POV-Ray : Newsgroups : povray.off-topic : FOSS annoyances Server Time
15 May 2026 05:28:59 EDT (-0400)
  FOSS annoyances (Message 11 to 20 of 33)
Subject: Re: FOSS annoyances
Date: 30 Dec 2009 16:03:09
Message: <4b3bc00d$1@news.povray.org>
TC wrote:
> Well, if it is open source, why don't you fix it?
I have, in other situations. It's difficult to get involved enough to fix
all of them. And in part for the same reasons the original authors didnt:
it's not enough of a pain to me to do that. But it's much more of a pain for
me to fix it than it is for the original authors to do it right in the first
place. :-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 30 Dec 2009 16:46:10
Message: <4b3bca22@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> >>>> Somehow, I always find it amusing how many FOSS programs assume Windows is
> >>>> basically how it was in Win98 and completely fail to do the right thing.
> >>>   Well, you can always demand your money back.
> >> Sometimes you're extremely predictable.
> >   Well, if the argument is valid, why change it?
> You're predictable in that you make that argument even when nobody else is
> arguing. :-)
  I don't think that presenting an argument is the same thing as "arguing"
(ie. to contend in oral disagreement).
Date: 30 Dec 2009 17:20:25
Message: <4b3bd229@news.povray.org>
>> arguing. :-)
You're very predictable in that you present that argument every time someone
says something about FOSS.
In any case, wouldn't you think it rather lame if (for example) Mono only
read text files that had lines terminated in CRLF? Or if you frequently ran
across large complex Linux programs that assumed "~fred/x" should expand to
"/home/fred/x" regardless of what was in /etc/passwd?
They should at least stop putting misinformation in the documentation like
"you can't delete open files in Windows" or "Windows doesn't have links".
That's just plain wrong. The minimum would be to phrase it as "we don't open
files in a mode that allows them to be deleted while open" and "we don't
support links in Windows".
Date: 30 Dec 2009 18:43:02
Message: <4b3be585@news.povray.org>
  It's an open source project. You can contribute.
Date: 30 Dec 2009 18:56:54
Message: <4b3be8c6$1@news.povray.org>
Wow, really?? Thanks, Warp! I didn't know that!
Date: 30 Dec 2009 18:57:19
Message: <4b3be8df$1@news.povray.org>
> open files in a mode that allows them to be deleted while open" and "we
> don't
Darren, how do you delete an OS-locked file or directory under Windows XP?
Can you point me to an api-call?
This is NOT meant as a tease, I am really interested in a solution to this
problem, if you know it.
About the links: yes, windows does indeed support links. I do not dare to
use them anymore. I tried once, but since people don't expect hard links
under Windows to some it came as a nasty surprise when they discovered the
doublettes they thought they were deleting were the actually hard linked
files...
Date: 30 Dec 2009 19:01:31
Message: <4b3be9db$1@news.povray.org>
>>> like "you can't delete open files in Windows" or "Windows doesn't
>>> have links". That's just plain wrong. The minimum would be to phrase
>>> it as "we don't open files in a mode that allows them to be deleted
>>> while open" and "we don't support links in Windows".
Wait, wait!  I have an even better idea!
I can go around the internet and correct *everyone* who says something
wrong! I'm sure that will improve the world and make me loved and respected
everywhere!
Date: 30 Dec 2009 19:10:06
Message: <4b3bebde@news.povray.org>
You don't lock it.  It's not that you can't delete an *open* file. You can't
delete an open file that was opened with the "don't let others write to this
while I have it open" flag.  The program opening the file has to open it in
a way that lets you delete it, which is why I'm saying I'm surprised that
(for example) the usual C runtimes don't default to setting this flag, since
that's the default under UNIX.
The primary problem is that the call to run a program opens the file with
that lock, in part because it pages out of the file while it's running. The
file gets locked because to delete a file in Windows you actually have to
open the file for delete, which requires write privileges. Opening an
executing file for writing doesn't work under Windows *or* UNIX, but you
don't have to open the file under UNIX to delete it.
Alternately, you can stick stuff in the registry that'll delete the file (or
rename it) next time the machine is booted, before all the code that tends
to hold files open runs, if that's what you mean.
It's just a normal delete.
> files...
Well, yes. That's not a good reason for a programming environment not to use
them. It's just a good reason to be careful how you expose that to your
users. :-)
Date: 31 Dec 2009 06:21:25
Message: <4b3c8935$1@news.povray.org>
> is basically how it was in Win98 and completely fail to do the right thing.
...which does, on the other hand, have the side-effect of making it
compatible with Win98. ;-)
> which in other words means "we haven't bothered to find the API call
> that tells you where a particular user's home directory is in Windows,
Or, more likely, "we just took our C sources and recompiled them on top
of a POSIX emulator, so we can't do anything that POSIX doesn't support
/ the emulator doesn't implement".
> And some people wonder why FOSS feels klunky on Windows.
Heh, well, the *really* fun thing is when you have to install GTK+
before the program will run... We all know what happens then. ;-)
http://blog.orphi.me.uk/
Date: 31 Dec 2009 10:36:27
Message: <4b3cc4fb@news.povray.org>
  And then you criticize me when I use sarcasm.
