![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Somehow, I always find it amusing how many FOSS programs assume Windows is
basically how it was in Win98 and completely fail to do the right thing.
For example, languages in which the call to "open" doesn't let you specify
how to lock the file, calls to get the owner of the file fail on Windows as
if there isn't any such concept, the ubiquitous assumption that Windows
doesn't have hard or soft links, and stuff like
On Windows, HOME and USERPROFILE will be used if set, otherwise a
combination of HOMEPATH and HOMEDRIVE will be used. An initial ~user is
handled by stripping the last directory component from the created user path
derived above.
which in other words means "we haven't bothered to find the API call that
tells you where a particular user's home directory is in Windows, so we'll
assume they're all subdirectories of the same parent directory, even tho
this isn't true in UNIX either."
And some people wonder why FOSS feels klunky on Windows.
Human nature dictates that toothpaste tubes spend
much longer being almost empty than almost full.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, you can always demand your money back.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
My guess is that that won't change while the portable C stdlibs they use don't
get updated to more modern times to cope with extra features... when in doubt,
use the lowest common denominator.
I merrily don't. Windows always felt klunky to me.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sometimes you're extremely predictable.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> is basically how it was in Win98 and completely fail to do the right thing.
I wouldn't limit this strictly to FOSS. Granted, it's been a while since
I've tried Windows -based freeware and shareware utilities, but on
Windows NT-series this has always been a problem with small utilities.
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah, I think that's the basic problem. Even so, you'd think the portable
libraries would at least try to support the same semantics where they can. I
hear the "Windows can't delete an open file" so often it's silly. Why
wouldn't you make your C compiler's "open" function set the flag that says
"let me delete open files" if that's how it works in POSIX?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
True. It mostly annoys me in big programs, tho, like language interpreters
for example.
As "nemesis" pointed out, it's more a problem in the use of C portability
layers than anything, which is excusable for small one-off programs. But if
you're going to port an X-windows based graphics system to Windows, you'd
think it would be easy to fix some of the other stuff too.
Of course it's FOSS, and if you don't need that, you're not going to
implement it. I understand that, which is why I find it amusing. Personally,
I'd be embarrassed to do something like porting Ruby or Python to Windows
without fixing such a thing.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, if the argument is valid, why change it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, if it is open source, why don't you fix it?
(Ducking and taking cover ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You're predictable in that you make that argument even when nobody else is
arguing. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
