POV-Ray : Newsgroups : povray.off-topic : Geometric puzzle Server Time
3 Jul 2026 00:11:35 EDT (-0400)
  Geometric puzzle (Message 62 to 71 of 201)
Subject: Re: Geometric puzzle
Date: 16 Dec 2009 12:47:00
Message: <4b291d14$1@news.povray.org>
On Wed, 16 Dec 2009 16:43:12 +0000, Invisible wrote:
> So far I can't figure out how to even change the 3D view. :-|
Clearly it's impossible, then. <scnr>
Jim
Date: 16 Dec 2009 12:56:11
Message: <4b291f3b$1@news.povray.org>
Invisible escreveu:
> Clearly I'm going to have to sit down and do a whole crapload of reading
> before I can start doing anything interesting with Blender.
here's some quick tips:
ctrl+x - starts a new scene from scratch
esc - cancels things out
space - calls the main menu
right mouse button click (RMB) - selects
left mouse button click (LMB) - changes location of 3D cursor
a - selects all or none
s - scale
r - rotate
g - grab an object so you may move it around
c - center scene
navigating through 3D space:
numeric keyboard:
1 - front view
7 - top view
3 - side view
use together with shift to get to the other sides
del/, - focus on selected object
with the mouse:
alt+LMB - rotate the scene around by moving the mouse
alt+shift+LMB - grab the scene around by moving the mouse
(under X in Linux you may need to add the "Windows" button to the
configuration above)
mouse wheel - zoom
tab - changes between normal object mode, where you place and manipulate
objects (primitives), and mesh editing mode where you
now, when you are in mesh edit mode, to edit, say, the default cube:
ctrl+tab - changes between vertice, edge or face mode
now, here's a first lesson to you:
1) ctrl+x to create a new scene
2) cube is already selected so tab to enter mesh edit mode
3) input this:  s (scale) y (restricted to y axis) then move the mouse
until its reasonably thin in y axis
4) a to deselect all
5) ctrl+tab and select face mode
6) ctrl+space and select "Enable/Disable" so it doesn't get in the way
7) select the right face  (you may zoom in a bit to make it clearer)
8) alt+shift(+Windows)+LMB and drag the cube to the left corner of the
screen
9) ok, right face selected all you do now is extrude it in the xy plane
with ctrl+LMB clicks.
You may trace it along funky paths in the xy plane (as default view is
top view in the z axis) as long as the steps are about same length as
the original cube.
now:
10) tab to exit mesh edit mode
11) F9 -> Modifiers panel down there -> Add Modifier -> Level 3
12) In the Link and Materials panel to the left, click Set Smooth down there
13) in the numeric numeric keypad, hit 5 to enter perspective mode (5
again to go back to orthographic)
14) drag your scene around with alt+shift+LMB, zoom with mouse wheel and
rotate with alt+shift+LMB to get the "belt" centered on screen
15) once you're satisfied with it, hit ctrl+alt+0 to get the camera set
in this position
16) F8 -> World ajust the default black blue sky to a color of your liking
17) in the panel just next to it, click on the Amb Occ tab and turn on
Ambient Occlusion (default settings ok)
18) hit F12 to render with default settings
if you're curious how to manage that mesh from now on, here's the tip:
1) select the belt with RMB and go back to edit mode with tab
2) a until everything deselected
3) ctrl+tab to select edge mode
4) alt+RMB in one of the top edges to select a whole edge loop
edge loops, extrusions, loop cuts... that's how you manage complexity.
There's so much more to tell, but you'd be overwhelmed this way.  anyway:
F6 goes to the material panels.  ctrl+e gives you the very useful edge
loop tools.  In mesh edit mode, e extrudes and ctrl+r loop cuts (mouse
wheel or numeric argument for number of cuts while in preview).
Sometimes numbers can be used with some commands, like s+shift+y+5 to
scale 5 times in the xz plane (shift+y).
a game sig: http://tinyurl.com/d3rxz9
Date: 16 Dec 2009 13:07:04
Message: <op.u41lx7we7bxctx@bigfrog.bredbandsbolaget.se>
On Wed, 16 Dec 2009 17:39:53 +0100, Invisible <voi### [at] devnull> wrote:
> After spending almost an hour watching this,
Eh... are you not supposed to be working?
FE
Date: 16 Dec 2009 13:15:47
Message: <op.u41mcqdg7bxctx@bigfrog.bredbandsbolaget.se>
On Wed, 16 Dec 2009 17:43:12 +0100, Invisible <voi### [at] devnull> wrote:
> Well, now that I have VMware, I thought I might do that, just for a
> giggle.
Why would you need VMware to run Blender?
http://www.blender.org/education-help/tutorials/
http://www.blender.org/education-help/video-tutorials/
http://blenderunderground.com/video-tutorials/
The one with the mantis is also good, at least if you have sound.
One thing you need to watch out for when going through Blender tutorials
is that they were mostly made with older versions of Blender. The
interface seems to change in peculiar ways even between minor version
bumps, so keyboard shortcuts and such are sometimes different from what a
tutorial claims.
FE
Date: 16 Dec 2009 13:43:03
Message: <4b292a37@news.povray.org>
errata:
read
as
11) F9 -> Modifiers panel down there -> Add Modifier -> Subsurf -> Level 3
nemesis escreveu:
> Invisible escreveu:
>> reading before I can start doing anything interesting with Blender.
> s - scale
> r - rotate
> c - center scene
> numeric keyboard:
> 1 - front view
> 7 - top view
> 3 - side view
> with the mouse:
> mouse wheel - zoom
> screen
> the original cube.
> now:
> there
> in this position
Date: 16 Dec 2009 13:50:50
Message: <4b292c0a$1@news.povray.org>
Warp wrote:
> andrel <a_l### [at] hotmailcom> wrote:
>> More importantly, what did we learn from this and why did you, warp,
>> post this?
>   Does everything have to have a reason behind it? Can't things be done just
> for the fun of it?
that's what the mascot does all of the time - yet he gets chastized from
time to time ;-)
Date: 16 Dec 2009 14:21:29
Message: <4b293338@news.povray.org>
> >> post this?
> > for the fun of it?
> time to time ;-)
  He presents puzzles for people to think about?
Date: 16 Dec 2009 14:28:44
Message: <4b2934ec$1@news.povray.org>
>> from time to time ;-)
Sure, just many of them have to do with his personal life. ;-)
Jim
Date: 16 Dec 2009 14:38:53
Message: <4b29374d$1@news.povray.org>
And I think that there pretty much sums up why people think Blender's
interface sucks. :-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 16 Dec 2009 14:46:35
Message: <4b29391b@news.povray.org>
  Like this? "you sit down and your trousers are no longer able to contain
the mass of your thighs. o_O"
  Maybe I *don't* want to think about it...
