POV-Ray : Newsgroups : povray.off-topic : Try Haskell Server Time
4 Jul 2026 22:22:50 EDT (-0400)
  Try Haskell (Message 11 to 20 of 62)
Subject: Re: Try AJAX
Date: 3 Mar 2010 04:06:29
Message: <4b8e2695@news.povray.org>
Warp wrote:
> Invisible <voi### [at] devnull> wrote:
>> I had no idea that you can actually do that...
>   You clearly haven't used gmail.
Indeed. But I have, at least, heard of it. ;-)
Date: 3 Mar 2010 05:03:46
Message: <4b8e3402$1@news.povray.org>
> Right, so... if I'm understanding this right, XMLHttpRequest allows a mere
> script to instruct the browser to send an HTTP request, and return the
> body of the response as data, which the script can then further
> manipulate?
What happens when the user presses the back button after such a process?
Can the script intercept this and provide its own "back" functionality?
I've definitely got annoyed by some sites where you hit the back button and
it takes you to a site you were looking at 10 minutes ago, because all the
things you've been doing on this site haven't actually loaded a new page...
Date: 3 Mar 2010 05:10:36
Message: <4b8e359c$1@news.povray.org>
> and it takes you to a site you were looking at 10 minutes ago, because
> all the things you've been doing on this site haven't actually loaded a
> new page...
Yeah, this is a lot of fun.
The other one is "JavaScript links". You know, where the "link" isn't
actually a hyperlink, it executes some JavaScript, which then tells the
browser to change URL. And because it's scripted, you can't Ctrl+click
to open the URL in a new window. (Or if you do, the existing window
changes URL anyway, so you *still* don't have the original page. At
least you can usually use the browser history to go back a page though.)
And then there's the links which pop up a "window" over the current
page. You know the kind - the whole page goes grey and a funky little
box appears over the top of it, and you can't do anything with the rest
of the page until you dismiss the box. (Modal dialogs suck for a reason!)
Lots of shopping sites like to take you to a completely different page
as soon as you've bought something, which also tends to thwart any
attempt to used tabbed browsing to nagivate around. You've got a page of
items, but as soon as you buy one, the page goes away. Great. Now I have
to somehow navigate back to where I just was...
Date: 3 Mar 2010 05:12:18
Message: <4b8e3602$1@news.povray.org>
Invisible wrote:
> Seems reasonably clear...
Hmm, I wonder if I could use this to implement distributed MVC, like in
my Final Year Project, but without requiring a custom client.
Of course, as far as I can tell, I need a real web server to even
experiment with this stuff, so...
Subject: Re: Try Haskell
Date: 3 Mar 2010 09:20:10
Message: <4b8e701a@news.povray.org>
scott wrote:
> The tutorial was good up until step 7.
Hmm, maybe I should write my own?
 > 2 + 2
That was easy, eh?
 > 2 + 3 * 4
The usual operator precedence rules apply.
 > (2 + 3) * 4
You can override operator precedence manually in the usual way.
 > sqrt 144
This is a function call. (Notice the lack of brackets!)
 > div 10 3
This is a 2-argument function. (Again, notice the lack of any brackets.)
It performs integer division (i.e., division to the nearest whole number.)
 > 10 / 3
Does the same calculation, but with floating-point arithmetic.
 > 10 `div` 3
This does the same thing as the first one, but it looks more natural.
The backticks work for any 2-argument function.
 > sin 1 + cos 1
This is sin(1) + cos(2).
 > sin (1 + cos 1)
This does a different calculation.
 > sin -1
This gives an error, because it thinks you mean "sin - 1", which is
invalid. (Yes, we all think it's very annoying.)
 > sin (-1)
This works properly.
 > "This is a string."
 > 'X'
This is a single character.
 > "X"
This is a string that only contains 1 character.
This is an empty string.
 > [8, 3, 11, 2]
This is a list of numbers.
 > ['X', 'Y', 'Z']
This is a list of characters. Note that a string *is* a list of characters!
 > ['X', 3]
A list can contain elements of any type, but all elements must be of
*the same* type. This example is therefore invalid. (Nice clear error
message, eh?)
 > sort [8, 3, 11, 2]
 > reverse [8, 3, 11, 2]
 > sum [8, 3, 11, 2]
 > 3 `elem` [8, 3, 11, 2]
 > 4 `elem` [8, 3, 11, 2]
Haskell has many, many list functions.
 > [1, 2, 3] ++ [4, 5, 6]
This joins two lists together.
 > [1..10]
This is a shorthand for writing lists.
 > sum [1..100]
Add up these numbers.
 > product [1..100]
Multiply these numbers. (Notice that even though the answer is huge,
Haskell computes it exactly.)
 > take 3 [5,4,6,3,7,2,8,1,9]
Get the first 3 elements.
 > drop 3 [5,4,6,3,7,2,8,1,9]
Remove the first 3 elements.
 > [5,4,6,3,7,2,8,1,9] !! 5
Get the 6th element. (The first element is index zero, not index one!)
 > filter odd [5,4,6,3,7,2,8,1,9]
Filter a list according to a condition.
 > filter (> 5) [5,4,6,3,7,2,8,1,9]
Filter with a different condition.
 > map (*2) [5,4,6,3,7,2,8,1,9]
Double all the numbers in the list.
 > map toUpper "This is a string."
Since strings are just lists that contain characters, all list functions
work on strings.
 > sin
You can't print this out, so you get an error.
 > :t sin
This tells the interpretter to only print the type signature, not
*execute* the code. (This is an interpretter command, not a Haskell
command.)
 > (5, 'x')
This is a "tuple". Tuples can contain any number of elements, and they
can be of different types. Their main use is in returning several
results from a single function call.
 > partition odd [5,4,6,3,7,2,8,1,9]
This splits the list into two lists, containing odd and not-odd numbers.
The lists are returned as a size-2 tuple.
 > :t fst
Take a look at this type signature. Can you figure out what it means?
 > fst (5, 'x')
Did that do what you expected?
 > let x = 5 in x + 1
This is how you define local variables. (The interpretter unfortunately
doesn't let you define things and then use them later. Everything has to
go into a single giant let-expression.)
 > let x = 5; y = 8 in x + y
This is how you define multiple variables.
 > iterate (*2) 1
This starts with 1, and applies the "times two" function to it over and
over again, creating an infinite list of results. (Again, the
interpretter doesn't display the whole thing.)
 > let factorial n = product [1..n] in factorial 6
This is how you define a new function. (Normally it wouldn't be a local
variable, but the interpretter unfortunately doesn't allow top-level
definitions.)
 > :t (+1)
This is a function that adds one to a number.
 > :t (*2)
This is a function that multiplies a number by two.
 > :t (+1) . (*2)
The "." operator takes two functions and combines them together. Here
we've made a function that takes a number, multiplies it by two and then
adds one. (Note carefully the order - RIGHT TO LEFT!)
 > map ((+1) . (*2)) [1..10]
Apply this function to a list of numbers.
 > :t div
This is a 2-argument function that does integer division.
 > :t div 10
This is not a syntax error. It's a 1-argument function. WTF?
 > :t div 10 5
This is a calculation that produces a number.
 > div 10 5
This divides 10 by 5.
 > map (div 10) [1..10]
See if you can work out what's going on.
OK, I'm going to stop now...
Date: 3 Mar 2010 11:00:56
Message: <4b8e87b8@news.povray.org>
You have a real web server.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 3 Mar 2010 11:05:15
Message: <4b8e88bb$1@news.povray.org>
GIYFT!
Date: 3 Mar 2010 11:12:01
Message: <4b8e8a51$1@news.povray.org>
I do, but it can only serve static HTML. (Plus it's quite a lot of work
continually logging into the web interface to re-upload your files every
time you edit 1 line of code.)
I think to try this out properly I'd have to set up a local Apache VM or
something. (This requires me figuring out how the hell to set up
Apache.) Alternatively, I could just write a trivial Haskell webserver
that will log what requests the browser is sending in response to by code...
Date: 3 Mar 2010 11:13:24
Message: <4b8e8aa4$1@news.povray.org>
It's very useful for an absolute beginner, these are the things you need to
know that a lot of tutorials assume you somehow magically know already.
> > :t fst
> > fst (5, 'x')
Well it seems to return the first item from a tuple.
Is it just a shorthand for "take 1"?
Ah no, it seems those list operators don't work with tuples :-(
> > let x = 5 in x + 1
So this means "let x = 5 in (the following expression)..."
Now Step 7 in the original tutorial makes sense :-)
OK I need to download the compiler if I am to actually learn any of this...
Date: 3 Mar 2010 11:24:45
Message: <4b8e8d4d$1@news.povray.org>
Uh, no. Every major OS comes with a real web server.
Now, if what you mean is "I don't have my own computer", then that's a
different question.
Unless you're using an IDE, yes. ;-)
> Apache.)
Depoending on your OS and distribution, this can be pretty trivial.
But if you're actually going to get into AJAX programming, you're going to
have to learn more than you can by asking people here to explain it to you. ;-)
