![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
> Aren't all cars upgradeable with just software nowadays? In my car the
> "1.6L", "1.8L", "2.0L" and "2.3L" versions all actually have exactly the
> same engine. You are just choosing whether you want the 116, 143, 177
> or 204 BHP software installed when you buy it :-)
Erm... 1.6L means that the engine block has a displacement of 1.6L,
while 2.3L means that the displacement is 2.3L - i.e., the cylinders are
physically bigger.
The Real WTF of course is that displacement is not directly related to
power output in the first place...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Stephen wrote:
> Would you run that past me again, in English? :-)
Download 'milnerhindley.png' (78 KB)
Preview of image 'milnerhindley.png'
![milnerhindley.png](/povray.off-topic/attachment/%3C4b4d989a%40news.povray.org%3E/milnerhindley.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
The bit where it says take away the number you first thought of.
Nice one BTW :D
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Stephen wrote:
> Nice one BTW :D
Heh. Somebody had this printed on a T-shirt [as you can probably tell].
I just copied the image file. ;-)
That's apparently the Milner-Hindley type inference algorithm. But whatever.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> Stephen wrote:
>> Nice one BTW :D
> whatever.
That's what the file name says :D
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> whatever.
I believe the correct response is "that's what SHE said!"
And besides, I named the file. (The website does some JavaScript
trickery to make it maximally awkward to copy the image file. But they
didn't bargin for the PrtSrc key...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Kevin Wampler wrote:
> I suppose I normally view distance in Euclidean space from the same
> definition that applies to non-Euclidean spaces, rather than the
> sqrt(dx^2 + dy^2) form, so I didn't really consider this. You're right
> though, if you're starting from the pythorgean theorem view of distance
> it does bear some thinking about how it generalizes to the non-Euclidean
> space.
> That said, I'm not sure it's necessary to actually understand the proper
> definition of distance in order to talk about circles in other spaces --
> particularly if we limit ourselves to spherical and hyperbolic spaces
> which are more or less easy to visualize.
So how *do* you compute the distance between two points in a non-Euclid
space anyway?
For that matter, is there a way to unambiguously refer to a specific
point in such a space?
(Normally you would of course just use Cartesian coordinates, but it is
not clear to me that this works any more once you remove the parallel
postulate.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Interesting fact: In elliptic geometry, pi is less than arcsine 1.
> It's less than arcsine 1 where you're sitting right now. That's why they
> say gravity bends space-time.
Space-time is an inhomogenous space anyway. I hear that gravity bends it
with positive curvature, but the universe itself appears to have
slightly negative curvature...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Erm... 1.6L means that the engine block has a displacement of 1.6L, while
> physically bigger.
It used to be like that, if you bought a "one point six" it meant the engine
displacement was roughly 1600 cc, but nowadays car makers like to keep the
"one point six" naming convention but actually have a standard engine
displacement across all models. A bit like how AMD called their processor
an XP2400, but it wasn't 2400 MHz. If I'd bought the "1.6" version of my
car it would have exactly the same engine as the "2.0" version, displacement
1998cc.
There are a vast number of things that significantly affect power output
apart from displacement. A useful quantity is "horsepower per litre" to
compare engines. Really efficient road-car engines can get up to 100
HP/litre, racing engines over 300 hp/litre.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> are physically bigger.
> engine displacement was roughly 1600 cc, but nowadays car makers like to
> keep the "one point six" naming convention but actually have a standard
> engine displacement across all models. A bit like how AMD called their
> processor an XP2400, but it wasn't 2400 MHz. If I'd bought the "1.6"
> version of my car it would have exactly the same engine as the "2.0"
> version, displacement 1998cc.
Sure, but AMD don't actually call it the XP 2.4GHz. That would be false
advertising - as would claiming that an engine has a displacement of X
when it's actually Y.
Or just HP if you want to know how powerful it is, MPG if you want to
know how efficient it is... I never did understand the fascination with
displacement. (Other than that I guess you can unambiguously measure it.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
