POV-Ray : Newsgroups : povray.off-topic : FOSS annoyances Server Time
13 Jun 2026 16:13:27 EDT (-0400)
  FOSS annoyances (Message 14 to 23 of 33)
Subject: Re: FOSS annoyances
Date: 30 Dec 2009 18:43:02
Message: <4b3be585@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> They should at least stop putting misinformation in the documentation like
> "you can't delete open files in Windows" or "Windows doesn't have links".
> That's just plain wrong. The minimum would be to phrase it as "we don't open
> files in a mode that allows them to be deleted while open" and "we don't
> support links in Windows".
  It's an open source project. You can contribute.
Date: 30 Dec 2009 18:56:54
Message: <4b3be8c6$1@news.povray.org>
Wow, really?? Thanks, Warp! I didn't know that!
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 30 Dec 2009 18:57:19
Message: <4b3be8df$1@news.povray.org>
> open files in a mode that allows them to be deleted while open" and "we
> don't
Darren, how do you delete an OS-locked file or directory under Windows XP?
Can you point me to an api-call?
This is NOT meant as a tease, I am really interested in a solution to this
problem, if you know it.
About the links: yes, windows does indeed support links. I do not dare to
use them anymore. I tried once, but since people don't expect hard links
under Windows to some it came as a nasty surprise when they discovered the
doublettes they thought they were deleting were the actually hard linked
files...
Date: 30 Dec 2009 19:01:31
Message: <4b3be9db$1@news.povray.org>
>>> like "you can't delete open files in Windows" or "Windows doesn't
>>> have links". That's just plain wrong. The minimum would be to phrase
>>> it as "we don't open files in a mode that allows them to be deleted
>>> while open" and "we don't support links in Windows".
Wait, wait!  I have an even better idea!
I can go around the internet and correct *everyone* who says something
wrong! I'm sure that will improve the world and make me loved and respected
everywhere!
Date: 30 Dec 2009 19:10:06
Message: <4b3bebde@news.povray.org>
You don't lock it.  It's not that you can't delete an *open* file. You can't
delete an open file that was opened with the "don't let others write to this
while I have it open" flag.  The program opening the file has to open it in
a way that lets you delete it, which is why I'm saying I'm surprised that
(for example) the usual C runtimes don't default to setting this flag, since
that's the default under UNIX.
The primary problem is that the call to run a program opens the file with
that lock, in part because it pages out of the file while it's running. The
file gets locked because to delete a file in Windows you actually have to
open the file for delete, which requires write privileges. Opening an
executing file for writing doesn't work under Windows *or* UNIX, but you
don't have to open the file under UNIX to delete it.
Alternately, you can stick stuff in the registry that'll delete the file (or
rename it) next time the machine is booted, before all the code that tends
to hold files open runs, if that's what you mean.
It's just a normal delete.
> files...
Well, yes. That's not a good reason for a programming environment not to use
them. It's just a good reason to be careful how you expose that to your
users. :-)
Date: 31 Dec 2009 06:21:25
Message: <4b3c8935$1@news.povray.org>
Darren New wrote:
> Somehow, I always find it amusing how many FOSS programs assume Windows
> is basically how it was in Win98 and completely fail to do the right thing.
...which does, on the other hand, have the side-effect of making it
compatible with Win98. ;-)
> which in other words means "we haven't bothered to find the API call
> that tells you where a particular user's home directory is in Windows,
Or, more likely, "we just took our C sources and recompiled them on top
of a POSIX emulator, so we can't do anything that POSIX doesn't support
/ the emulator doesn't implement".
> And some people wonder why FOSS feels klunky on Windows.
Heh, well, the *really* fun thing is when you have to install GTK+
before the program will run... We all know what happens then. ;-)
http://blog.orphi.me.uk/
Date: 31 Dec 2009 10:36:27
Message: <4b3cc4fb@news.povray.org>
  And then you criticize me when I use sarcasm.
Date: 31 Dec 2009 10:59:17
Message: <4b3cca55$1@news.povray.org>
No, I criticize you for not making it obvious enough. For the record. :-)
Date: 31 Dec 2009 11:04:25
Message: <4b3ccb89$1@news.povray.org>
Orchid XP v8 wrote:
>> Windows is basically how it was in Win98 and completely fail to do the
>> right thing.
One might think that, but that tends not to be the case. In part, for
example, it'll support things like memory-mapped files and etc. as well.
Yes. Altho I don't think that's really the case. Tcl, for example, has a
whole X-windows emulation built in. That's why it's (a) somewhat slow, (b)
tends to look like Motif, and (c) gets used everywhere as a graphics library
for other languages. :-)
Come to think of it, one of the nice things about Tcl is how much people
have made extensions for accessing Windows-like stuff.  Considering this, I
expect I can find Python (for example) extensions to Do The Right Thing.
It really wasn't a complaint, as much as it was a "I wonder why people don't
fix this when they do it in the first place" sort of thought. Sort of "if
you're going to try to invent an algorithm to figure out where the home
directory is, why not just ask the OS". If it was completely unsupported, I
could see it, but to have it half-ass supported is ... half-ass.
Maybe I'm just getting sick of half-assed technology, tho.
Actually, I don't think I do.
Date: 31 Dec 2009 11:34:18
Message: <4b3cd28a$1@news.povray.org>
>> top of a POSIX emulator, so we can't do anything that POSIX doesn't
>> support / the emulator doesn't implement".
It is sometimes.
Like, there are several CLI tools which are just recompiled against
Cygwin to make a "Windows port", and you find that all sorts of strange
things break when you do that.
I know *I* am. But it's not like you can do anything about it... I used
to think you could, but apparently you can't.
...the program uses the GTK+ look and feel, rather than behaving like a
native Windows application?
Than again, on Linux it seems each program has its own totally different
look and feel, so...
