POV-Ray : Newsgroups : povray.off-topic : Binary trees, branches and leaves Server Time
16 Jul 2026 02:02:45 EDT (-0400)
  Binary trees, branches and leaves (Message 11 to 16 of 16)
Subject: Re: Binary trees, branches and leaves
Date: 5 Mar 2010 08:11:18
Message: <4b9102f6$1@news.povray.org>
Warp wrote:
>   However, can this be called object-oriented? Having objects in an array
> excludes the possibility of using objects of a derived type (unless an
> object of the derived type has the exact same size as the base type object;
> even then it requires some low-levelish trickery to get it working, at
> least in C++, and probably other languages where objects can be handled
> by value and put into arrays). However, one of the basic ideas of OOP is
> that whenever an object of type A is expected, an object of type B can be
> given to it instead, if B has been derived from A (or from any of its
> subclasses). An array of objects wouldn't support this.
Wouldn't you just need to determine the storage requirements of THE
LARGEST class of object? And allocate that amount for every object?
Granted, I don't actually know of a language or compiler which actually
supports this...
(In particular, if you can add new subclasses dynamically at runtime,
this approach obviously won't work at all. But if all classes are known
at compile-time, it's feasible in principle.)
Date: 5 Mar 2010 08:51:45
Message: <4b910c6f@news.povray.org>
  No, because indexing is done based on the type of the array. For the
indexing to work properly the array type would have to be that of the
largest object type, but then you wouldn't be able to easily store any
other type of objects there (because now you would be handling objects
of the most derived class type rather than objects of the base class
type).
  You could probably get around this limitation by creating an array
container class which handles the memory allocation and indexing using
low-level functionalities (raw pointer arithmetic and such), but it would
be quite a hack. And you wouldn't be able to use pointer arithmetic on
the array directly (except by using more abstract iterators).
  Then there's the problem of assigning objects: If you assign an object
to a place in the array where there's already an object, and they are of
different types... I don't think it would work. Maybe you could get around
it by first destroying the existing object and then placing the new object
in its place using placement new, but it becomes complicated.
  Perhaps not *impossible*, but as you may guess, quite hard and kludgey.
Date: 5 Mar 2010 09:03:56
Message: <4b910f4c@news.povray.org>
> type).
You seem to be looking at "can you do this in an existing language?" I'm
looking at "is it feasible for a hypothetical OO language to support
this efficiently?" I think it could be supported efficiently; I just
can't think of any language which does it.
Not if it's hard-wired into the language. Then it becomes no less hard
or kludgey than (say) generating the illusion that each program on the
machine has complete control of the entire machine, when in reality the
OS is time-slicing them and sharing memory and I/O resources between them...
Date: 5 Mar 2010 13:50:25
Message: <4b915271$1@news.povray.org>
Invisible wrote:
> One of the points of a relational database is that several programs can
> use the data, possibly in ways not originally envisaged.
I'd go so far as to say that was the *primary* point. We already had
standard database stuff using pointers, called CODASYL. It sucked if you
wanted to do anything unexpected with it.
> Today, lots and lots of people seem to forget this. They think of a
> database as being a system for holding data that only one application
> uses and only that application understands. This isn't what a database
> is supposed to be. It's supposed to facilitate access by multiple programs.
This si why I laugh at people who say it's better to put the data
consistency assurances in the program.
> Or sometimes it's just for performance. An order can be completely
> identified by the customer it's for, the date it was placed, and what
> was ordered.
Well, probably customer and timestamp. You don't have to know what they
ordered at 14:01 on Jan 23 to find it. The artificial key, being artificial,
is a secondary key, not a primary key.  Unless it is printed on the physical
slip you used to take the order, like at a restaurant or something.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 5 Mar 2010 14:07:43
Message: <4b91567f$1@news.povray.org>
Warp wrote:
>   One interesting question: If objects are in an array rather than being
> individually allocated (and handled through references/pointers), can it
> still be called object-oriented?
I would think so. Inheritance is just one part of the OO thing.
It could, if you allocate enough space in the array for child types. Of
course this breaks if you start loading new child classes at runtime. You
just artificially inflate the size you allocate to be large enough.
You're also running into the covariance problem. If you have
virtual A* x(B*) { ... }
(i.e., a function x that take an instance of B or one of B's subclases as an
argument, and returns an instance of class A or one of A's children...)
what is a subclass that overrides that x allowed to declare as a return type
and an argument type?  Is it allowed to accept only C*, where C is a child
of B?  Is it allowed to accept D*, where D is a parent of B?  Now ask the
same about A, and you get a completely different answer.
Date: 5 Mar 2010 14:10:33
Message: <4b915729$1@news.povray.org>
C# lets you declare arrays of objects that are inline like C++, and the
generic "List" class will generate special versions when you instantiate it
with a class that is pass-by-value, but the nature of the pass-by-value
objects is that you can't inherit from them and add any fields, so the
question doesn't come up.
Yeah. C++ style OO is kludgey in C. That's why cfront was written. :-)
