (eg. they have a referrer which indicates
that the request was made by a search engine). 'grep' is your tool for that.
> Now, I suppose if you were trying to script something, being able to
> pipe output from another command into grep so that it can grab a
> particular substring that you can then pipe to something else might be
> useful. But then, if *I* wanted to do something like that, I wouldn't
> script it. I'd write a real program, not a script.
  Filtering some files through a chain of programs (such as grep and sed)
takes just a few seconds of writing a few commands on the command line.
Writing a program to do that would probably take a hundred times longer.
> I never have 50 small files.
  Haha. You are quite humorous sometimes.
Date: 22 Apr 2010 07:11:10
Message: <4bd02ece@news.povray.org>
> I still don't get why you'd need to do complex searching. And if for
> some strange reason you do need to, why use an obfuscated text string
> with limited processing capabilities when you can use a real programming
> language?
  Because you can write a simple search pattern in a matter of seconds,
while writing the equivalent program would take you minutes at least.
Date: 22 Apr 2010 07:17:37
Message: <4bd03051@news.povray.org>
>  Lucky you.
Computers don't work on luck :-)
Date: 22 Apr 2010 07:22:00
Message: <4bd03158@news.povray.org>
>> language?
Um... why? Three lines of text doesn't take "minutes" to write. And
that's about all it takes to search a folder for a file matching a
condition. (Obviously, it depends on how complicated the condition is...)
Date: 22 Apr 2010 07:22:25
Message: <4bd03171@news.povray.org>
Some days I start to wonder... :-S
Date: 22 Apr 2010 07:22:57
Message: <4bd03191$1@news.povray.org>
> idea.
Yeah. But then, it's part of the general Unix philosophy of "make each
tool do one job, and one job well".
With MS-DOS/Windows, the shell's job is basically to launch the
interactive programs that do all the *real* work. The shell itself is
pretty poor. (Although not quite as poor as it seems at first...)
>> for something.
Ah, right. I see.
Personally, I'd import the whole log into a relational database, and
process it that way. (Or maybe even use a webserver that keeps its logs
in a database in the first place, rather than a huge flat file.) But
apparently that's just me...
On the contrary, figuring out how to work grep vs writing a program in a
language I already know well is likely to take *slightly* more than
merely a hundred times longer. (Although you could argue that's a
one-time cost.)
Personally I just dislike scripting languages. I'd rather use a real
language with propper error checking and so on and so forth. But I guess
that's just me.
Maybe I just don't try to do the same kinds of tasks as you?
Date: 22 Apr 2010 08:22:32
Message: <4bd03f87@news.povray.org>
  Talk about an overly complicated solution for a simple problem.
> one-time cost.)
  Writing something like "grep 'hello.*there' file.txt" doesn't require a
lot of time or thinking.
> that's just me.
  What's the difference between "a scripting language" and "a real language"?
Date: 22 Apr 2010 08:26:47
Message: <4bd04087@news.povray.org>
  How long does it take you to write a program which does the same thing
as this:
    fgrep '#include "header.hh"' *.cc
  How long does it take to write the program *and* compile it *and* run it?
Why would you do that when you *already* have a program which does that
(namely 'grep')?
  And I didn't even use any wildcards there.
Date: 22 Apr 2010 08:31:08
Message: <4bd0418c$1@news.povray.org>
Once the data is in a real database, you can sort it and search it and
compute stats on it and basically do whatever you want with it,
effortlessly and easily. But sure, if you *only* wanted to quickly see
if a particular IP address appears or something, you could use a text
search. But if I was hunting through web logs, I'd probably want to
build all sorts of statistics or do multi-way searches - the exact task
that databases are especially designed to perform. Why not use the right
tool?
>> one-time cost.)
Nor does opening file.txt in a text editor and running a quick search.
(Not that I can think of a reason to want to do this in the first place...)
Now that is surprisingly hard to pin down. ;-)
