POV-Ray : Newsgroups : povray.off-topic : BIGNUMs for Andrew Server Time
31 Mar 2026 18:40:47 EDT (-0400)
  BIGNUMs for Andrew (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: BIGNUMs for Andrew
Date: 17 Jan 2010 13:49:06
Message: <4b535ba2@news.povray.org>
andrel wrote:
> On 17-1-2010 16:12, Doctor John wrote:
>> andrel wrote:
>>> I particularly like it that they used a ray-tracer to produce figure 1.
>> I hadn't actually noticed that ...
>> <checking>
>> ...you're joking, aren't you?
> I don't think you can create such graphics with an ordinary package like
> Excel or SPSS. So, yes I might be.
I don't get your sense of humor, but I guess the reciprocal is true. :P
in any case, it looks more like a scan from a manually-drawn chart than
something generated on PC.
Date: 17 Jan 2010 13:50:49
Message: <4b535c09$1@news.povray.org>
Doctor John wrote:
> See http://eprint.iacr.org/2010/006.pdf for details of the method
*wooosh*
That was the sound of most of the paper flying straight over my head.
About the only thing I _did_ understand is that whoever these people
are, they somehow have access to some pretty futuristic computer
hardware. o_O
http://blog.orphi.me.uk/
Date: 17 Jan 2010 14:01:56
Message: <4b535ea4$1@news.povray.org>
> hardware. o_O
good thing it is researchers spending two years and a half of many
hundreds of machines rather than thieves. ^^;
Date: 17 Jan 2010 14:04:31
Message: <4b535f3f$1@news.povray.org>
> <checking>
Hahaha wtf?
Date: 18 Jan 2010 05:02:36
Message: <4b5431bc$1@news.povray.org>
>> hardware. o_O
Heh, good thing I typically use 4,096 bits for an RSA key. (Honestly, as
far as I can tell, there is no detectable difference in speed at all...
But it's going to make one hell of a difference to anybody bored enough
to want to attack a key that belongs to *me* of all people.)
I just visited a random website that uses HTTPS, and it seems all the
certificates are RSA 2,048 bits. Which is interesting, because the
encryption itself is just RC4 (128 bits). And this is "high-grade
encryption"??
Date: 18 Jan 2010 05:38:03
Message: <4b543a0b$2@news.povray.org>
> encryption"??
The purpose of the https is mainly authentication.
Encryption using RC4 is weak anyway, and unpublished (STO: bad!)
RC4 is just quick enough to not bother too much a server.
the 128 bits of the RC4 key are used to generate a pseudo-random bit
sequence, and applying the output to XOR.
It might stop your child from eavesdropping, but that pretty all.
For instance, it is used in Wep (wifi)... and wep-keybreaker are everywhere.
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 18 Jan 2010 05:55:09
Message: <4b543e0d$1@news.povray.org>
>> encryption"??
It proves you're giving your credit card details to the right company.
...and it's supposed to prevent anybody listening in from stealing the
data in transit. So, yes, the encryption part is supposed to actually work!
Unpublished, but never the less leaked and therefore widely known and
analysed. As to how weak it is... well, it wouldn't be my first choice.
Interesting that Firefox refers to it as "high-grade encryption".
(Presumably because it's 128-bit RC4 and not the 40-bit RC4 that USA
export software used to have to use. That stuff really *is* weak!)
Probably.
This is the definition of "stream cipher", yes. Lots of ciphers work
this way.
It certainly isn't *trivially* breakable by any means. But sure, it
isn't the cipher I'd choose.
WEP is broken due to the simplistic way keys are handled, not due to RC4
itself as such.
Date: 18 Jan 2010 11:43:58
Message: <4b548fce@news.povray.org>
> encryption"??
  Number of bits between different encryption algorithms is not comparable.
  For example AES-256 is currently thought to be unbreakable while RSA-512
is not, even though the latter uses twice as many bits.
Date: 18 Jan 2010 11:47:12
Message: <4b549090$1@news.povray.org>
>> encryption"??
Most particularly, asymmetric algorithms such as RSA typically require
far more bits than do symmetric algorithms such as RC4. But sure, it
also varies by individual cipher of course.
My point was that 128 bits isn't much for *any* symmetric cipher. So
calling this "high-grade encryption" is somewhat misleading.
2,048 bits for the RSA cipher, OTOH, should be safe for a while yet...
Date: 18 Jan 2010 11:53:30
Message: <4b54920a$1@news.povray.org>
Not because RC4 is easy to break, tho, but because RC4 is a stream cypher
being used to encrypt multiple small unordered packets from multiple
sources, so most of the key winds up being put into every packet.
RC4 used as a stream cypher is much stronger than RC4 used as a block cypher.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
