POV-Ray : Newsgroups : povray.off-topic : Probability question Server Time
1 Apr 2026 22:36:31 EDT (-0400)
  Probability question (Message 29 to 38 of 38)
Subject: Re: Probability question
Date: 9 Feb 2010 11:42:04
Message: <4b71905c@news.povray.org>
Invisible wrote:
> Oh, I see. I thought it was going to say something more insightful than
> that. (How the hell do you compute a limit or an integral anyway?)
Ahh, no nothing more insightful, just that it did address the major
points you were worrying about.
Also, I'll assume you mean "how do you numerically compute a limit or
integral?":
If it's a limit, just compute it for numbers as close as possible to the
limiting value (or really really big numbers if the limiting value is
infinite).  The closer (or the bigger) the number you compute it for the
closer your answer will be.
If it's an integral do something like this:
http://en.wikipedia.org/wiki/Riemann_sum
> But you can't compute an infinite product.
If the product converges (which it does, otherwise you couldn't define a
number/function with it) then you can by definition get an arbitrarily
good approximation by computing the product of the first n terms for a
large enough n.
You might want to read up on these, they're pretty much fundamental to
all of calculus and many many other ways of defining things over the
real (or complex) numbers (Taylor expansions, Fourier series, numeric
optimization and root finding, etc.):
http://en.wikipedia.org/wiki/Limit_(mathematics)
http://en.wikipedia.org/wiki/Limit_of_a_sequence
Out of curiosity have you ever had a calculus class?  I'd think that
these things should have been covered there, and it makes me wonder if
maybe the UK curriculum is somewhat different that what I'm used to.
Date: 9 Feb 2010 11:49:03
Message: <4b7191ff$1@news.povray.org>
>> than that. (How the hell do you compute a limit or an integral anyway?)
> integral?":
Wouldn't that be increadibly unstable, numerically?
I see. (Although I'm still not sure how you compute an infinite integral
this way...)
> large enough n.
I don't see how that is the case.
If you have an infinite *sum*, then as long as the terms get
progressively more tiny and never get larger again, you can disregard
all the terms after a certain point. But if you're taking a *product*
then any term, anywhere in the series could radically alter the final
result.
I've never had *any* maths class!
(Unless you count what we did at school. This simply involved filling
out hundreds of thousands of pages of long-division problems over a
7-year period...)
Hypothetically I shouldn't be able to do algebra at all...
Date: 9 Feb 2010 11:58:08
Message: <4b719420$1@news.povray.org>
How could it be?  If you're taking the limit of something that's going to a
finite value in a continuous curve, how could your calculation of the value
closer to the limit have more error than the error calculated farther from
the limit?
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 9 Feb 2010 12:04:49
Message: <4b7195b1$1@news.povray.org>
>> the limiting value (or really really big numbers if the limiting value
>> is infinite).  The closer (or the bigger) the number you compute it
>> for the closer your answer will be.
How much a a problem this is depends on the limit.  For most limits that
I've ever numerically computed it's worked fine.  If you're taking the
limit of a series (as opposed to the limit of a function) then it'll
almost certainly be fine.
> this way...)
Combine this definition with how you compute the limit of an infinite
sum.  So you'll have two approximations, one in approximating the
integral with an infinite sum, and another with approximating the
infinite sum with a finite one.  If you're doing this, it'd be wise to
prove that these approximations both converge to the correct value.
>> a number/function with it) then you can by definition get an
>> arbitrarily good approximation by computing the product of the first n
>> terms for a large enough n.
> result.
The same is true for a sum actually.  The point is proving that an
infinite sum or product *converges* is to show that this doesn't happen.
  Basically you show that the partial sums/products form a convergent
sequence (see the "Limit of a sequence" Wikipedia article I linked).
Then you know by definition that you can get a good approximation by
computing a large enough partial sum/product.
In the case of a sum this requires that the terms progressively get
closer to zero, for a product it'll require they get closer to one.
> 7-year period...)
That's too bad, it seems like you would have greatly enjoyed being able
to do some math that was more advanced than long division.
Date: 9 Feb 2010 12:10:21
Message: <4b7196fd@news.povray.org>
> to a finite value in a continuous curve, how could your calculation of
> the value closer to the limit have more error than the error calculated
> farther from the limit?
According to Google calculator, sin(1e-14)/1e-14 = 1, but
sin(1e-15)/1e-15 = 0.
Date: 9 Feb 2010 12:38:23
Message: <4b719d8f@news.povray.org>
*caveat: unless the product converges to zero.
Date: 10 Feb 2010 04:15:25
Message: <4b72792d@news.povray.org>
>> calculated farther from the limit?
Indeed, this was going to be my example. When x is small, sin(x) is
approximately equal to x. But whatever, sin(x)/x when x is small
involves division by a tiny number - which is equivilant to
multiplication by a huge number. It's numerically unstable.
(Of course, the limit of sin(x)/x as x approaches zero is just 1, which
you don't need to "estimate" in the first place. But if you had a
similar formula which approximates some irrational quantity...)
Date: 10 Feb 2010 04:17:11
Message: <4b727997$1@news.povray.org>
>>> value is infinite).  The closer (or the bigger) the number you
>>> compute it for the closer your answer will be.
> How much of a problem this is depends on the limit.
True enough.
>>> If the product converges then you can by definition get an
>>> n terms for a large enough n.
>> result.
I guess it's just the case that an infinite sum or product can be
convergent, and yet converge really, *really* slowly...
>> 7-year period...)
Well, I *did* go to a school for stupid people, after all...
Date: 10 Feb 2010 13:47:56
Message: <4b72ff5c@news.povray.org>
Orchid XP v8 wrote:
> Nicolas Alvarez wrote:
>> Invisible wrote:
>>> http://office.microsoft.com/en-us/excel/HP052090051033.aspx
>> Nice, that link crashed my browser :) Clearly Microsoft and KDE don't
>> like each other.
> Crashed it? Or just upset it?
Crashed. A khtml::BidiContext object supposedly on the memory address
0xffffffffffffffff had one of its member methods called. *Boom*.
I filed a bug: http://bugs.kde.org/show_bug.cgi?id=225954
Date: 11 Feb 2010 04:09:30
Message: <4b73c94a$1@news.povray.org>
>>> like each other.
OK, that's not good...
