POV-Ray : Newsgroups : povray.off-topic : Scientific Faith Server Time
4 Jun 2026 04:21:31 EDT (-0400)
  Scientific Faith (Message 55 to 64 of 64)
Subject: Re: Scientific Faith
Date: 1 Apr 2010 02:56:51
Message: <4bb443b3$1@news.povray.org>
> The major things we have been sending is FM (and AM) modulated radio and
> TV. This is effectively a big signal in a very small bandwidth. If you
> make a spectrum it will turn up as an unexpected peak above the
> background. If you then become interested and look closer you will see
> that the spectral contend is not compatible with a line originating from
> an exited atom or molecule. So, if these aliens are at the right time and
> place and have a SETI project running they will detect us in a couple of
> centuries when the signal reaches them.
OOC how sensitive is the SETI equipment and project?  I mean how big must a
signal be from 200 ly away that we are able to detect it with that system?
Extrapolating from the Voyager power levels and distance, I make it that we
need a 350 GW signal to be transmitted from 200 ly away.  Is that realistic
to expect?
Date: 1 Apr 2010 07:42:51
Message: <op.vahetstimn4jds@phils>
And lo On Mon, 29 Mar 2010 18:17:10 +0200, Darren New <dne### [at] sanrrcom>
did spake thusly:
> Phil Cook v2 wrote:
>> Depends on the setup. Off the top of my head imagine a situation with a
>> night-guard on reception. The building is locked, but the alarms aren't
>> on. Now if the building can't be locked without the alarms being
>> activated that's a pointless function of the card.
> Yes, but that's not the problem. Indeed, that's how it works now.
> The problem is that the card unlocks the door but does *not* turn off
> the alarm.
Yes I would consider that a flaw :-)
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 1 Apr 2010 18:01:24
Message: <4BB517B2.2060302@gmail.com>
>> and TV. This is effectively a big signal in a very small bandwidth. If
>> you make a spectrum it will turn up as an unexpected peak above the
>> from an exited atom or molecule. So, if these aliens are at the right
>> time and place and have a SETI project running they will detect us in
>> a couple of centuries when the signal reaches them.
> must a signal be from 200 ly away that we are able to detect it with
> that system?
I don't know.
> make it that we need a 350 GW signal to be transmitted from 200 ly
> away.
The SETI equipment might even be somewhat more sensitive because they
are using larger disks. Then again they don't know what exact frequency
to tune into.
BTW I arrive at something more like 47 MW if the voyager is transmitting
all its power, which is unlikely, so the number could even be much lower.
> Is that realistic to expect?
If you really want to broadcast a message anything is realistic.
Date: 1 Apr 2010 18:21:20
Message: <4bb51c60$1@news.povray.org>
And what if they aim the message directly at us? I assume they can use less
power if they are pointing exactly at the Earth.
Date: 1 Apr 2010 20:27:54
Message: <4bb53a0a$1@news.povray.org>
> a signal be from 200 ly away that we are able to detect it with that
> system? Extrapolating from the Voyager power levels and distance, I make
> it that we
Eric Korpela, one of SETI@Home admins, replies:
> SETI@home has a sensitivity of about 1e-25 W/m^2, so if I'm doing my math
> right, a transmitter at 200 ly would need to be about 7e+12 W EIRP
> (effective isotropic radiated power). If the transmitter was attached to a
> telescope the size of AO, it would have a gain of about 2 million, so the
> actual transmitter would need to be about 3.5 MW total power.
> Of course for a directional transmitter ET would need to suspect we are
> here.
Date: 1 Apr 2010 20:46:04
Message: <4bb53e4c$1@news.povray.org>
And more info:
Eric Korpela wrote:
> Nicolas Alvarez wrote:
>>> math right, a transmitter at 200 ly would need to be about 7e+12 W EIRP
>>> a telescope the size of AO, it would have a gain of about 2 million, so
>>> the actual transmitter would need to be about 3.5 MW total power.
>>> here.
>> What if it's not directional but broadcast? How much power do the
>> 200ly-far aliens need to send a radio signal covering an entire
>> hemisphere*, so that a reasonable amount still reaches us (or rather
>> SETI's antenna)?
> That would be 7 TW. Which is the amount of power you can generate with a
> solar array 150 km x 150 km* in size (assuming 24% efficiency). That would
> be a bit more than our society could afford to spend on trying to
> broadcast our position.
Date: 2 Apr 2010 11:50:40
Message: <4BB6124F.40109@gmail.com>
Then they know we are here which implies that they noticed our radio or
television broadcasts. So, the answer to your question will not be
relevant within the next 3 centuries.
Date: 6 Apr 2010 03:03:44
Message: <4bbadcd0$1@news.povray.org>
>> we need a 350 GW signal to be transmitted from 200 ly away.
> The SETI equipment might even be somewhat more sensitive because they are
> using larger disks. Then again they don't know what exact frequency to
> tune into.
I assumed that the power needed goes up with the square of distance, so used
Google to calculate:
"(200 light years / 16.8e9 km)^2 * 23 W"
which actually gives 300 GW, but I think that's a big underestimate, as
presumably Voyager is directing its 23 W directly at Earth, and not
radiating out in a sphere.  If an alien world 200 ly away is radiating in
all directions equally, it would need to be outputting much more than 300 GW
in total.
Date: 6 Apr 2010 03:08:10
Message: <4bbaddda$1@news.povray.org>
>>> SETI's antenna)?
>> would
Good info, thanks!
Date: 9 Apr 2010 08:37:24
Message: <4BBF1F81.50902@gmail.com>
>>> that we need a 350 GW signal to be transmitted from 200 ly away.
>> frequency to tune into.
>> transmitting all its power, which is unlikely, so the number could
>> even be much lower.
> used Google to calculate:
You are absolutely correct of course, I seem to have forgotten the
square. :(
> in all directions equally, it would need to be outputting much more than
> 300 GW in total.
That too. Probably the most efficient way to do it is by modulating the
output of a star. Either directly (controlled starquakes?) or by putting
things in front of it (jupiter sized arrays of shutters?).
Only, SETI isn't looking for that.
